Hi all,
Bluetooth has been working only occasionally, and usually does not function at all. I’m not sure what the cause is, but there is a weird error coming up in the systemctl status. Any thoughts?
Output of—
inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter> UEFI-[Legacy]: American Megatrends v: P3.60
date: 07/31/2019
Memory: RAM: total: 46.99 GiB used: 3.36 GiB (7.1%)
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ rev: 2 cache: L2: 3 MiB bogomips: 81470
Speed: 2118 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz): 1: 2118 2: 1415 3: 1390 4: 1543 5: 1462
6: 1447 7: 1378 8: 1547 9: 1619 10: 1385 11: 1389 12: 1540
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Gigabyte driver: nvidia v: 460.56 bus-ID: 09:00.0
chip-ID: 10de:1f02 class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia resolution: 1: 1920x1080~60Hz
2: 1080x1920 s-dpi: 91
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio: Device-1: NVIDIA TU106 High Definition Audio vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 09:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo bus-ID: 5-4.3:4 chip-ID: 0c45:6367
class-ID: 0102 serial: <filter>
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: d000
bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-8:2 chip-ID: 8087:0029 class-ID: e001
Report: ID: hci0 state: up address: <filter>
Logical: Message: No LVM data was found.
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 4.1 TiB used: 1.08 TiB (26.3%)
ID-1: /dev/sda vendor: Gigabyte model: GP-GSTFS30512GTTD size: 476.94 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 13.2 scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WDS100T2B0A-00SM50 size: 931.51 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 20WD scheme: MBR
ID-3: /dev/sdc vendor: Hitachi model: HUA723030ALA640 size: 2.73 TiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A6L0 scheme: GPT
Partition: ID-1: / size: 915.89 GiB used: 225.59 GiB (24.6%) fs: ext4 dev: /dev/sdb1 label: N/A
uuid: 493b19f5-91ea-4c24-b3e3-90bff83c3544
ID-2: /run/media/macji/GEB size: 2.73 TiB used: 424.59 GiB (15.2%) fs: fuseblk dev: /dev/dm-0 mapped: bitlk-2082
label: N/A uuid: N/A
ID-3: /run/media/macji/IMN size: 475.88 GiB used: 456.08 GiB (95.8%) fs: ntfs dev: /dev/sda2 label: IMN
uuid: E4EC4AA7EC4A73B8
ID-4: /run/timeshift/backup raw-size: 931.51 GiB size: <superuser required> used: <superuser required> fs: ext4
dev: /dev/sdb1 label: N/A uuid: 493b19f5-91ea-4c24-b3e3-90bff83c3544
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 549 MiB fs: ntfs label: System Reserved uuid: 8A323BDA323BCA49
ID-2: /dev/sda3 size: 535 MiB fs: ntfs label: N/A uuid: AA6E9BAD6E9B70B5
ID-3: /dev/sdc1 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-4: /dev/sdc2 size: 2.73 TiB fs: bitlocker label: N/A uuid: N/A
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-8:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Hub-6: 5-4:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 5-4.1:3 info: G.SKILL RIPJAWS KM570 RGB G.SKILL RIPJAWS KM570 RGB GAMING KEYBOARD
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 28da:1301 class-ID: 0300
Device-2: 5-4.3:4 info: Microdia USB 2.0 Camera type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Device-3: 5-4.4:5 info: Razer USA Naga 2014 type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0040 class-ID: 0300
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors: System Temperatures: cpu: 36.8 C mobo: N/A gpu: nvidia temp: 49 C
Info: Processes: 329 Uptime: 7m wakeups: 1 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages:
pacman: 1392 Shell: Bash v: 5.1.0 running-in: yakuake inxi: 3.3.03
And of
sudo systemctl status bluetooth
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-03-28 18:59:15 PDT; 53s ago
Docs: man:bluetoothd(8)
Main PID: 1026 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 57728)
Memory: 2.2M
CGroup: /system.slice/bluetooth.service
└─1026 /usr/lib/bluetooth/bluetoothd
Mar 28 18:59:15 PSEUDO systemd[1]: Starting Bluetooth service...
Mar 28 18:59:15 PSEUDO bluetoothd[1026]: Bluetooth daemon 5.56
Mar 28 18:59:15 PSEUDO bluetoothd[1026]: src/main.c:check_config() Unknown group Controller in /etc/bluetooth/main.conf
Mar 28 18:59:15 PSEUDO systemd[1]: Started Bluetooth service.
Mar 28 18:59:15 PSEUDO bluetoothd[1026]: Starting SDP server
Mar 28 18:59:15 PSEUDO bluetoothd[1026]: Bluetooth management interface 1.18 initialized
Mar 28 18:59:28 PSEUDO bluetoothd[1026]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc
Mar 28 18:59:28 PSEUDO bluetoothd[1026]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc
This bolded line below is what seems odd to me, but nothing in the main.conf is leaping out. Any thoughts?
