inxi -Fxxxza ✔
System: Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=633c5b42-5cb3-45ea-9822-32e4832d57af ro quiet apparmor=1
security=apparmor resume=UUID=dcf3897e-8d5f-4feb-961e-bae7d43fea82 udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Apple product: iMac7,1 v: 1.0 serial: <filter> Chassis: type: 13 v: Mac-F4238CC8
serial: <filter>
Mobo: Apple model: Mac-F4238CC8 v: PVT serial: <filter> UEFI: Apple v: IM71.88Z.007A.B03.0803051705 date: 03/05/08
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: Dual Core model: Intel Core2 Duo T7300 bits: 64 type: MCP arch: Core Merom family: 6 model-id: F (15)
stepping: B (11) microcode: BA L2 cache: 4 MiB
flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 7982
Speed: 798 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 798 2: 798
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] RV610/M74 [Mobility Radeon HD 2400 XT] vendor: Apple driver: radeon
v: kernel bus ID: 01:00.0 chip ID: 1002:94c8 class ID: 0300
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus ID: 2-4:2 chip ID: 05ac:8502 class ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9") s-diag: 523mm (20.6")
Monitor-1: LVDS res: 1680x1050 hz: 60 dpi: 99 size: 433x270mm (17.0x10.6") diag: 510mm (20.1")
OpenGL: renderer: AMD RV610 (DRM 2.50.0 / 5.10.15-1-MANJARO LLVM 11.0.1) v: 3.3 Mesa 20.3.4 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 82801H HD Audio vendor: Apple driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:284b
class ID: 0403
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Broadcom BCM4321 802.11a/b/g/n vendor: Apple AirPort Extreme driver: b43-pci-bridge v: N/A modules: ssb
port: 3000 bus ID: 04:00.0 chip ID: 14e4:4328 class ID: 0280
Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2 v: 1.30 port: 2000 bus ID: 05:00.0 chip ID: 11ab:436a
class ID: 0200
IF: ens5 state: down mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
IF-ID-2: wlan0 state: up mac: <filter>
Drives: Local Storage: total: 232.89 GiB used: 13.14 GiB (5.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD2500AAJS-40VWA0 size: 232.89 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1D02 scheme: GPT
Partition: ID-1: / raw size: 80 GiB size: 78.24 GiB (97.81%) used: 11.87 GiB (15.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 4 GiB size: 3.99 GiB (99.80%) used: 312 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 138.88 GiB size: 135.7 GiB (97.71%) used: 1.26 GiB (0.9%) fs: ext4 dev: /dev/sda4
maj-min: 8:4
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2 maj-min: 8:2
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 21.0 C
Fan Speeds (RPM): cpu: 1197
Info: Processes: 171 Uptime: 12m wakeups: 2 Memory: 3.84 GiB used: 1.43 GiB (37.3%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1282 lib: 396 flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.0 running in: yakuake
inxi: 3.3.01
rfkill list all ✔
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
bluetooth ✔
bluetooth = none (no device)
sudo modprobe btusb ✔
[sudo] password for username:
sudo systemctl start bluetooth ✔ 4s
sudo systemctl enable bluetooth ✔
sudo systemctl status bluetooth ✔
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2021-02-25 09:47:13 PST; 19s ago
Docs: man:bluetoothd(8)
Main PID: 2857 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4695)
Memory: 1.8M
CGroup: /system.slice/bluetooth.service
└─2857 /usr/lib/bluetooth/bluetoothd
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Feb 25 09:47:13 username bluetoothd[2857]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Feb 25 09:47:13 username systemd[1]: Started Bluetooth service.
Feb 25 09:47:13 username bluetoothd[2857]: Starting SDP server
Feb 25 09:47:13 username bluetoothd[2857]: Bluetooth management interface 1.18 initialized
sudo mhwd-kernel -li ✔
Currently running: 5.10.15-1-MANJARO (linux510)
* linux510
* linux54
sudo dmesg | grep -Ei 'b43|bcma|brcm|wl|[F]irm|deauth' ✔
[ 0.409058] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 2.054166] b43-pci-bridge 0000:04:00.0: enabling device (0000 -> 0002)
[ 2.164316] b43-pci-bridge 0000:04:00.0: Sonics Silicon Backplane found on PCI device 0000:04:00.0
[ 12.816990] b43-phy0: Broadcom 4321 WLAN found (core revision 12)
[ 12.850750] b43-phy0: Found PHY: Analog 5, Type 4 (N), Revision 2
[ 12.850777] b43-phy0: Found Radio: Manuf 0x17F, ID 0x2055, Revision 4, Version 0
[ 21.050791] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
[ 21.460776] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
[ 113.420758] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
[ 113.830766] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
[ 158.160779] b43-phy0: Loading firmware version 666.2 (2011-02-23 01:15:07)
[ 167.039344] wlan0: authenticate with 78:d2:94:09:04:4b
[ 167.181051] wlan0: send auth to 78:d2:94:09:04:4b (try 1/3)
[ 167.187079] wlan0: authenticated
[ 167.187572] wlan0: associate with 78:d2:94:09:04:4b (try 1/3)
[ 167.190874] wlan0: RX AssocResp from 78:d2:94:09:04:4b (capab=0x1411 status=0 aid=5)
[ 167.191299] wlan0: associated
[ 167.242157] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status" ✔
Model: "Marvell Imac 8,1 Wired Ethernet Adapter"
Driver: "sky2"
Device File: ens5
Link detected: no
Driver Status: sky2 is active
Driver Activation Cmd: "modprobe sky2"
Model: "Apple AirPort Extreme"
Driver: "b43-pci-bridge"
Device File: wlan0
Link detected: yes
Driver Status: ssb is active
Driver Activation Cmd: "modprobe ssb"
sudo nano /usr/lib/modprobe.d/bluetooth-usb.conf
# use "reset=1" as default, since it should be safe for recent devices and
# solves all kind of problems.
options btusb reset=1
bluetoothctl ✔
Agent registered
[bluetooth]# show
No default controller available
Been trying to get this old (~2008) iMac’s bluetooth working. It’s dual WiFi/Bluetooth BCM4321. The WiFi works if I uninstall the driver (network-broadcom-wl) in Hardware Configuration under System Settings but, the bluetooth device doesn’t seem to be found, either way.
If I modprobe btusb and start/enable the bluetooth service I’m then able to add devices from the icon in the task tray but, it just scans and finds no devices. In System Settings > Bluetooth I get “Enable Device” button but, it doesn’t do anything.
Currently, I have manjaro-firmware installed (which came with KDE edition and I think includes b43.) I tried broadcom-wl-dkms without success (WiFi no longer worked; couldn’t connect.) UPDATE: followed the steps again and broadcom-wl-dkms, in fact, works for WiFi but, didn’t help Bluetooth issue; same issues.
bluetoothctl doesn’t seem to find the device if I run power on or list etc.
I’ve been following this post:
Any help would be greatly appreciated! Thanks…
