Hi there, I tried to download pycairo but error had occured while building wheel for pycairo. Is there anyone who can help me? (I am currently using Python 3.7.12
Error message that I get:
pip3 install pycairo
Collecting pycairo
Using cached pycairo-1.23.0.tar.gz (344 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Installing backend dependencies ... done
Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: pycairo
Building wheel for pycairo (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for pycairo (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [51 lines of output]
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-cpython-37
creating build/lib.linux-x86_64-cpython-37/cairo
copying cairo/__init__.py -> build/lib.linux-x86_64-cpython-37/cairo
copying cairo/__init__.pyi -> build/lib.linux-x86_64-cpython-37/cairo
copying cairo/py.typed -> build/lib.linux-x86_64-cpython-37/cairo
running build_ext
building 'cairo._cairo' extension
creating build/temp.linux-x86_64-cpython-37
creating build/temp.linux-x86_64-cpython-37/cairo
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/bufferproxy.c -o build/temp.linux-x86_64-cpython-37/cairo/bufferproxy.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/cairomodule.c -o build/temp.linux-x86_64-cpython-37/cairo/cairomodule.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/context.c -o build/temp.linux-x86_64-cpython-37/cairo/context.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/device.c -o build/temp.linux-x86_64-cpython-37/cairo/device.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/enums.c -o build/temp.linux-x86_64-cpython-37/cairo/enums.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/error.c -o build/temp.linux-x86_64-cpython-37/cairo/error.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/font.c -o build/temp.linux-x86_64-cpython-37/cairo/font.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/glyph.c -o build/temp.linux-x86_64-cpython-37/cairo/glyph.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/matrix.c -o build/temp.linux-x86_64-cpython-37/cairo/matrix.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/misc.c -o build/temp.linux-x86_64-cpython-37/cairo/misc.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/path.c -o build/temp.linux-x86_64-cpython-37/cairo/path.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/pattern.c -o build/temp.linux-x86_64-cpython-37/cairo/pattern.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/rectangle.c -o build/temp.linux-x86_64-cpython-37/cairo/rectangle.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/region.c -o build/temp.linux-x86_64-cpython-37/cairo/region.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/surface.c -o build/temp.linux-x86_64-cpython-37/cairo/surface.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/textcluster.c -o build/temp.linux-x86_64-cpython-37/cairo/textcluster.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -B /home/yayiz/earth-ml/eml_env/compiler_compat -Wl,--sysroot=/ -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -Wstrict-prototypes -fPIC -DPYCAIRO_VERSION_MAJOR=1 -DPYCAIRO_VERSION_MINOR=23 -DPYCAIRO_VERSION_MICRO=0 -I/usr/include/cairo -I/usr/include/libpng16 -I/usr/include/freetype2 -I/usr/include/harfbuzz -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sysprof-4 -I/usr/include/pixman-1 -I/home/yayiz/earth-ml/eml_env/include/python3.7m -c cairo/textextents.c -o build/temp.linux-x86_64-cpython-37/cairo/textextents.o -Wall -Warray-bounds -Wcast-align -Wconversion -Wextra -Wformat=2 -Wformat-nonliteral -Wformat-security -Wimplicit-function-declaration -Winit-self -Winline -Wmissing-format-attribute -Wmissing-noreturn -Wnested-externs -Wold-style-definition -Wpacked -Wpointer-arith -Wreturn-type -Wshadow -Wsign-compare -Wstrict-aliasing -Wundef -Wunused-but-set-variable -Wswitch-default -Wno-missing-field-initializers -Wno-unused-parameter -Wno-unused-command-line-argument -fno-strict-aliasing -fvisibility=hidden -std=c99
gcc -pthread -shared -B /home/yayiz/earth-ml/eml_env/compiler_compat -L/home/yayiz/earth-ml/eml_env/lib -Wl,-rpath=/home/yayiz/earth-ml/eml_env/lib -Wl,--no-as-needed -Wl,--sysroot=/ build/temp.linux-x86_64-cpython-37/cairo/bufferproxy.o build/temp.linux-x86_64-cpython-37/cairo/cairomodule.o build/temp.linux-x86_64-cpython-37/cairo/context.o build/temp.linux-x86_64-cpython-37/cairo/device.o build/temp.linux-x86_64-cpython-37/cairo/enums.o build/temp.linux-x86_64-cpython-37/cairo/error.o build/temp.linux-x86_64-cpython-37/cairo/font.o build/temp.linux-x86_64-cpython-37/cairo/glyph.o build/temp.linux-x86_64-cpython-37/cairo/matrix.o build/temp.linux-x86_64-cpython-37/cairo/misc.o build/temp.linux-x86_64-cpython-37/cairo/path.o build/temp.linux-x86_64-cpython-37/cairo/pattern.o build/temp.linux-x86_64-cpython-37/cairo/rectangle.o build/temp.linux-x86_64-cpython-37/cairo/region.o build/temp.linux-x86_64-cpython-37/cairo/surface.o build/temp.linux-x86_64-cpython-37/cairo/textcluster.o build/temp.linux-x86_64-cpython-37/cairo/textextents.o -lcairo -o build/lib.linux-x86_64-cpython-37/cairo/_cairo.cpython-37m-x86_64-linux-gnu.so
/home/yayiz/earth-ml/eml_env/compiler_compat/ld: /usr/lib/libc.so.6: unknown type [0x13] section `.relr.dyn'
/home/yayiz/earth-ml/eml_env/compiler_compat/ld: skipping incompatible /usr/lib/libc.so.6 when searching for /usr/lib/libc.so.6
/home/yayiz/earth-ml/eml_env/compiler_compat/ld: cannot find /usr/lib/libc.so.6
/home/yayiz/earth-ml/eml_env/compiler_compat/ld: /usr/lib/ld-linux-x86-64.so.2: unknown type [0x13] section `.relr.dyn'
/home/yayiz/earth-ml/eml_env/compiler_compat/ld: skipping incompatible /usr/lib/ld-linux-x86-64.so.2 when searching for /usr/lib/ld-linux-x86-64.so.2
/home/yayiz/earth-ml/eml_env/compiler_compat/ld: cannot find /usr/lib/ld-linux-x86-64.so.2
collect2: error: ld returned 1 exit status
error: command '/usr/bin/gcc' failed with exit code 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for pycairo
Failed to build pycairo
ERROR: Could not build wheels for pycairo, which is required to install pyproject.toml-based projects
My system information:
inxi -v7azy
Kernel: 5.15.114-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=52fc0dd4-8c85-4b1b-9d6b-9f63964e450a rw quiet splash apparmor=1
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Micro-Star product: GF63 Thin 9SC v: REV:1.0
Mobo: Micro-Star model: MS-16R3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16R3IMS.108 date: 03/26/2020
ID-1: BAT1 charge: 38.5 Wh (90.2%) condition: 42.7/51.3 Wh (83.2%)
volts: 12.4 min: 11.4 model: MSI Corp. MS-16R3 type: Li-ion serial: N/A
status: N/A
System RAM: available: 15.47 GiB used: 3.9 GiB (25.2%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2754 high: 4351 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 3777
5: 4246 6: 4190 7: 4288 8: 4351 9: 4031 10: 4173 11: 800 12: 800
bogomips: 62431
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0302
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: modesetting dri: iris gpu: i915
display-ID: :1 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x21ed built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
API: ALSA v: k5.15.114-1-MANJARO status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off tools: qjackctl
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 465.76 GiB used: 134.83 GiB (28.9%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 448.43 GiB (98.20%)
used: 134.83 GiB (30.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 52fc0dd4-8c85-4b1b-9d6b-9f63964e450a
label: NO_LABEL uuid: 0A7A-192D
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 3659c6bf-7b48-4880-9640-06e1c3979a15
Device-1: 1-5:2 info: USB OPTICAL MOUSE type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 275d:0a29 class-ID: 0301
Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 54.0 C pch: 61.0 C mobo: N/A
Processes: 346 Uptime: 22m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1806
pm: pacman pkgs: 1786 libs: 407 tools: gnome-software,pamac pm: flatpak
pkgs: 20 Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.27
