Hi, I’m new in manjaro. And I was wondering if the Bluetooth swift pair (Connecting automatically without going through the UI) was available on here. I’ve had it on windows before. Not sure what command to post. So didn’t. Sorry if I didn’t write anything basic.
here’s the code you asked
sudo inxi --admin --verbosity=7 --filter --no-host --width ✔
[sudo] password for zareef:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "bn_BD",
LC_IDENTIFICATION = "bn_BD",
LC_MEASUREMENT = "bn_BD",
LC_MONETARY = "bn_BD",
LC_NAME = "bn_BD",
LC_NUMERIC = "en_DE.UTF-8",
LC_PAPER = "bn_BD",
LC_TELEPHONE = "bn_BD",
LC_TIME = "bn_BD",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b2e1aee2-0506-48d8-a067-451af4f80aad rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: HP Stream Laptop 14-cb1XX v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84FB v: 97.20 serial: <filter> UEFI: Insyde v: F.19
date: 07/21/2021
ID-1: BAT0 charge: 28.2 Wh (100.0%) condition: 28.2/28.2 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: N/A status: full
RAM: total: 7.58 GiB used: 2.4 GiB (31.7%)
Array-1: capacity: 16 GiB slots: 1 EC: None max-module-size: 16 GiB
note: est.
Device-1: Bottom type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: N/A width (bits): data: 8 total: 8
manufacturer: SK Hynix part-no: HMA81GS6DJR8N-XN serial: <filter>
Info: model: Intel Celeron N4000 socket: U3E1 bits: 64 type: MCP
arch: Goldmont Plus level: v2 built: 2017 process: Intel 14nm family: 6
model-id: 0x7A (122) stepping: 1 microcode: 0x3C
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1194 min/max: 800/2600 base/boost: 1100/1100 scaling:
driver: intel_cpufreq governor: schedutil volts: 0.7 V ext-clock: 100 MHz
cores: 1: 1194 2: 1194 bogomips: 4378
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts erms est fpu
fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdpid
rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vme x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3185 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Webcam type: USB
driver: uvcvideo bus-ID: 1-6:6 chip-ID: 05c8:022a class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x0696 built: 2015 res: 1366x768 hz: 60
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 600 (GLK
2) direct-render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Message: No PCI device data found.
Device-1: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
bus-ID: 1-2:3 chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: enp0s21f0u2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
driver: N/A bus-ID: 1-3:4 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-5:5 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
Local Storage: total: 29.12 GiB used: 13.64 GiB (46.8%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: HP model: DF4032 size: 29.12 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-1: / raw-size: 28.82 GiB size: 28.2 GiB (97.85%) used: 13.64 GiB (48.4%)
fs: ext4 block-size: 4096 B dev: /dev/mmcblk0p2 maj-min: 179:2 label: N/A
uuid: b2e1aee2-0506-48d8-a067-451af4f80aad
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/mmcblk0p1
maj-min: 179:1 label: N/A uuid: DC15-5C53
ID-1: /dev/mmcblk0boot0 maj-min: 179:8 size: 4 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/mmcblk0boot1 maj-min: 179:16 size: 4 MiB fs: N/A label: N/A
uuid: N/A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-1:2 info: HP Wireless Optical Comfort Mouse
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 03f0:a407 class-ID: 0301
Device-2: 1-2:3 info: Realtek RTL8152 Fast Ethernet Adapter type: Network
driver: r8152 interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 100mA
Device-3: 1-3:4 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
type: WiFi driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-4: 1-5:5 info: Realtek Bluetooth 4.2 Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-5: 1-6:6 info: Cheng Uei Precision Industry (Foxlink) HP Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:022a class-ID: 0e02 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 7 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 56.0 C mobo: N/A
Processes: 184 Uptime: 11m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1176 libs: 318 tools: pamac Shell: Zsh (sudo) v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
thanks.
