some information might help
Kernel: 5.15.5-1-rt22-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
root=UUID=391c1451-ae80-4f57-a99c-d7a5b05f6e57 rw quiet apparmor=1
security=apparmor resume=UUID=15310bec-d4cd-42ad-b906-e44a97d54ccd
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Latitude E6430 v: 01
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Dell model: N/A serial: <superuser required> BIOS: Dell v: A12
date: 05/20/2013
ID-1: BAT0 charge: 10.3 Wh (42.7%) condition: 24.1/60.0 Wh (40.2%)
volts: 12.5 min: 11.1 model: SMP DELL 5G67C15 type: Li-ion serial: <filter>
status: Charging
RAM: total: 9.61 GiB used: 3.34 GiB (34.7%)
RAM Report:
Info: model: Intel Core i7-3520M bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1825 high: 1996 min/max: 1200/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1712 2: 1670 3: 1996
4: 1925 bogomips: 23123
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GF108GLM [NVS 5200M] driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:0dfc class-ID: 0300
Device-3: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:4 chip-ID: 0c45:648b class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: intel display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 112
size: 310x180mm (12.2x7.1") diag: 358mm (14.1")
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-1-rt22-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Broadcom BCM43228 802.11a/b/g/n vendor: Dell driver: wl
v: kernel modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:4359 class-ID: 0280
driver: btusb v: 0.8 bus-ID: 1-1.2:3 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 3 state: up address: N/A
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 238.47 GiB used: 36.06 GiB (15.1%)
ID-1: /dev/sda maj-min: 8:0 model: SSD 256GB size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 1A0 scheme: MBR
Optical-1: /dev/sr0 vendor: PLDS model: DVD+-RW DU-8A5HH rev: SD11
dev-links: cdrom
ID-1: / raw-size: 229.67 GiB size: 225 GiB (97.97%) used: 36.06 GiB (16.0%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 391c1451-ae80-4f57-a99c-d7a5b05f6e57
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 15310bec-d4cd-42ad-b906-e44a97d54ccd
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-2: 1-1.5:4 info: Microdia Integrated Webcam type: Video
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 58.0 C mobo: 47.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 281 Uptime: 21m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1334 pacman: 1310 lib: 339 flatpak: 0
snap: 24 Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
rfkill
[hayaz@haya-pc ~]$ rfkill list
1: dell-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Status
[hayaz@haya-pc ~]$ sudo systemctl status bluetooth
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2022-01-02 12:47:17 PKT; 12s ago
Docs: man:bluetoothd(8)
Main PID: 6211 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 11787)
CPU: 22ms
CGroup: /system.slice/bluetooth.service
└─6211 /usr/lib/bluetooth/bluetoothd
Jan 02 12:47:17 haya-pc systemd[1]: Started Bluetooth service.
Jan 02 12:47:17 haya-pc bluetoothd[6211]: Starting SDP server
Jan 02 12:47:17 haya-pc bluetoothd[6211]: Bluetooth management interface 1.21 initialized
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 00001133-0000-1000-8000-00805f9b34f>
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 00001132-0000-1000-8000-00805f9b34f>
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 0000112f-0000-1000-8000-00805f9b34f>
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 00001104-0000-1000-8000-00805f9b34f>
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 00001106-0000-1000-8000-00805f9b34f>
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 00001105-0000-1000-8000-00805f9b34f>
Jan 02 12:47:17 haya-pc bluetoothd[6211]: src/profile.c:register_profile() :1.55 tried to register 00005005-0000-1000-8000-0002ee00000>
Blueman
[hayaz@haya-pc ~]$ blueman-manager
blueman-manager 12.48.16 ERROR Manager:137 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 12.48.16 ERROR Manager:141 on_dbus_name_appeared: No adapter(s) found, exiting
Qi bluez
[hayaz@haya-pc ~]$ pacman -Qi bluez
Version : 5.62-1
Description : Daemons for the bluetooth protocol stack
Architecture : x86_64
URL : http://www.bluez.org/
Licenses : GPL2
Groups : None
Provides : None
Depends On : libical dbus glib2 alsa-lib json-c
Optional Deps : None
Required By : blueman bluez-qt bluez-tools gnome-bluetooth pulseaudio-bluetooth
Optional For : networkmanager
Conflicts With : obexd-client obexd-server
Replaces : None
Installed Size : 2.68 MiB
Packager : Andreas Radke <andyrtr@archlinux.org>
Build Date : Thu 14 Oct 2021 12:21:34 AM PKT
Install Date : Sun 02 Jan 2022 10:48:11 AM PKT
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
Qi bluedevil
[hayaz@haya-pc ~]$ pacman -Qi bluedevil
Version : 1:5.23.4-1
Description : Integrate the Bluetooth technology within KDE workspace and applications
URL : https://kde.org/plasma-desktop/
Licenses : GPL2
Groups : plasma
Provides : None
Depends On : bluez-qt kdeclarative
Optional Deps : pulseaudio-bluetooth: to connect to A2DP profile [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 1547.14 KiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Tue 30 Nov 2021 09:28:05 PM PKT
Install Date : Sun 02 Jan 2022 10:54:33 AM PKT
Install Reason : Explicitly installed
Install Script : No
lsusb
[hayaz@haya-pc ~]$ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0c45:648b Microdia Integrated Webcam
Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub```
