Bluetooth Mouse Lag
Hi guys,
I'm enjoying my (slow but getting there) switch to Manjaro.
I've been using my bluetooth mouse (MX Master 2S) for a couple of weeks, recently it has started to be very laggy. I have tried removing and re adding the mouse, as well as using multiple channels on the mouse. I have a dual boot with Win 10 and it works fine there.
I've been searching the forum looking to see if anyone else has had this issue but couldn't find anything, I do apologise if I have missed a post.
Let me know what information I'm missing to help
Thanks in advance
Kind regards
E
Test different kernels.
sudo echo "options iwlwifi bt_coex_active=0" >> /etc/modprobe.d/btlag.conf
and reboot.
reference:
edit: it probably would of been a better idea to have you post your inxi -Fxxxza output before suggesting a fix to a driver im unsure your even using. :man_facepalming:
Thanks so much
I have tried using Kernel 51, 52, 419, and 414 with the same result
My inxi output is below
$ inxi -Fxxxza
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:2526
IF: wlp2s0 state: up mac:
give the one-liner i posted a try and reboot.
I tried
and restarted to no success, when I tried
I get permission denied
sudo nano /etc/modprobe.d/btlag.conf
copy/paste this line
ctrl+o to save, ctrl+x to exit
As a temporary troubleshooting test, disable the tlp:
sudo sytemctl mask tlp
Reboot.
If there is no improvement then re-enable tlp.
To enable tlp again:
sudo sytemctl unmask tlp
sudo sytemctl enable tlp
Then restart.
Unfortunately those two didn't work
Thanks for the help
the arch wiki on bluetooth points here for input lag
https://wiki.archlinux.org/index.php/Mouse_polling_rate
You could also try this when your mouse starts to lag.
Issue this command:
nmcli networking off; sudo rmmod btusb; sleep 2; sudo modprobe btusb; nmcli networking on
I was having lag on some kernels a while back and I used a little more complex script whenever my wireless logitech trackball started lagging. Of course mine's not bluetooth but perhaps something similar would work for you.
I installed and ran evhz and my mouse is sitting at a "smooth" 20hz :joy:
Am I being stupid to ask, how would I fix this?
post
hwinfo --mouse
  [Created at input.249]
  Unique ID: AH6Q.wJ5XlLsA+Z6
  Hardware Class: mouse
  Model: "MX Master 2S Mouse"
  Vendor: 0x046d
  Device: 0xb019 "MX Master 2S Mouse"
  Compatible to: int 0x0210 0x0048
  Device File: /dev/input/mice (/dev/input/mouse2)
  Device Files: /dev/input/mice, /dev/input/mouse2, /dev/input/event23
  Device Number: char 13:63 (char 13:34)
  Driver Info #0:
    Buttons: 8
    Wheels: 4
    XFree86 Protocol: explorerps/2
    GPM Protocol: exps2
  Config Status: cfg=new, avail=yes, need=no, active=unknown
btw, your not the only one
https://bbs.archlinux.org/viewtopic.php?id=248185
Should've done my research before getting this mouse
open a terminal and run these 4 commands
su
echo 0 > /sys/kernel/debug/bluetooth/hci0/conn_latency
echo 6 > /sys/kernel/debug/bluetooth/hci0/conn_min_interval
echo 7 > /sys/kernel/debug/bluetooth/hci0/conn_max_interval
  • reconnect mouse
  • does the latency improve?
EDIT: as an updated solution, here's how to make this persistent through reboots
bash: /sys/kernel/debug/bluetooth/hci0/conn_latency: Permission denied
My bad I accidentally a command. I did the 4 and it didn't seem to change anything, do I need to set a min and max interval?
try reconnecting the mouse now, maybe a reconnect is needed to notice a change.
my reference for those is here:
https://bbs.archlinux.org/viewtopic.php?pid=1857256#p1857256
