Bluetooth problem doesn't reconnect
Hello my friends
I'm on manjaro kde since last summer
and my problem is that a couple of days i boot up my laptop and the Bluetooth mouse doesn't connect automatically , but only if i delete it from the paired devices and pair again. My BT mouse is a noname mouse from ebay and it works pretty good before manjaro kde on mint kde too. I tried another bt mouse and i have the same result.The laptop is dual boot with win 10, on win 10 works good.So i thing it is some driver where the problem is.My laptop is a dell xps-l502x i7 8gb and here are :
$ inxi -Fxxxz
System:    Host: beams Kernel: 5.1.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5 tk: Qt 5.12.3
           info: cairo-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Portable System: Dell product: Dell System XPS L502X v: N/A serial: <filter> Chassis: type: 8 v: 0.1
           serial: <filter>
           Mobo: Dell model: 0NJT03 v: A00 serial: <filter> UEFI [Legacy]: Dell v: A07 date: 10/20/2011
Battery:   ID-1: BAT0 charge: 22.1 Wh condition: 22.1/73.3 Wh (30%) volts: 12.4/11.1 model: LGC Dell type: Li-ion
           serial: <filter> status: Full
CPU:       Topology: Quad Core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L1 cache: 64 KiB
           L2 cache: 6144 KiB L3 cache: 6144 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 35128
           Speed: 798 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 807 2: 801 3: 806 4: 807 5: 807 6: 800 7: 798 8: 807
Graphics:  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0116
           Device-2: NVIDIA GF108M [GeForce GT 540M] vendor: Dell driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:0df4
           Display: x11 server: X.Org 1.20.4 driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
           compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.0.4 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:1c20
           Device-2: Philips s SAA7231 vendor: Avermedia driver: N/A bus ID: 02:00.0 chip ID: 1131:7231
           Sound Server: ALSA v: k5.1.1-2-MANJARO
Network:   Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi v: kernel port: 3000 bus ID: 03:00.0
           chip ID: 8086:008a
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8168 v: 8.047.01-NAPI
           port: 2000 bus ID: 06:00.0 chip ID: 10ec:8168
           IF: enp6s0 state: down mac: <filter>
Drives:    Local Storage: total: 698.65 GiB used: 642.83 GiB (92.0%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB speed: 6.0 Gb/s serial: <filter> rev: 2B6Q
           scheme: MBR
           ID-2: /dev/sdb vendor: Hitachi model: HTS727550A9E364 size: 465.76 GiB speed: 3.0 Gb/s rotation: 7200 rpm
           serial: <filter> rev: A0D0 scheme: MBR
Partition: ID-1: / size: 105.84 GiB used: 85.28 GiB (80.6%) fs: ext4 dev: /dev/sda6
           ID-2: swap-1 size: 7.66 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 55 C
Info:      Processes: 234 Uptime: 2h 39m Memory: 7.68 GiB used: 2.59 GiB (33.7%) Init: systemd v: 242 Compilers: gcc: 8.3.0
           clang: 8.0.0 Shell: bash (su) v: 5.0.7 running in: konsole inxi: 3.0.34
$ dmesg | grep usb
[    0.740890] usbcore: registered new interface driver usbfs
[    0.740890] usbcore: registered new interface driver hub
[    0.740894] usbcore: registered new device driver usb
[    0.983880] usbcore: registered new interface driver usbserial_generic
[    0.983886] usbserial: USB Serial support registered for generic
[    1.183290] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.01
[    1.183293] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.183294] usb usb1: Product: EHCI Host Controller
[    1.183296] usb usb1: Manufacturer: Linux 5.1.1-2-MANJARO ehci_hcd
[    1.183297] usb usb1: SerialNumber: 0000:00:1a.0
[    1.183995] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.01
[    1.183997] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.183998] usb usb2: Product: xHCI Host Controller
[    1.183998] usb usb2: Manufacturer: Linux 5.1.1-2-MANJARO xhci-hcd
[    1.183999] usb usb2: SerialNumber: 0000:04:00.0
[    1.187180] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.187200] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.01
[    1.187201] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.187202] usb usb4: Product: xHCI Host Controller
[    1.187203] usb usb4: Manufacturer: Linux 5.1.1-2-MANJARO xhci-hcd
[    1.187204] usb usb4: SerialNumber: 0000:04:00.0
[    1.200150] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.01
[    1.200154] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.200157] usb usb3: Product: EHCI Host Controller
[    1.200159] usb usb3: Manufacturer: Linux 5.1.1-2-MANJARO ehci_hcd
[    1.200160] usb usb3: SerialNumber: 0000:00:1d.0
[    1.513339] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.516659] usb 2-1: new low-speed USB device number 2 using xhci_hcd
[    1.530011] usb 3-1: new high-speed USB device number 2 using ehci-pci
[    1.660719] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.660726] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.677341] usb 3-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.677348] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.688462] usb 2-1: New USB device found, idVendor=1d57, idProduct=0008, bcdDevice=11.10
[    1.688469] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.688473] usb 2-1: Product: 2.4G Wireless Optical Mouse
[    1.719745] usbcore: registered new interface driver usbhid
[    1.719747] usbhid: USB HID core driver
[    1.943332] usb 1-1.4: new high-speed USB device number 3 using ehci-pci
[    1.959997] usb 3-1.5: new full-speed USB device number 3 using ehci-pci
[    2.042440] usb 1-1.4: New USB device found, idVendor=0408, idProduct=2fb1, bcdDevice= 9.01
[    2.042448] usb 1-1.4: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[    2.042452] usb 1-1.4: Product: Laptop_Integrated_Webcam_2HDM
[    2.042455] usb 1-1.4: Manufacturer: CN07CN2C786641AL0620A00
[    2.061396] usb 3-1.5: New USB device found, idVendor=8086, idProduct=0189, bcdDevice=69.19
[    2.061402] usb 3-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.284917] input: 2.4G Wireless Optical Mouse as /devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb2/2-1/2-1:1.0/0003:1D57:0008.0001/input/input8
[    4.285006] hid-generic 0003:1D57:0008.0001: input,hidraw0: USB HID v1.10 Mouse [2.4G Wireless Optical Mouse] on usb-0000:04:00.0-1/input0
[    4.483994] input: Laptop_Integrated_Webcam_2HDM:  as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input10
[    4.484065] usbcore: registered new interface driver uvcvideo
[    4.546572] usbcore: registered new interface driver btusb
[   48.365509] input: Bluetooth Mouse as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.5/3-1.5:1.0/bluetooth/hci0/hci0:37/0005:05AC:3232.0002/input/input18
$ journalctl -b -p err
-- Logs begin at Mon 2019-03-11 23:03:39 EET, end at Thu 2019-05-23 15:02:29 EEST. --
Μαΐ 23 12:15:28 beams bluetoothd[696]: Can't get HIDP connection info
is there someone who can help me??
Thanks a lot
Try installing and testing the real time kernels. A few people have said they worked better for this issue. Install kernels through Manjaro Settings Manager, and always have at least two kernels installed at all times for safety.
How to switch kernels:
When you reboot if you do not see the grub boot screen press and hold down the ESC, SHIFT or F8 key. This should show the GRUB boot menu if it doesn't appear. As soon as you see the grub boot screen, press the down arrow. Select the "advanced" menu from the choices and press enter. In the next menu you can select the different kernels you have installed to boot from. Select the regular kernel you wish boot into (not the fallback), and then press enter to complete the kernel change.
hello tbg
and thank you very much i try it and it works.
i have now another question is there any problem to work with rt-kernel so that i remove the latest kernel?
so that it boots automatically in the rt kernel
thanks a lot again
You should always have at least 2 kernels installed for safety in case the RT kernel gives you problems (and at least one of those should be an LTS kernel).
You will be able to boot to the RT kernel automatically if you uninstall any kernels newer than it. Be sure to install a backup kernel such as 4.14 and test it out first before uninstalling any kernels.
Please mark your thread solved by applying the check mark below the post that gave you a solution.
(edit) please don't mark hour own post as the solution when someone else gave you the suggestion on how to fix your issue.
thank you for your advice
i will keep this in mind
have a nice day
Here is another method you can use:
I've had the same problem. Switching to a realtime kernel has solved it, thank you. May I ask why a realtime kernel is required? I've tried a couple of Ubuntu distributions with generic kernels, and my bluetooth hardware works just fine with those.
You'd probably have to ask a kernel developer to get an informed answer to that question.
