Bluetooth headset connects to bluetooth audio transmitter adapter, but no sound
My bluetooth headset connects successfully to my bluetooth audio transmitter adapter and is listed as audio device in the pulseaudio list as UACDemoV1.0 Analog Stereo. However, there is no sound output.
On windows 10, I have no problems by using this dongle and this headset
My bluetooth audio transmitter adapter: Jieli Technology PC-T7.
My headset: Epos H3 Hybrid
I have installed pulseaudio-modules-bt and libldac
Here is the output of pactl list
Modul #0
	Argument:
	Nutzungszähler: k. A.
	Eigenschaften:
		module.author = "Lennart Poettering"
		module.description = "Automatically restore the volume/mute state of devices"
		module.version = "15.0"
Modul #1
	Argument:
	Eigenschaften:
		module.description = "Automatically restore the volume/mute/device state of streams"
Modul #2
	Argument:
	Eigenschaften:
		module.description = "Automatically restore profile of cards"
Modul #3
	Argument:
	Eigenschaften:
		module.description = "Augment the property sets of streams with additional static information"
Modul #4
	Argument:
	Eigenschaften:
		module.author = "David Henningsson"
		module.description = "Switches ports and profiles when devices are plugged/unplugged"
Modul #5
	Argument:
	Eigenschaften:
		module.description = "Detect available audio hardware and load matching drivers"
Modul #6
	Argument: device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Nutzungszähler: 0
	Eigenschaften:
		module.description = "ALSA Card"
Modul #7
	Argument: device_id="2" name="usb-046d_0825_B975BB10-02" card_name="alsa_card.usb-046d_0825_B975BB10-02" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Nutzungszähler: 0
	Eigenschaften:
Modul #8
	Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Nutzungszähler: 0
	Eigenschaften:
Modul #9
	Argument: channels=2
	Eigenschaften:
		module.description = "Adds JACK sink/source ports when JACK is started"
Modul #10
	Argument:
	Eigenschaften:
		module.author = "Frédéric Dalleau, Pali Rohár"
		module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Modul #11
	Argument: a2dp_config="ldac_eqmid=hq ldac_fmt=f32"
	Eigenschaften:
		module.author = "João Paulo Rechi Vita"
		module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Modul #12
	Eigenschaften:
		module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Modul #13
	Argument:
	Eigenschaften:
		module.author = "Michael Terry"
		module.description = "When a sink/source is added, switch to it or conditionally switch to it"
Modul #14
	Argument:
	Eigenschaften:
		module.author = "Tanu Kaskinen"
		module.description = "D-Bus interface"
Modul #15
	Argument:
	Eigenschaften:
		module.description = "Native protocol (UNIX sockets)"
Modul #16
	Argument:
	Eigenschaften:
		module.author = "Sylvain Baubeau"
		module.description = "GSettings Adapter"
Modul #17
	Argument:
	Eigenschaften:
		module.description = "Automatically restore the default sink and source"
Modul #18
	Argument:
	Eigenschaften:
		module.author = "Colin Guthrie"
		module.description = "Hält stets ein Ziel geladen, selbst wenn dies ein Null-Ziel ist"
Modul #19
	Argument:
	Eigenschaften:
		module.description = "Automatically set device of streams based on intended roles of devices"
Modul #20
	Argument:
	Eigenschaften:
		module.description = "When a sink/source is idle for too long, suspend it"
Modul #21
	Argument:
	Eigenschaften:
		module.description = "Create a client for each ConsoleKit session of this user"
Modul #22
	Argument:
	Eigenschaften:
		module.description = "Create a client for each login session of this user"
Modul #23
	Argument:
	Eigenschaften:
		module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Modul #24
	Argument:
	Eigenschaften:
		module.description = "Mute & cork streams with certain roles while others exist"
Modul #25
	Argument:
	Eigenschaften:
		module.description = "Detect when various filters are desirable"
Modul #26
	Argument:
	Eigenschaften:
		module.description = "Load filter sinks automatically when needed"
Modul #29
	Argument: device_id="3" name="usb-Jieli_Technology_UACDemoV1.0_4542BF943C234C53-01" card_name="alsa_card.usb-Jieli_Technology_UACDemoV1.0_4542BF943C234C53-01" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
	Nutzungszähler: 0
	Eigenschaften:
Ziel #0
	Status: SUSPENDED
	Beschreibung: GP107GL High Definition Audio Controller Digital Stereo (HDMI 2)
	Treiber: module-alsa-card.c
	Abtastwert-Angabe: s16le 2ch 44100Hz
	Kanalzuordnung: front-left,front-right
	Besitzer-Modul: 6
	Stumm: nein
	Lautstärke: front-left: 38010 /  58% / -14,19 dB,   front-right: 38010 /  58% / -14,19 dB
	        Verteilung 0,00
	Basis-Lautstärke: 65536 / 100% / 0,00 dB
	Quellen-Monitor: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor
	Latenz: 0 usec, eingestellt 0 usec
	Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
	Eigenschaften:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "HDMI 1"
		alsa.id = "HDMI 1"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "7"
		alsa.card = "1"
		alsa.card_name = "HDA NVidia"
		alsa.long_card_name = "HDA NVidia at 0xdf080000 irq 17"
		device.bus_path = "pci-0000:01:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
		device.bus = "pci"
		device.vendor.id = "10de"
		device.vendor.name = "NVIDIA Corporation"
		device.product.id = "0fb9"
		device.product.name = "GP107GL High Definition Audio Controller"
		device.string = "hdmi:1,1"
		device.buffering.buffer_size = "352768"
		device.buffering.fragment_size = "176384"
		device.access_mode = "mmap+timer"
		device.profile.name = "hdmi-stereo-extra1"
		device.profile.description = "Digital Stereo (HDMI 2)"
		device.description = "GP107GL High Definition Audio Controller Digital Stereo (HDMI 2)"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Ports:
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, available)
	Aktiver Port: hdmi-output-1
	Formate:
		pcm
Ziel #1
	Status: SUSPENDED
	Beschreibung: Internes Audio Digital Stereo (IEC958)
	Besitzer-Modul: 8
	Stumm: nein
	Lautstärke: front-left: 68157 / 104% / 1,02 dB,   front-right: 68157 / 104% / 1,02 dB
	        Verteilung 0,00
	Quellen-Monitor: alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor
	Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY SET_FORMATS
	Eigenschaften:
		device.api = "alsa"
		alsa.name = "ALC1220 Digital"
		alsa.id = "ALC1220 Digital"
		alsa.device = "1"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xdf240000 irq 137"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "a2f0"
		device.product.name = "200 Series PCH HD Audio"
		device.string = "iec958:0"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.profile.name = "iec958-stereo"
		device.profile.description = "Digital Stereo (IEC958)"
		device.description = "Internes Audio Digital Stereo (IEC958)"
	Ports:
		iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, availability unknown)
	Aktiver Port: iec958-stereo-output
	Formate:
		pcm
Ziel #4
	Status: SUSPENDED
	Beschreibung: UACDemoV1.0 Analog Stereo
	Abtastwert-Angabe: s16le 2ch 48000Hz
	Besitzer-Modul: 29
	Stumm: nein
	Lautstärke: front-left: 64587 /  99% / -0,38 dB,   front-right: 64587 /  99% / -0,38 dB
	        Verteilung 0,00
	Basis-Lautstärke: 64587 /  99% / -0,38 dB
	Quellen-Monitor: alsa_output.usb-Jieli_Technology_UACDemoV1.0_4542BF943C234C53-01.analog-stereo.monitor
	Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
	Eigenschaften:
		device.api = "alsa"
		alsa.name = "USB Audio"
		alsa.id = "USB Audio"
		alsa.device = "0"
		alsa.card = "3"
		alsa.card_name = "UACDemoV1.0"
		alsa.long_card_name = "Jieli Technology UACDemoV1.0 at usb-0000:00:14.0-3.3, full speed"
		alsa.driver_name = "snd_usb_audio"
		device.bus_path = "pci-0000:00:14.0-usb-0:3.3:1.1"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.3/1-3.3:1.1/sound/card3"
		udev.id = "usb-Jieli_Technology_UACDemoV1.0_4542BF943C234C53-01"
		device.bus = "usb"
		device.vendor.id = "4c4a"
		device.vendor.name = "Jieli Technology"
		device.product.id = "4155"
		device.product.name = "UACDemoV1.0"
		device.serial = "Jieli_Technology_UACDemoV1.0_4542BF943C234C53"
		device.string = "front:3"
		device.buffering.buffer_size = "384000"
		device.buffering.fragment_size = "192000"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "UACDemoV1.0 Analog Stereo"
		device.icon_name = "audio-card-usb"
	Ports:
		analog-output: Analog Output (type: Analog, priority: 9900, availability unknown)
	Aktiver Port: analog-output
	Formate:
		pcm
Quelle #0
	Status: SUSPENDED
	Beschreibung: Monitor of GP107GL High Definition Audio Controller Digital Stereo (HDMI 2)
	Besitzer-Modul: 6
	Stumm: nein
	Lautstärke: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
	        Verteilung 0,00
	Ziel-Monitor: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1
	Flags: DECIBEL_VOLUME LATENCY
	Eigenschaften:
		device.description = "Monitor of GP107GL High Definition Audio Controller Digital Stereo (HDMI 2)"
		device.class = "monitor"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "1"
	Formate:
		pcm
Quelle #1
	Status: SUSPENDED
	Beschreibung: Webcam C270 Mono
	Abtastwert-Angabe: s16le 1ch 48000Hz
	Kanalzuordnung: mono
	Besitzer-Modul: 7
	Stumm: nein
	Lautstärke: mono: 47841 /  73% / -8,20 dB
	        Verteilung 0,00
	Basis-Lautstärke: 20724 /  32% / -30,00 dB
	Ziel-Monitor: k. A.
	Eigenschaften:
		device.api = "alsa"
		alsa.device = "0"
		alsa.card = "2"
		alsa.card_name = "USB Device 0x46d:0x825"
		alsa.long_card_name = "USB Device 0x46d:0x825 at usb-0000:00:14.0-13, high speed"
		device.bus_path = "pci-0000:00:14.0-usb-0:13:1.2"
		sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.2/sound/card2"
		udev.id = "usb-046d_0825_B975BB10-02"
		device.bus = "usb"
		device.vendor.id = "046d"
		device.vendor.name = "Logitech, Inc."
		device.product.id = "0825"
		device.product.name = "Webcam C270"
		device.serial = "046d_0825_B975BB10"
		device.form_factor = "webcam"
		device.string = "hw:2"
		device.buffering.buffer_size = "192000"
		device.buffering.fragment_size = "96000"
		device.profile.name = "mono-fallback"
		device.profile.description = "Mono"
		device.description = "Webcam C270 Mono"
		device.icon_name = "camera-web-usb"
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
	Aktiver Port: analog-input-mic
	Formate:
		pcm
Quelle #2
	Status: SUSPENDED
	Beschreibung: Monitor of Internes Audio Digital Stereo (IEC958)
	Besitzer-Modul: 8
	Stumm: nein
	        Verteilung 0,00
	Ziel-Monitor: alsa_output.pci-0000_00_1f.3.iec958-stereo
	Eigenschaften:
		device.description = "Monitor of Internes Audio Digital Stereo (IEC958)"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
	Formate:
		pcm
Quelle #5
	Status: SUSPENDED
	Name: alsa_output.usb-Jieli_Technology_UACDemoV1.0_4542BF943C234C53-01.analog-stereo.monitor
	Beschreibung: Monitor of UACDemoV1.0 Analog Stereo
	Besitzer-Modul: 29
	Stumm: nein
	        Verteilung 0,00
	Ziel-Monitor: alsa_output.usb-Jieli_Technology_UACDemoV1.0_4542BF943C234C53-01.analog-stereo
	Eigenschaften:
		device.description = "Monitor of UACDemoV1.0 Analog Stereo"
		alsa.card = "3"
		device.bus = "usb"
		device.string = "3"
	Formate:
		pcm
Client #0
	Treiber: module-systemd-login.c
	Owner-Modul: 22
	Eigenschaften:
		application.name = "Login Session 2"
		systemd-login.session = "2"
Client #1
	Treiber: protocol-native.c
	Owner-Modul: 15
	Eigenschaften:
		application.name = "xfwm4"
		native-protocol.peer = "UNIX socket client"
		native-protocol.version = "35"
		window.x11.screen = "0"
		window.x11.display = ":0"
		application.process.id = "1189"
		application.process.user = "myuser"
		application.process.host = "imedv11"
		application.process.binary = "xfwm4"
		application.language = "de_DE.utf8"
		application.process.machine_id = "2cf839ec73924242bcda5fa06d38ae8f"
		application.process.session_id = "2"
Client #2
	Owner-Modul: 15
	Eigenschaften:
		application.name = "xfce4-pulseaudio-plugin"
		application.version = "0.4.3"
		application.id = "org.xfce.pulseaudio-plugin"
		application.icon_name = "multimedia-volume-control"
		application.process.id = "1220"
		application.process.binary = "wrapper-2.0"
Client #3
	Owner-Modul: 15
	Eigenschaften:
		application.process.id = "1229"
Client #8
	Owner-Modul: 15
	Eigenschaften:
		application.name = "pactl"
		application.process.id = "4077"
		application.process.binary = "pactl"
		window.x11.display = ":0.0"
Karte #0
	Owner-Modul: 6
	Eigenschaften:
		alsa.card = "1"
		device.bus = "pci"
		device.string = "1"
		device.description = "GP107GL High Definition Audio Controller"
	Profile:
		output:hdmi-stereo: Digital Stereo (HDMI)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5900, verfügbar: nein)
		output:hdmi-surround: Digital Surround 5.1 (HDMI)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 800, verfügbar: nein)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 800, verfügbar: nein)
		output:hdmi-stereo-extra1: Digital Stereo (HDMI 2)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 38468, verfügbar: ja)
		output:hdmi-stereo-extra2: Digital Stereo (HDMI 3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
		output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-stereo-extra3: Digital Stereo (HDMI 4)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
		output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-stereo-extra4: Digital Stereo (HDMI 5)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
		output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-stereo-extra5: Digital Stereo (HDMI 6)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5700, verfügbar: nein)
		output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 600, verfügbar: nein)
		off: Aus (Ziele: 0, Quellen: 0, Priorität: 0, verfügbar: ja)
	Aktives Profil: output:hdmi-stereo-extra1
	Ports:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
			Eigenschaften:
			Teil der/des Profil(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
		hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, available)
			Eigenschaften:
				device.product.name = "BenQ GL2450H
			Teil der/des Profil(s): output:hdmi-stereo-extra1
		hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, not available)
			Eigenschaften:
			Teil der/des Profil(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
		hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, not available)
			Eigenschaften:
			Teil der/des Profil(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
		hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, not available)
			Eigenschaften:
			Teil der/des Profil(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
		hdmi-output-5: HDMI / DisplayPort 6 (type: HDMI, priority: 5400, latency offset: 0 usec, not available)
			Eigenschaften:
			Teil der/des Profil(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
Karte #1
	Owner-Modul: 7
	Eigenschaften:
		alsa.card = "2"
		device.bus = "usb"
		device.string = "2"
		device.description = "Webcam C270"
	Profile:
		input:mono-fallback: Mono-Eingabe (Ziele: 0, Quellen: 1, Priorität: 1, verfügbar: ja)
	Aktives Profil: input:mono-fallback
	Ports:
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
			Eigenschaften:
			Teil der/des Profil(s): input:mono-fallback
Karte #2
	Owner-Modul: 8
	Eigenschaften:
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
		device.description = "Internes Audio"
	Profile:
		input:analog-stereo: Analog Stereo-Eingabe (Ziele: 0, Quellen: 1, Priorität: 65, verfügbar: nein)
		output:analog-stereo: Analog Stereo-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 6500, verfügbar: nein)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (Ziele: 1, Quellen: 1, Priorität: 6565, verfügbar: nein)
		output:analog-surround-21: Analog Surround 2.1-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 1300, verfügbar: nein)
		output:analog-surround-21+input:analog-stereo: Analog Surround 2.1-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1365, verfügbar: nein)
		output:analog-surround-40: Analog Surround 4.0-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 1200, verfügbar: nein)
		output:analog-surround-40+input:analog-stereo: Analog Surround 4.0-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1265, verfügbar: nein)
		output:analog-surround-41: Analog Surround 4.1-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 1300, verfügbar: nein)
		output:analog-surround-41+input:analog-stereo: Analog Surround 4.1-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1365, verfügbar: nein)
		output:analog-surround-50: Analog Surround 5.0-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 1200, verfügbar: nein)
		output:analog-surround-50+input:analog-stereo: Analog Surround 5.0-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1265, verfügbar: nein)
		output:analog-surround-51: Analog Surround 5.1-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 1300, verfügbar: nein)
		output:analog-surround-51+input:analog-stereo: Analog Surround 5.1-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 1365, verfügbar: nein)
		output:iec958-stereo: Digital Stereo (IEC958)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 38268, verfügbar: ja)
		output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958)-Ausgabe + Analog Stereo-Eingabe (Ziele: 1, Quellen: 1, Priorität: 5565, verfügbar: ja)
	Aktives Profil: output:iec958-stereo
	Ports:
		analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, not available)
			Eigenschaften:
			Teil der/des Profil(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo
		analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, not available)
			Eigenschaften:
		analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, not available)
		analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, not available)
			Teil der/des Profil(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
		analog-output-headphones: Headphones (type: Kopfhörer, priority: 9900, latency offset: 0 usec, not available)
			Eigenschaften:
		iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
			Teil der/des Profil(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
Karte #5
	Owner-Modul: 29
	Eigenschaften:
		alsa.card = "3"
		device.bus = "usb"
		device.string = "3"
		device.description = "UACDemoV1.0"
	Profile:
		output:analog-stereo: Analog Stereo-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 6500, verfügbar: ja)
		output:iec958-stereo: Digital Stereo (IEC958)-Ausgabe (Ziele: 1, Quellen: 0, Priorität: 5500, verfügbar: ja)
	Aktives Profil: output:analog-stereo
	Ports:
		analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Ok, solved my issue. For some reason, the PCM was muted in alsa.
Typing
amixer -c3 set 'PCM',0 100%,100%
fixed it and I got sound. Additionally I changed from pulseaudio-modules-bt to pulseaudio-bluetooth.
