Bluetooth mouse loses connection after some time
Hello,
this is an issue I only have with Manjaro. When I connect my bluetooth mouse to the computer, everting seems fine but after 30 seconds or so it disconnects and the cursor stucks for about 3 seconds. Then it reconnects and keeps working just fine. But this happens every time I wake up my computer or my mouse, so it gets really annoying after some time.
Interestingly this problem does occur only on the following distros:
Manjaro KDE
Manjaro Gnome
I also tried these following distros, and the issue did not occur:
Ubuntu 19.10
openSuse Leap 15.1 KDE
ZorinOS
If I have to post more information, I am happy to do so.
Thank you for your help!
$ inxi -Fx
System:    Host: ZenDriver Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: KDE Plasma 5.17.4
           Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: UX331UN v: 1.0 serial: <root required>
           Mobo: ASUSTeK model: UX331UN v: 1.0 serial: <root required> UEFI: American Megatrends v: UX331UN.308
           date: 04/17/2019
Battery:   ID-1: BAT0 charge: 39.2 Wh condition: 39.4/50.1 Wh (79%) model: ASUSTeK ASUS Battery status: Charging
CPU:       Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
           Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 799 5: 800 6: 793 7: 800 8: 782
Graphics:  Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia v: 440.44 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.6 driver: modesetting tty: N/A
           OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.6 Mesa 19.3.1 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.4.6-2-MANJARO
Network:   Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: e000 bus ID: 03:00.0
           IF: wlp3s0 state: up mac: 40:a3:cc:22:d7:a1
           IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: 00:50:56:c0:00:01
           IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: 00:50:56:c0:00:08
Drives:    Local Storage: total: 296.32 GiB used: 41.88 GiB (14.1%)
           ID-1: /dev/sda vendor: Micron model: 1100 MTFDDAV256TBN size: 238.47 GiB
           ID-2: /dev/sdb type: USB vendor: SanDisk model: Ultra Fit size: 57.84 GiB
Partition: ID-1: / size: 48.97 GiB used: 41.85 GiB (85.5%) fs: ext4 dev: /dev/sda5
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda7
Sensors:   System Temperatures: cpu: 61.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 3400
Info:      Processes: 258 Uptime: 9m Memory: 7.70 GiB used: 1.15 GiB (14.9%) Init: systemd Compilers: gcc: 9.2.0 Shell: bash
           v: 5.0.11 inxi: 3.0.37
Hello,
here are the logs that apprear just when the bluetooth device disconnects:
Dienstag, 21. Januar 2020 19:59:39 CET	systemd	systemd-hostnamed.service: Succeeded.
Dienstag, 21. Januar 2020 19:59:39 CET	audit	SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dienstag, 21. Januar 2020 19:59:39 CET	kernel	audit: type=1131 audit(1579633179.740:146): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dienstag, 21. Januar 2020 19:59:40 CET	plasmashell	file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:36: TypeError: Cannot read property 'devices' of undefined
Dienstag, 21. Januar 2020 19:59:40 CET	org_kde_powerdevil	QObject::disconnect: Unexpected null parameter
Dienstag, 21. Januar 2020 19:59:40 CET	org_kde_powerdevil	powerdevil: Battery with UDI "/org/freedesktop/UPower/devices/mouse_dev_40_06_A0_68_7B_29" has been removed
