Hi all,
I’ve just bought a bluetooth adapter for my pc: https://plugable.com/products/usb-bt4le/
I’ve tried everything I’ve found in this forum and in the archived one without result including install bcm43142a0-firmware from the AUR instead of manjaro-firmware, change the name of the driver, test all services…
I send you all the system reports that I’ve get.
Thanks all in advance…
**inxi -Fazy**
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/vmlinuz-5.8-x86_64
root=UUID=35e21678-adbc-4487-94d9-48922ff17966 rw quiet apparmor=1
Desktop: i3 4.18.2 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: M4N78 PRO v: Rev 1.xx serial: <filter>
BIOS: American Megatrends v: 1009 date: 08/06/2009
Topology: Dual Core model: AMD Athlon 7550 bits: 64 type: MCP arch: K10
family: 10 (16) model-id: 2 stepping: 3 microcode: 1000095
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 10004
Speed: 2500 MHz min/max: 1250/2500 MHz Core speeds (MHz): 1: 2500 2: 2500
Type: spec_store_bypass status: Not affected
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA GF119 [GeForce GT 610] vendor: ASUSTeK driver: nvidia
v: 390.132 alternate: nouveau,nvidia_drm bus ID: 02:00.0 chip ID: 10de:104a
Device-2: Microdia Sonix USB 2.0 Camera type: USB driver: uvcvideo
bus ID: 1-4:5 chip ID: 0c45:62c0
Display: x11 server: X.Org 1.20.9 compositor: picom v: git-2c9e7
driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 89 s-size: 411x263mm (16.2x10.4")
s-diag: 488mm (19.2")
Monitor-1: VGA-0 res: 1440x900 hz: 75 dpi: 89 size: 410x260mm (16.1x10.2")
diag: 485mm (19.1")
OpenGL: renderer: GeForce GT 610/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132
direct render: Yes
Device-1: NVIDIA MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:07.0
chip ID: 10de:0774
Device-2: VIA ICE1712 [Envy24] PCI Multi-Channel I/O
vendor: TERRATEC Electronic EWX 24/96 driver: snd_ice1712 v: kernel
bus ID: 01:06.0 chip ID: 1412:1712
Device-3: Creative Labs CA0106/CA0111 [SB Live!/Audigy/X-Fi Series]
driver: snd_ca0106 v: kernel bus ID: 01:07.0 chip ID: 1102:0007
Device-4: NVIDIA GF119 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 02:00.1 chip ID: 10de:0e08
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: NVIDIA MCP77 Ethernet vendor: ASUSTeK driver: forcedeth v: kernel
port: b880 bus ID: 00:0a.0 chip ID: 10de:0760
IF: enp0s10 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 213.44 GiB (22.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00BN5A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw size: 29.30 GiB size: 28.71 GiB (98.00%) used: 18.97 GiB (66.1%)
fs: ext4 dev: /dev/sda9
ID-2: /boot raw size: 250.4 MiB size: 242.5 MiB (96.84%)
used: 55.6 MiB (22.9%) fs: ext2 dev: /dev/sda10
ID-3: /home raw size: 247.07 GiB size: 243.07 GiB (98.38%)
used: 184.93 GiB (76.1%) fs: ext4 dev: /dev/sda6
ID-4: /var raw size: 14.65 GiB size: 14.35 GiB (98.00%)
used: 9.48 GiB (66.0%) fs: ext4 dev: /dev/sda8
ID-1: swap-1 type: partition size: 3.88 GiB used: 14.1 MiB (0.4%)
priority: -2 dev: /dev/sda7
Message: No sensors data was found. Is sensors configured?
Processes: 227 Uptime: 9h 00m Memory: 7.77 GiB used: 4.24 GiB (54.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1693 lib: 360 Shell: Zsh v: 5.8 running in: xfce4-terminal
inxi: 3.1.05
**[bluetooth]# devices**
No default controller available
**rfkill list all**
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
**sudo dmesg | grep -Ei 'blue|firm'**
[sudo] password for ______:
[ 74.368353] audit: type=1130 audit(1602744142.032:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 103.902531] audit: type=1131 audit(1602744171.569:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32937.972702] Bluetooth: Core ver 2.22
[32937.973550] Bluetooth: HCI device and connection manager initialized
[32937.973556] Bluetooth: HCI socket layer initialized
[32937.973559] Bluetooth: L2CAP socket layer initialized
[32937.973567] Bluetooth: SCO socket layer initialized
[32938.134777] Bluetooth: hci0: BCM: chip id 63
[32938.137771] Bluetooth: hci0: BCM: features 0x07
[32938.155779] Bluetooth: hci0: BCM20702A
[32938.155783] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[32938.214259] Bluetooth: hci0: BCM20702A1 'brcm/BCM20702A1-0a5c-21e8.hcd' Patch
[32938.268417] audit: type=1130 audit(1602777005.938:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32938.345206] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[32938.345209] Bluetooth: BNEP filters: protocol multicast
[32938.345215] Bluetooth: BNEP socket layer initialized
[32938.359805] audit: type=1130 audit(1602777006.031:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth-mesh comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[32939.279779] Bluetooth: hci0: Broadcom Bluetooth Device
[32939.279787] Bluetooth: hci0: BCM20702A1 (001.002.014) build 1338
**sudo systemctl status |grep blue**
│ ├─52211 grep --color=tty -d skip blue
├─bluetooth.service
│ └─52060 /usr/lib/bluetooth/bluetoothd
├─bluetooth-mesh.service
│ └─52059 /usr/lib/bluetooth/bluetooth-meshd
**sudo systemctl status dbus-org.bluez.service**
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2020-10-15 17:50:05 CEST; 7min ago
Docs: man:bluetoothd(8)
Main PID: 52060 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9456)
Memory: 2.1M
CGroup: /system.slice/bluetooth.service
oct 15 17:50:05 ________ bluetoothd[52060]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in gro>
oct 15 17:50:05 _______ bluetoothd[52060]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in gro>
oct 15 17:50:05 _______ bluetoothd[52060]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “>
oct 15 17:50:05 _______ bluetoothd[52060]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout”>
oct 15 17:50:05 _______ bluetoothd[52060]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group >
oct 15 17:50:05 _______systemd[1]: Started Bluetooth service.
oct 15 17:50:05 _______ bluetoothd[52060]: Starting SDP server
oct 15 17:50:06 _______ bluetoothd[52060]: Bluetooth management interface 1.17 initialized
oct 15 17:50:07 _______ bluetoothd[52060]: Failed to read info for index 0: Invalid Index (0x11)
oct 15 17:50:07 _______ bluetoothd[52060]: src/adapter.c:index_removed() Ignoring index removal for a non-existent adapter
**journalctl -g blue**
-- Logs begin at Wed 2020-04-29 21:05:01 CEST, end at Thu 2020-10-15 18:00:26 CEST. --
abr 29 22:24:00 Erathor pipewire[2239]: [E][000005451.000834][bluez5-dbus.c:2003 get_managed_objects_reply()] GetManagedObjects() failed: o>
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
may 07 17:26:52 Erathor NetworkManager[618]: <info> [1588865212.0646] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.22.1>
may 07 17:29:58 Erathor dbus-daemon[617]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested>
may 07 17:29:58 Erathor systemd[1]: Condition check resulted in Bluetooth service being skipped.
may 07 17:30:23 Erathor dbus-daemon[617]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
-- Reboot --
may 08 13:03:42 Erathor NetworkManager[619]: <info> [1588935822.6609] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.22.1>
may 08 16:52:56 Erathor dbus-daemon[618]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested>
may 08 16:52:56 Erathor systemd[1]: Condition check resulted in Bluetooth service being skipped.
may 08 16:53:21 Erathor dbus-daemon[618]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
-- Reboot --
may 08 20:34:12 Erathor NetworkManager[657]: <info> [1588962852.1741] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.22.1>
-- Reboot --
may 08 20:50:58 Erathor NetworkManager[612]: <info> [1588963858.4949] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.22.1>
may 08 22:03:51 Erathor kernel: Bluetooth: Core ver 2.22
may 08 22:03:51 Erathor kernel: Bluetooth: HCI device and connection manager initialized
may 08 22:03:51 Erathor kernel: Bluetooth: HCI socket layer initialized
may 08 22:03:51 Erathor kernel: Bluetooth: L2CAP socket layer initialized
lines 1-43
I’ve left for the end the two reports with visible errors: bluez.service seems to fail in systemd and journalctl.
Best regards.
