Bluetooth mouse - disconnect loop
Hi,
I’ve recently encountering a problem with my Logitech MX Master 2 bluetooth mouse.
This mouse worked flawlessly for years with my system using the bluetooth connection, but now, after probably some updates, I’m having problems.
Basically when I turn on my laptop the mouse starts connecting and immediately disconnecting in an infinite loop.
If I turn on the laptop (with the mouse off), this happens as soon as I turn on the mouse.
The only solution is to remove the device and re-pair it.
After this procedure the device works perfectly until I restart the laptop.
I already tried this solution:
Bluetooth mouse - ArchWiki).-,Thinkpad%20Bluetooth%20Laser%20Mouse%20problems,-If%20you%20are
Without success.
Can you please help me diagnose and solve the problem?
Thank you
