Hello i’m a noobie to linux i just installed a fresh version of manjaro xfce 21.1.6,everything seems to work fine my wifi adaptor is working with no problems but my bluetooth is not working
when i on bluetooth on the side bar it goes away and when i take bluetooth manager it crashes
i have updated after installing and i think i have the drivers,rfkill says no block
i dont know any commands to write on terminal sorry ;(
Please tell us some more about your system:
inxi --admin --verbosity=7 --filter --width
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=228e5ef7-a81f-46f2-983f-022938cf2c15 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: INTEL model: H61 serial: <filter>
BIOS: American Megatrends v: 4.6.5 date: 03/05/2019
RAM: total: 1.76 GiB used: 1.34 GiB (76.4%)
Info: Dual Core model: Intel Pentium G2010 bits: 64 type: MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 3 MiB bogomips: 11178
Speed: 1597 MHz min/max: 1600/2800 MHz Core speeds (MHz): 1: 1597 2: 1596
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est
flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme
xsave xsaveopt xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: VGA-1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1)
v: 4.2 Mesa 21.2.3 compat-v: 3.0 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 v: kernel
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 1-1.2:4 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s26u1u2 state: up mac: <filter>
driver: btusb v: 0.8 bus-ID: 2-1.4:5 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 313 GiB used: 7.58 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3320311CS
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: SC13 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Force
size: 14.91 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.27 scheme: MBR
ID-1: / raw-size: 298.09 GiB size: 292.35 GiB (98.07%) used: 7.58 GiB (2.6%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 228e5ef7-a81f-46f2-983f-022938cf2c15
ID-1: /dev/sdb1 maj-min: 8:17 size: 2.93 GiB fs: iso9660
ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 922B-3DAB
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-2: 1-1.2:4 info: Ralink MT7601U Wireless Adapter type: Network
driver: mt7601u interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 160mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.1:3 info: SanDisk Cruzer Force type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:557d class-ID: 0806 serial: <filter>
Device-2: 2-1.2:4 info: CASUE USB Keyboard type: Keyboard,HID
power: 100mA chip-ID: 2a7a:9a18 class-ID: 0300
Device-3: 2-1.4:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
System Temperatures: cpu: 52.0 C mobo: 27.8 C
Processes: 160 Uptime: 7m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1048 lib: 305 flatpak: 0 Shell: Bash
v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.08```
if you need more information please leave the command it will be very helpful
Try
rfkill unblock bluetooth
The following may be helpful as well:
after typing it goes to the next line
i tried rfkill list all and it didnt have any softblock or hard block
i dont think its this problem
Ok. Thought the above meant that it is blocked.
i have tried different linux mint versions like xfce mate it didnt work,i thought switching to new os might fix it,apparently not.it worked pefectly while using windows
