Hello,
I am a beginner when it comes to Linux in general and Manjaro in particular. Therefore, I am not sure if this is the right channel for my question. Should this topic be posted under “Kernel,” “Audio,” or “Third-Party Software”? Unfortunately, I have no idea.
In advance:
I am happy to provide all the necessary information to solve the problem. However, I do not know exactly what you need. Please feel free to ask!
My problem is as follows:
With kernel 6.18.x, my PC occasionally freezes to the point where only a restart helps. Therefore, I am now testing the LTS kernel 6.12.91-1, which has been running stably so far. However, with 6.18, Bluetooth worked in such a way that my headsets were detected—this is not the case with 6.12. Can you give me any tips on this?
I would use kernel 6.18 if it ran stably. Otherwise, I will stick with the stable 6.12 with Bluetooth support.
Thank you in advance for your help!
inxi -zv8
Kernel: 6.12.91-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
root=UUID=b6a3c10b-9279-4d47-9bbd-3923dc3e5bc9 rw quiet splash
udev.log_priority=3 lockdown=confidentiality
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
Type: Desktop System: CSL GmbH product: Silent v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: B850M MAX GAMING WIFI v: Rev 1.xx
serial: <superuser required> part-nu: 88504 uuid: <superuser required>
Firmware: UEFI vendor: American Megatrends v: 1644 date: 03/10/2026
System RAM: total: 32 GiB available: 30.99 GiB used: 5.47 GiB (17.7%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KF556C40-16 serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 9900X bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 960 KiB desc: d-12x48 KiB; i-12x32 KiB L2: 12 MiB
desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3646 min/max: 600/5658 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3646 2: 3646 3: 3646
4: 3646 5: 3646 6: 3646 7: 3646 8: 3646 9: 3646 10: 3646 11: 3646 12: 3646
13: 3646 14: 3646 15: 3646 16: 3646 17: 3646 18: 3646 19: 3646 20: 3646
21: 3646 22: 3646 23: 3646 24: 3646 bogomips: 210884
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-2,DP-3
empty: DP-1,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 7680x2160 display-ID: 0
Monitor-1: DP-2 pos: right model: BenQ EL2870U serial: <filter>
built: 2021 res: mode: 3840x2160 hz: 60 scale: 165% (1.65) to: 2327x1309
dpi: 157 gamma: 1.2 chroma: red: x: 0.635 y: 0.341 green: x: 0.310
y: 0.635 blue: x: 0.157 y: 0.059 white: x: 0.314 y: 0.329
size: 621x341mm (24.45x13.43") diag: 708mm (27.9") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
1440x480, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unhandled CEA mode 93 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95
Monitor-2: DP-3 pos: primary,left model: BenQ EL2870U serial: <filter>
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 9070 (radeonsi gfx1201 ACO DRM
3.61 6.12.91-1-MANJARO) device-ID: 1002:7550 memory: 15.62 GiB unified: no
display-ID: :1.0
API: Vulkan v: 1.4.350 layers: 6 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 (RADV GFX1201) driver: mesa radv v: 26.1.1-arch1.2
device-ID: 1002:7550 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.91-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Realtek RTL8851BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8851be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0 chip-ID: 10ec:b851
class-ID: 0280
IF: wlp10s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 13d3:3600
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 1.82 TiB used: 142.3 GiB (7.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QJXD7 temp: 46.9 C
scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 142.29 GiB (7.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: b6a3c10b-9279-4d47-9bbd-3923dc3e5bc9
used: 336 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: E422-2896
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: f6f39c07-8d60-46e8-a613-1d0bf2bb9f04
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-7:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Hub-2: 1-8:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-8.2:4 info: USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 30fa:0300 class-ID: 0301
Device-2: 1-8.3:5 info: China Resource Semico Keyboard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1a2c:2124 class-ID: 0300
Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: IMC Networks Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 13d3:3600 class-ID: e001 serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 49.1 C mobo: 40.8 C gpu: amdgpu temp: 55.0 C
mem: 58.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1630 libs: 427 tools: pamac pm: flatpak pkgs: 0
1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
2: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
3: https://mirror.easyname.at/manjaro/stable/$repo/$arch
4: https://muug.ca/mirror/manjaro/stable/$repo/$arch
5: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
6: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
7: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 451
1: cpu: 3.9% command: steamwebhelper pid: 5747 mem: 215.0 MiB (0.6%)
2: cpu: 2.5% command: steamwebhelper pid: 5866 mem: 584.5 MiB (1.8%)
3: cpu: 1.2% command: firefox pid: 16679 mem: 869.1 MiB (2.7%)
4: cpu: 1.2% command: plasma-systemmonitor pid: 29800
mem: 351.7 MiB (1.1%)
5: cpu: 1.0% command: firefox pid: 19365 mem: 581.5 MiB (1.8%)
Memory top: 5 of 451
1: mem: 869.1 MiB (2.7%) command: firefox pid: 16679 cpu: 1.2%
2: mem: 584.5 MiB (1.8%) command: steamwebhelper pid: 5866 cpu: 2.5%
3: mem: 581.5 MiB (1.8%) command: firefox pid: 19365 cpu: 1.0%
4: mem: 556.4 MiB (1.7%) command: firefox pid: 30237 cpu: 0.2%
5: mem: 533.4 MiB (1.6%) command: plasmashell pid: 1525 cpu: 0.0%
Processes: 451 Power: uptime: 14h 30m states: freeze,mem suspend: deep
avail: s2idle wakeups: 0 hibernate: disabled image: 12.34 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 260 default: graphical tool: systemctl
Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Bash v: 5.3.9 default: Zsh
v: 5.9 running-in: konsole inxi: 3.3.40
