My computer’s Bluetooth is not working anymore after doing fresh install of Manjaro 20.1 Mikah. I think this is kernel’s problem as I have tried to downgrade my kernel to Linux 5.4 LTS and the Bluetooth started working.
This is my system information
Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=a79e5af0-2b9e-4e85-b065-1d3e3198041e rw quiet apparmor=1
Console: tty 2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: B85M-E45 (MS-7817) v: 2.0 serial: N/A
UEFI: American Megatrends v: 10.9 date: 04/21/2015
Topology: Dual Core model: Intel Core i3-4150 socket: BGA1155 bits: 64
type: MT MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3
microcode: 28 L1 cache: 128 KiB L2 cache: 3072 KiB L3 cache: 3072 KiB
bogomips: 28010
Speed: 3443 MHz min/max: 800/3500 MHz base/boost: 3500/3800 volts: 1.2 V
ext-clock: 100 MHz Core speeds (MHz): 1: 2293 2: 2302 3: 2244 4: 2000
Type: l1tf
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1c82
Display: server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:8c20
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.8.6-1-MANJARO
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 10.61 GiB (0.6%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00WN4A0 family: Blue
size: 931.51 GiB block size: physical: 4096 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 temp: 42 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 89d 7h cycles: 5150
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-00WN4A0 family: Blue
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 temp: 41 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 38d 4h cycles: 4836
ID-1: / raw size: 50.00 GiB size: 48.97 GiB (97.93%) used: 9.26 GiB (18.9%)
fs: ext4 block size: 4096 B dev: /dev/sda8
ID-2: /home raw size: 200.00 GiB size: 195.86 GiB (97.93%)
used: 1.35 GiB (0.7%) fs: ext4 block size: 4096 B dev: /dev/sda9
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Processes: 183 Uptime: 1h 36m Memory: 7.70 GiB used: 2.32 GiB (30.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1203 lib: 341
flatpak: 0 Shell: Bash (sudo) v: 5.0.18 running in: konsole inxi: 3.1.05
And this is the output of lsusb
Bus 003 Device 002: ID 8087:8000 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:8008 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 004: ID 046d:c07e Logitech, Inc. G402 Gaming Mouse
Bus 002 Device 003: ID 1a2c:2c27 China Resource Semico Co., Ltd USB Keyboard
Bus 002 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I am fairly new in Linux world, may be I am doing something wrong.
