I am able to sucessfully connect to my bluetooth headphones but i am unable to get any sound output from it.
When i saw my bluetooth service status. It gave me this output
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2021-05-16 05:16:20 IST; 1min 14s ago
Docs: man:bluetoothd(8)
Main PID: 41166 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9394)
Memory: 972.0K
CGroup: /system.slice/bluetooth.service
└─41166 /usr/lib/bluetooth/bluetoothd
May 16 05:16:20 jarvis systemd[1]: Starting Bluetooth service...
May 16 05:16:20 jarvis bluetoothd[41166]: Bluetooth daemon 5.58
May 16 05:16:20 jarvis systemd[1]: Started Bluetooth service.
May 16 05:16:20 jarvis bluetoothd[41166]: Starting SDP server
May 16 05:16:20 jarvis bluetoothd[41166]: Bluetooth management interface 1.18 initialized
May 16 05:16:20 jarvis bluetoothd[41166]: Endpoint registered: sender=:1.275 path=/MediaEndpoint/A2DPSink/sbc
May 16 05:16:20 jarvis bluetoothd[41166]: Endpoint registered: sender=:1.275 path=/MediaEndpoint/A2DPSource/sbc
May 16 05:17:08 jarvis bluetoothd[41166]: profiles/audio/avctp.c:avctp_control_confirm() Control: Refusing unexpected connect
May 16 05:17:11 jarvis bluetoothd[41166]: /org/bluez/hci0/dev_6C_CE_44_26_3A_E1/sep2/fd0: fd(39) ready
This is causing some problem
Please help me.
I know it sounds simple, but many headphones won’t play sound when using their integrated microphones. If your headphone set has a microphone and it is activated, try to turn it off.
If that solution doesn’t work, could you please run the following command and post the output?
inxi -Fazy
Thanks,
Nomadical
P.S, Welcome to the manjaro support community!
Thank you for replying.
I am using Realme Buds Q , I don’t think it has integrated microphones.
inxi -Fazy Output
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=e4064013-4cc8-47d7-8cc7-be61542a5af6 rw quiet apparmor=1
security=apparmor resume=UUID=36909053-655a-4758-b972-b096f6c518d3
udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Laptop 15-cs2xxx
v: Type1ProductConfigId serial: Chassis: type: 10 serial:
Mobo: HP model: 84C1 v: 15.32 serial: UEFI: Insyde v: F.23
date: 12/25/2020
ID-1: BAT0 charge: 38.3 Wh (100.0%) condition: 38.3/38.3 Wh (100.0%)
volts: 12.7 min: 11.3 model: HP Primary type: Li-ion serial: N/A
status: Discharging
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: B (11)
microcode: DE cache: L2: 6 MiB
bogomips: 28800
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 801 8: 800
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:1d13 class-ID: 0302
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:4 chip-ID: 0408:5300 class-ID: 0e02 serial:
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:9dc8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: no
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlo1 state: up mac:
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0
IF: eno1 state: down mac:
IF-ID-1: br-1d3d65b18340 state: down mac:
IF-ID-2: br-1fb005d71c69 state: up speed: 10000 Mbps duplex: unknown
mac:
IF-ID-3: br-ad231a5118a8 state: down mac:
IF-ID-4: docker0 state: down mac:
IF-ID-5: vethd9e2f85 state: up speed: 10000 Mbps duplex: full mac:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Local Storage: total: 1.17 TiB used: 112.02 GiB (9.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 rotation: SSD serial: rev: ADHA0102 temp: 37.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
rotation: 5400 rpm serial: rev: 4C scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Blade
size: 28.65 GiB block-size: physical: 512 B logical: 512 B serial:
rev: 1.00 scheme: MBR
ID-1: / raw-size: 90.61 GiB size: 89.07 GiB (98.29%) used: 56.03 GiB (62.9%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 324 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 63.5 GiB size: 62 GiB (97.64%) used: 55.99 GiB (90.3%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 3.91 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 280 Uptime: 3h 08m wakeups: 1 Memory: 7.66 GiB
used: 3.26 GiB (42.5%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1523 pacman: 1506 lib: 433 flatpak: 5 snap: 12
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
I tried connecting headphones from Bootable Manjaro in my USB Drive . And the headphones are working perfectly in it.
inxi -Fazy
Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_KDE_2003 quiet systemd.show_status=1
apparmor=1 security=apparmor
Desktop: KDE Plasma 5.18.5 tk: Qt 5.14.2 wm: kwin_x11 vt: 1 dm: SDDM
date: 12/25/2020
ID-1: BAT0 charge: 29.7 Wh (77.5%) condition: 38.3/38.3 Wh (100.0%)
volts: 11.9 min: 11.3 model: HP Primary type: Li-ion serial: N/A
status: Discharging
bogomips: 28808
Speed: 900 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 901 8: 902
driver: nouveau v: kernel bus-ID: 02:00.0 chip-ID: 10de:1d13 class-ID: 0302
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver:
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.0.7
direct render: Yes
class-ID: 0403
Sound Server-1: ALSA v: k5.6.15-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 13.0 running: yes
Sound Server-4: PipeWire v: 0.3.5 running: yes
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
Local Storage: total: 1.17 TiB used: 0 KiB (0.0%)
lanes: 2 rotation: SSD serial: rev: ADHA0102 temp: 35.9 C
scheme: GPT
Message: No partition data found.
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Processes: 236 Uptime: 14m wakeups: 1 Memory: 7.67 GiB
used: 2.55 GiB (33.2%) Init: systemd v: 245 tool: systemctl Compilers:
gcc: 10.1.0 Packages: pacman: 1218 lib: 319 flatpak: 0 Shell: Bash v: 5.0.17
So, it seems that your PipeWire installation is broken. Follow these commands to uninstall and reinstall it:
sudo pacman -R manjaro-pipewire
sudo pacman -S manjaro-pipewire
Then restart your computer
system
closed
May 31, 2021, 5:50pm
#7
