Hi all,
I’m getting the following error message after messing about on a partition manager on the live USB so I can create a separate partition for Timeshift, since it was taking up a lot of space in my root partition. I should note this was my first time using KDE Partition Manager, so I might have messed something up during the process. I chopped up a little bit of Home partition and created a new btrfs for Timeshift, having done that. I’ve rebooted, took off the USB and see the dreaded screen.
[FAILED] Failed to start File System Check on /dev/disk/by-uuid/7273e618-e97c-41
[DEPEND] Dependency failed for /home
[DEPEND] Dependency failed for Local File Systems.
You are in emergency mode, etc.
tl;dr I did a oopsy by attempting make a backup on my computer in case a oopsy happens in the near future, making the the word ‘Oopsy’ lost its meaning in the process.
I also got the journal -xd logs (I’m hoping I got the right log) But there are over 3000 lines and the forum is not letting me post them because there are links in them, which I can understand but I’m not sure which part I need to post here.
EDITED: Forum trusts me now, here it is.
Apr 01 15:41:14 manjaro plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/a>
Apr 01 15:41:14 manjaro kded5[1425]: System timezone has been changed, new timezone is "UTC"
Apr 01 15:41:14 manjaro kaccess[1496]: Xlib XKB extension major= 1 minor= 0
Apr 01 15:41:14 manjaro dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.UDis>
Apr 01 15:41:14 manjaro systemd[1]: Starting Disk Manager...
░░ Subject: A start job for unit udisks2.service has begun execution
░░ Defined-By: systemd
░░ Support: s://forum.manjaro.org/c/support
░░ A start job for unit udisks2.service has begun execution.
░░ The job identifier is 643.
Apr 01 15:41:14 manjaro NetworkManager[678]: <info> [1680363674.8488] agent-manager: agent[b9593d0fe2dae5ef,>
Apr 01 15:41:14 manjaro udisksd[1512]: udisks daemon version 2.9.4 starting
Apr 01 15:41:14 manjaro systemd[1097]: Starting Sound Service...
░░ Subject: A start job for unit UNIT has begun execution
░░ A start job for unit UNIT has begun execution.
░░ The job identifier is 80.
Apr 01 15:41:14 manjaro plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/home/manj>
Apr 01 15:41:14 manjaro breath2tobreath[1530]: QApplication::qAppName: Please instantiate the QApplication ob>
Apr 01 15:41:14 manjaro breath2tobreath[1530]: QSocketNotifier: Can only be used with threads started with QT>
Apr 01 15:41:14 manjaro breath2tobreath[1530]: QCoreApplication::arguments: Please instantiate the QApplicati>
Apr 01 15:41:14 manjaro kaccess[1496]: X server XKB extension major= 1 minor= 0
Apr 01 15:41:14 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Activating via systemd: service name='>
Apr 01 15:41:14 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Apr 01 15:41:14 manjaro systemd[1]: Started Disk Manager.
░░ Subject: A start job for unit udisks2.service has finished successfully
░░ A start job for unit udisks2.service has finished successfully.
Apr 01 15:41:14 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 >
Apr 01 15:41:14 manjaro udisksd[1512]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Apr 01 15:41:14 manjaro systemd[1097]: Starting KActivityManager Activity manager Service...
░░ The job identifier is 98.
Apr 01 15:41:14 manjaro dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.UPow>
Apr 01 15:41:14 manjaro audit: BPF prog-id=16 op=LOAD
Apr 01 15:41:14 manjaro audit: BPF prog-id=17 op=LOAD
Apr 01 15:41:14 manjaro systemd[1]: Starting Daemon for power management...
░░ Subject: A start job for unit upower.service has begun execution
░░ A start job for unit upower.service has begun execution.
░░ The job identifier is 705.
Apr 01 15:41:14 manjaro dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.Real>
Apr 01 15:41:14 manjaro systemd[1]: Starting RealtimeKit Scheduling Policy Service...
░░ Subject: A start job for unit rtkit-daemon.service has begun execution
░░ A start job for unit rtkit-daemon.service has begun execution.
░░ The job identifier is 767.
Apr 01 15:41:14 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.freedesktop.RealtimeKi>
Apr 01 15:41:14 manjaro systemd[1]: Started RealtimeKit Scheduling Policy Service.
░░ Subject: A start job for unit rtkit-daemon.service has finished successfully
░░ A start job for unit rtkit-daemon.service has finished successfully.
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Successfully called chroot.
Apr 01 15:41:14 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-da>
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Successfully dropped privileges.
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Successfully limited resources.
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Canary thread running.
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Running.
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Watchdog thread running.
Apr 01 15:41:14 manjaro polkit-kde-authentication-agent-1[1502]: New PolkitAgentListener 0x5575e3ee6c00
Apr 01 15:41:14 manjaro polkit-kde-authentication-agent-1[1502]: Adding new listener PolkitQt1::Agent::Liste>
Apr 01 15:41:14 manjaro polkit-kde-authentication-agent-1[1502]: Listener online
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Successfully made thread 1544 of process 1544 owned by '1000' hig>
Apr 01 15:41:14 manjaro rtkit-daemon[1569]: Supervising 1 threads of 1 processes of 1 users.
Apr 01 15:41:15 manjaro polkitd[620]: Registered Authentication Agent for unix-session:1 (system bus name :1.>
Apr 01 15:41:15 manjaro polkit-kde-authentication-agent-1[1502]: Authentication agent result: true
Apr 01 15:41:15 manjaro plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/home/manj>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.freedesktop.UPower'
Apr 01 15:41:15 manjaro systemd[1]: Started Daemon for power management.
░░ Subject: A start job for unit upower.service has finished successfully
░░ A start job for unit upower.service has finished successfully.
Apr 01 15:41:15 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower c>
Apr 01 15:41:15 manjaro plasma_session[1407]: org.kde.plasma.session: Starting autostart service "/etc/xdg/a>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Activating service name='org.kde.powerdevil.discretegpuhel>
Apr 01 15:41:15 manjaro kwin_x11[1428]: kwin_core: XCB error: 10 (BadAccess), sequence: 823, resource id: 173>
Apr 01 15:41:15 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 904, >
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.kde.powerdevil.discret>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Activating service name='org.kde.powerdevil.chargethreshol>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.home>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Activation via systemd failed for unit 'dbus-org.freedeskt>
Apr 01 15:41:15 manjaro sudo[1638]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus>
Apr 01 15:41:15 manjaro audit[1638]: USER_ACCT pid=1638 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grant>
Apr 01 15:41:15 manjaro sudo[1638]: manjaro : PWD=/home/manjaro ; USER=root ; COMMAND=/usr/bin/mkdir -p /.Tr>
Apr 01 15:41:15 manjaro audit[1638]: CRED_REFR pid=1638 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors>
Apr 01 15:41:15 manjaro sudo[1638]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 01 15:41:15 manjaro audit[1638]: USER_START pid=1638 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open gr>
Apr 01 15:41:15 manjaro sudo[1638]: pam_unix(sudo:session): session closed for user root
Apr 01 15:41:15 manjaro audit[1638]: USER_END pid=1638 uid=1000 auid=1000 ses=1 msg='op=PAM:session_close gra>
Apr 01 15:41:15 manjaro audit[1638]: CRED_DISP pid=1638 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors>
Apr 01 15:41:15 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Successfully activated service 'org.kd>
Apr 01 15:41:15 manjaro systemd[1097]: Started KActivityManager Activity manager Service.
░░ Subject: A start job for unit UNIT has finished successfully
░░ A start job for unit UNIT has finished successfully.
Apr 01 15:41:15 manjaro sudo[1651]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus>
Apr 01 15:41:15 manjaro audit[1651]: USER_ACCT pid=1651 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grant>
Apr 01 15:41:15 manjaro sudo[1651]: manjaro : PWD=/home/manjaro ; USER=root ; COMMAND=/usr/bin/chown -R 1000>
Apr 01 15:41:15 manjaro audit[1651]: CRED_REFR pid=1651 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors>
Apr 01 15:41:15 manjaro sudo[1651]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Apr 01 15:41:15 manjaro audit[1651]: USER_START pid=1651 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open gr>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.kde.powerdevil.charget>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Activating service name='org.kde.powerdevil.backlighthelpe>
Apr 01 15:41:15 manjaro sudo[1651]: pam_unix(sudo:session): session closed for user root
Apr 01 15:41:15 manjaro audit[1651]: USER_END pid=1651 uid=1000 auid=1000 ses=1 msg='op=PAM:session_close gra>
Apr 01 15:41:15 manjaro audit[1651]: CRED_DISP pid=1651 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors>
Apr 01 15:41:15 manjaro plasmashell[1506]: Aborting shell load: The activity manager daemon (kactivitymanager>
Apr 01 15:41:15 manjaro plasmashell[1506]: If this Plasma has been installed into a custom prefix, verify tha>
Apr 01 15:41:15 manjaro baloo_file[1497]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we>
Apr 01 15:41:15 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.kde.powerdevil.backlig>
Apr 01 15:41:15 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Activating service name='org.freedeskt>
Apr 01 15:41:15 manjaro org_kde_powerdevil[1504]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelpe>
Apr 01 15:41:15 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Activating via systemd: service name='>
Apr 01 15:41:15 manjaro systemd[1097]: Starting Accessibility services bus...
░░ The job identifier is 116.
Apr 01 15:41:15 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Successfully activated service 'org.a1>
Apr 01 15:41:15 manjaro systemd[1097]: Started Accessibility services bus.
Apr 01 15:41:15 manjaro at-spi-bus-launcher[1828]: dbus-daemon[1828]: Activating service name='org.a11y.atspi>
Apr 01 15:41:15 manjaro systemd[1097]: Starting Portal service...
░░ The job identifier is 133.
Apr 01 15:41:15 manjaro at-spi-bus-launcher[1828]: dbus-daemon[1828]: Successfully activated service 'org.a11>
Apr 01 15:41:15 manjaro at-spi-bus-launcher[1835]: SpiRegistry daemon is running with well-known name - org.a>
Apr 01 15:41:15 manjaro systemd[1097]: Starting flatpak document portal service...
░░ The job identifier is 151.
Apr 01 15:41:15 manjaro org_kde_powerdevil[1504]: org.kde.powerdevil: Handle button events action could not c>
Apr 01 15:41:15 manjaro systemd[1097]: Starting KScreen...
░░ The job identifier is 169.
Apr 01 15:41:15 manjaro systemd[1097]: Starting sandboxed app permission store...
░░ The job identifier is 187.
Apr 01 15:41:15 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Successfully activated service 'org.fr>
Apr 01 15:41:15 manjaro systemd[1097]: Started sandboxed app permission store.
Apr 01 15:41:15 manjaro systemd[1097]: Started flatpak document portal service.
Apr 01 15:41:15 manjaro systemd[1097]: Started KScreen.
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Connected output 82 to CRTC 78
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Detected XRandR 1.6
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Event Base: 89
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Event Error: 147
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Supervising 1 threads of 1 processes of 1 users.
Apr 01 15:41:15 manjaro systemd[1097]: Starting Xdg Desktop Portal For KDE...
░░ The job identifier is 204.
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Successfully made thread 1885 of process 1544 owned by '1000' RT >
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Supervising 2 threads of 1 processes of 1 users.
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Successfully made thread 1887 of process 1544 owned by '1000' RT >
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Supervising 3 threads of 1 processes of 1 users.
Apr 01 15:41:15 manjaro plasmashell[1506]: kf.plasma.quick: Applet preload policy set to 1
Apr 01 15:41:15 manjaro systemd[1097]: Started Xdg Desktop Portal For KDE.
Apr 01 15:41:15 manjaro xdg-desktop-portal-kde[1883]: xdp-kde: Desktop portal registered successfully
Apr 01 15:41:15 manjaro systemd[1097]: Started PipeWire Multimedia Service.
░░ The job identifier is 222.
Apr 01 15:41:15 manjaro systemd[1097]: Started PipeWire Media Session Manager.
░░ The job identifier is 240.
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Successfully made thread 1907 of process 1907 owned by '1000' hig>
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Supervising 4 threads of 2 processes of 1 users.
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Successfully made thread 1918 of process 1908 owned by '1000' RT >
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Supervising 5 threads of 3 processes of 1 users.
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Successfully made thread 1924 of process 1907 owned by '1000' RT >
Apr 01 15:41:15 manjaro rtkit-daemon[1569]: Supervising 6 threads of 3 processes of 1 users.
Apr 01 15:41:15 manjaro systemd[1097]: Started Portal service.
Apr 01 15:41:15 manjaro kded5[1425]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought>
Apr 01 15:41:15 manjaro kded5[1425]: Delayed initialization.
Apr 01 15:41:15 manjaro kded5[1425]: Reloading the khotkeys configuration
Apr 01 15:41:15 manjaro kded5[1425]: Version 2 File!
Apr 01 15:41:15 manjaro kded5[1425]: Loaded defaults from "/usr/share/khotkeys/defaults.khotkeys"
Apr 01 15:41:15 manjaro kded5[1425]: true
Apr 01 15:41:15 manjaro kded5[1425]: Imported file "/usr/share/khotkeys/defaults.khotkeys"
Apr 01 15:41:15 manjaro kded5[1425]: Imported file "/usr/share/khotkeys/kde32b1.khotkeys"
Apr 01 15:41:15 manjaro kded5[1425]: Imported file "/usr/share/khotkeys/konqueror_gestures_kde321.khotkeys"
Apr 01 15:41:15 manjaro gst-plugin-scan[1890]: type name '-a-png-encoder-pred' contains invalid characters
Apr 01 15:41:15 manjaro gst-plugin-scan[1890]: g_type_set_qdata: assertion 'node != NULL' failed
Apr 01 15:41:15 manjaro systemd[1097]: Starting Bluetooth OBEX service...
░░ The job identifier is 241.
Apr 01 15:41:15 manjaro kded5[1425]: Registering ":1.27/StatusNotifierItem" to system tray
Apr 01 15:41:15 manjaro kded5[1425]: Registering ":1.36/StatusNotifierItem" to system tray
Apr 01 15:41:15 manjaro kded5[1425]: Registering ":1.32/StatusNotifierItem" to system tray
Apr 01 15:41:15 manjaro obexd[1931]: OBEX daemon 5.65
Apr 01 15:41:15 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Successfully activated service 'org.bl>
Apr 01 15:41:15 manjaro systemd[1097]: Started Bluetooth OBEX service.
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandR::setConfig
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Requested screen size is QSize(2560, >
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Needed CRTCs: 1
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Actions to perform:
Primary Output: false
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Change Screen Size: false
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Disable outputs: false
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Change outputs: false
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Enable outputs: false
Apr 01 15:41:15 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandR::setConfig done!
Apr 01 15:41:15 manjaro kernel: Bluetooth: RFCOMM TTY layer initialized
Apr 01 15:41:15 manjaro kernel: Bluetooth: RFCOMM socket layer initialized
Apr 01 15:41:15 manjaro kernel: Bluetooth: RFCOMM ver 1.11
Apr 01 15:41:16 manjaro plasmashell[1506]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.>
Apr 01 15:41:16 manjaro plasmashell[1506]: evaluating startup script: "/usr/share/plasma/look-and-feel/org.ma>
Apr 01 15:41:16 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.>
Apr 01 15:41:16 manjaro plasmashell[1506]: <Unknown File>: QML QQuickAnchors: Binding loop detected for prope>
Apr 01 15:41:16 manjaro plasmashell[1506]: Trying to use rootObject before initialization is completed, whils>
Apr 01 15:41:16 manjaro plasmashell[1506]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5591>
Apr 01 15:41:16 manjaro plasmashell[1506]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5591>
Apr 01 15:41:16 manjaro plasmashell[1506]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x559>
Apr 01 15:41:16 manjaro pulseaudio[1544]: stat('/etc/pulse/default.pa.d'): No such file or directory
Apr 01 15:41:16 manjaro systemd[1097]: Started Sound Service.
Apr 01 15:41:16 manjaro pulseaudio[1544]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryPro>
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/lda>
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/aptx_>
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/apt>
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/aptx
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSink/sbc_x>
Apr 01 15:41:16 manjaro bluetoothd[760]: Endpoint registered: sender=:1.52 path=/MediaEndpoint/A2DPSource/sbc>
Apr 01 15:41:16 manjaro plasmashell[1506]: QDBusConnection: error: could not send signal to service "" path ">
Apr 01 15:41:16 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/con>
Apr 01 15:41:16 manjaro plasmashell[1506]: Activity added twice "4d374bb1-f548-4681-b87f-40ee5100c9e6"
Apr 01 15:41:16 manjaro plasmashell[1506]: "Containment 0 Does not have a _sep1 item; it must be a panel.\n"
Apr 01 15:41:16 manjaro plasmashell[1506]: "Containment 1 Does not have a _sep1 item; it must be a panel.\n"
Apr 01 15:41:16 manjaro plasmashell[1506]: "Panel 1 Seems to have a middle-click paste action defined; deleti>
Apr 01 15:41:16 manjaro plasmashell[1506]: org.kde.klipper: Failed to load history resource. Clipboard histor>
Apr 01 15:41:17 manjaro plasmashell[1506]: Cyclic dependency detected between "file:///usr/share/plasma/plasm>
Apr 01 15:41:17 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Successfully activated service 'org.fr>
Apr 01 15:41:17 manjaro plasmashell[1506]: libkcups: CUPS-Get-Printers last error: 1030 No destinations added.
Apr 01 15:41:17 manjaro plasmashell[1506]: libkcups: Get-Jobs last error: 0 successful-ok
Apr 01 15:41:17 manjaro plasmashell[1506]: libkcups: Create-Printer-Subscriptions last error: 0 successful-ok
Apr 01 15:41:17 manjaro kded5[1425]: Registering "org.kde.StatusNotifierHost-1506" as system tray
Apr 01 15:41:17 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtr>
Apr 01 15:41:17 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/con>
Apr 01 15:41:17 manjaro plasmashell[1506]: libkcups: 0
Apr 01 15:41:17 manjaro plasmashell[1506]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x5591>
Apr 01 15:41:17 manjaro plasmashell[1506]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x5591>
Apr 01 15:41:17 manjaro plasmashell[1506]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x559>
Apr 01 15:41:17 manjaro plasmashell[1506]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater >
Apr 01 15:41:17 manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
░░ Subject: Unit succeeded
░░ The unit NetworkManager-dispatcher.service has successfully entered the 'dead' state.
Apr 01 15:41:17 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkMa>
Apr 01 15:41:17 manjaro plasmashell[1506]: Plasma Shell startup completed
Apr 01 15:41:17 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4045,>
Apr 01 15:41:18 manjaro plasmashell[1506]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qm>
Apr 01 15:41:18 manjaro plasmashell[1506]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two>
Apr 01 15:41:19 manjaro plasmashell[1506]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qm>
Apr 01 15:41:19 manjaro plasmashell[1506]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two>
Apr 01 15:41:20 manjaro plasmashell[1506]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qm>
Apr 01 15:41:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5213,>
Apr 01 15:41:20 manjaro plasmashell[1506]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two>
Apr 01 15:41:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 5404,>
Apr 01 15:41:20 manjaro kded5[1425]: Registering ":1.26/org/ayatana/NotificationItem/matray" to system tray
Apr 01 15:41:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 587>
Apr 01 15:41:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 588>
Apr 01 15:41:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 588>Apr 01 15:41:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 588>
Apr 01 15:41:21 manjaro plasmashell[1506]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qm>
Apr 01 15:41:21 manjaro plasmashell[1506]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two>
Apr 01 15:41:22 manjaro plasmashell[1506]: org.kde.plasma.runner.bookmarks: No default firefox profile found
Apr 01 15:41:22 manjaro plasmashell[1506]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Apr 01 15:41:22 manjaro plasmashell[1506]: Connecting to deprecated signal QDBusConnectionInterface::serviceO>
Apr 01 15:41:22 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Activating via systemd: service name='>
Apr 01 15:41:22 manjaro systemd[1097]: Starting KRunner provider for baloo file indexer...
░░ The job identifier is 258.
Apr 01 15:41:22 manjaro dbus-daemon[1173]: [session uid=1000 pid=1173] Successfully activated service 'org.kd>
Apr 01 15:41:22 manjaro systemd[1097]: Started KRunner provider for baloo file indexer.
Apr 01 15:41:25 manjaro systemd[1097]: Started systemsettings.
░░ The job identifier is 276.
Apr 01 15:41:25 manjaro systemsettings[2081]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qm>
Apr 01 15:41:25 manjaro systemsettings[2081]: kf.coreaddons: "Could not load plugin from kcm_kscreen: The sha>
Apr 01 15:41:25 manjaro systemsettings[2081]: QQmlEngine::setContextForObject(): Object already has a QQmlCon>
Apr 01 15:41:25 manjaro systemsettings[2081]: Qt Quick Layouts: Detected recursive rearrange. Aborting after >
Apr 01 15:41:25 manjaro systemsettings[2081]: qml: The item SubCategoryPage_QMLTYPE_103(0x560c6752ec80) is al>
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandR::setConfig
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Requested screen size is QSize(1440, >
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Needed CRTCs: 1
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Actions to perform:
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Change Screen Size: true
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Old: QSize(2560, 1600>
Intermediate: QSize(2560, 1600)
New: QSize(1440, 900)
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Disable outputs: false
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Change outputs: true
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: (82)
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Enable outputs: false
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 82 ( "eDP" )
CRTC: 78
Pos: QPoint(0,0)
Mode: KScreen::Mode(Id: "92" , Size: QSize(1>
Rotation: KScreen::Output::None
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandRCrtc 78 m_timestamp update 0>
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Result: 0 timestamp: 29618
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandROutput 82 update
m_connected: 0
m_crtc XRandRCrtc(0x562b71885a30)
CRTC: 78
MODE: 92
Connection: 0
Primary: true
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: RRSetScreenSize
DPI: 96.0757
SizeMM: QSize(380, 237)
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandR::setConfig done!
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: RRNotify_CrtcChange
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Timestamp: 11474
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: CRTC: 78
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Mode: 92
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Rotation: "Rotate_0"
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Geometry: 0 0 1440 900
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: RRScreenChangeNotify
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Config_timestamp: 11474
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Window: 58720261
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Root: 1739
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Size ID: 0
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Size: 2560 1600
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: SizeMM: 677 423
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Timestamp: 29618
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Size ID: 6
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: Size: 1440 900
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xcb.helper: SizeMM: 380 237
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: XRandRCrtc 78 m_configTimestamp upd>
Apr 01 15:41:29 manjaro systemsettings[2081]: kf.coreaddons: "Could not load plugin from kcm_kscreen: The sha>
Apr 01 15:41:29 manjaro kscreen_backend_launcher[1857]: kscreen.xrandr: Emitting configChanged()
Apr 01 15:41:33 manjaro pacman-key[903]: -> Locally signed 23 keys.
Apr 01 15:41:33 manjaro pacman-key[903]: ==> Importing owner trust values...
Apr 01 15:41:33 manjaro pacman-key[2184]: gpg: setting ownertrust to 4
Apr 01 15:41:33 manjaro pacman-key[2184]: gpg: inserting ownertrust of 4
Apr 01 15:41:33 manjaro pacman-key[2185]: gpg: inserting ownertrust of 4
Apr 01 15:41:33 manjaro pacman-key[2185]: gpg: setting ownertrust to 4
Apr 01 15:41:33 manjaro pacman-key[903]: ==> Disabling revoked keys in keyring...
Apr 01 15:41:33 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11059>
Apr 01 15:41:33 manjaro systemd[1097]: app-systemsettings-a7ab66ebd5be41c5b08f9bb3a8e72f20.scope: Consumed 1.>
░░ Subject: Resources consumed by unit runtime
░░ The unit UNIT completed and consumed the indicated resources.
Apr 01 15:41:34 manjaro plasmashell[1506]: trying to show an empty dialog
Apr 01 15:41:37 manjaro systemd[1]: systemd-hostnamed.service: Deactivated successfully.
░░ The unit systemd-hostnamed.service has successfully entered the 'dead' state.
Apr 01 15:41:37 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-h>
Apr 01 15:41:37 manjaro kernel: kauditd_printk_skb: 26 callbacks suppressed
Apr 01 15:41:37 manjaro kernel: audit: type=1131 audit(1680363697.416:86): pid=1 uid=0 auid=4294967295 ses=42>
Apr 01 15:41:37 manjaro systemd[1097]: Started Firefox - Web Browser.
░░ The job identifier is 280.
Apr 01 15:41:37 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13814>
Apr 01 15:41:37 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13819>
Apr 01 15:41:37 manjaro audit: BPF prog-id=0 op=UNLOAD
Apr 01 15:41:37 manjaro kernel: audit: type=1334 audit(1680363697.539:87): prog-id=0 op=UNLOAD
Apr 01 15:41:37 manjaro kernel: audit: type=1334 audit(1680363697.539:88): prog-id=0 op=UNLOAD
Apr 01 15:41:37 manjaro kernel: audit: type=1334 audit(1680363697.539:89): prog-id=0 op=UNLOAD
Apr 01 15:41:38 manjaro xdg-desktop-portal-kde[1883]: xdp-kde-settings: Read called with parameters:
Apr 01 15:41:38 manjaro xdg-desktop-portal-kde[1883]: xdp-kde-settings: group: "org.freedesktop.appearan>
Apr 01 15:41:38 manjaro xdg-desktop-portal-kde[1883]: xdp-kde-settings: key: "color-scheme"
Apr 01 15:41:39 manjaro rtkit-daemon[1569]: Supervising 6 threads of 3 processes of 1 users.
Apr 01 15:41:39 manjaro rtkit-daemon[1569]: Successfully made thread 2471 of process 2207 owned by '1000' RT >
Apr 01 15:41:39 manjaro rtkit-daemon[1569]: Supervising 7 threads of 4 processes of 1 users.
Apr 01 15:41:40 manjaro rtkit-daemon[1569]: Supervising 7 threads of 4 processes of 1 users.
Apr 01 15:41:45 manjaro xdg-desktop-portal-kde[1883]: xdp-kde-background: GetAppState called: no parameters
Apr 01 15:41:46 manjaro rtkit-daemon[1569]: Supervising 7 threads of 4 processes of 1 users.
Apr 01 15:41:47 manjaro plasmashell[1506]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since>
Apr 01 15:41:47 manjaro plasmashell[1506]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plas>
Apr 01 15:41:49 manjaro wpa_supplicant[912]: wlo1: Reject scan trigger since one is already pending
Apr 01 15:41:50 manjaro kded5[1425]: Registering ":1.57/StatusNotifierItem" to system tray
Apr 01 15:41:55 manjaro plasmashell[1506]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qm>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.2642] device (wlo1): Activation: starting co>
Apr 01 15:41:55 manjaro audit[678]: USYS_CONFIG pid=678 uid=0 auid=4294967295 ses=4294967295 msg='op=connecti>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.2645] audit: op="connection-add-activate" uu>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.2647] device (wlo1): state change: disconnec>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.2650] manager: NetworkManager state is now C>
Apr 01 15:41:55 manjaro kernel: audit: type=1111 audit(1680363715.259:90): pid=678 uid=0 auid=4294967295 ses=>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3063] device (wlo1): set-hw-addr: reset MAC >
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3665] device (wlo1): state change: prepare ->
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3670] device (wlo1): Activation: (wifi) acce>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3671] device (wlo1): state change: config ->>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3740] device (wlo1): state change: need-auth>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3743] device (wlo1): state change: prepare ->
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3746] device (wlo1): Activation: (wifi) conn>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3747] Config: added 'ssid' value 'EE-Hub-cJ8>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3747] Config: added 'scan_ssid' value '1'
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3747] Config: added 'bgscan' value 'simple:3>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3747] Config: added 'key_mgmt' value 'WPA-PS>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3747] Config: added 'auth_alg' value 'OPEN'
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.3747] Config: added 'psk' value '<hidden>'
Apr 01 15:41:55 manjaro plasmashell[1506]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since>
Apr 01 15:41:55 manjaro plasmashell[1506]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plas>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.4129] device (wlo1): supplicant interface st>
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: SME: Trying to authenticate with cc:d4:2e:bc:1d:64 (SSID='>
Apr 01 15:41:55 manjaro kernel: wlo1: authenticate with cc:d4:2e:bc:1d:64
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.4406] device (wlo1): supplicant interface st>
Apr 01 15:41:55 manjaro kernel: wlo1: send auth to cc:d4:2e:bc:1d:64 (try 1/3)
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: Trying to associate with cc:d4:2e:bc:1d:64 (SSID='EE-Hub-c>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.4451] device (wlo1): supplicant interface st>
Apr 01 15:41:55 manjaro kernel: wlo1: authenticated
Apr 01 15:41:55 manjaro kernel: wlo1: associate with cc:d4:2e:bc:1d:64 (try 1/3)
Apr 01 15:41:55 manjaro kernel: wlo1: RX AssocResp from cc:d4:2e:bc:1d:64 (capab=0x431 status=0 aid=1)
Apr 01 15:41:55 manjaro kernel: wlo1: associated
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: Associated with cc:d4:2e:bc:1d:64
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alph>
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: WPA: Key negotiation completed with cc:d4:2e:bc:1d:64 [PTK>
Apr 01 15:41:55 manjaro wpa_supplicant[912]: wlo1: CTRL-EVENT-CONNECTED - Connection to cc:d4:2e:bc:1d:64 com>
Apr 01 15:41:55 manjaro wpa_supplicant[912]: bgscan simple: Failed to enable signal strength monitoring
Apr 01 15:41:55 manjaro kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.5968] device (wlo1): supplicant interface st>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.5968] device (wlo1): Activation: (wifi) Stag>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.5972] device (wlo1): state change: config ->>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.5981] dhcp4 (wlo1): activation: beginning tr>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7393] dhcp4 (wlo1): state changed new lease,>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7396] policy: set 'EE-Hub-cJ8u' (wlo1) as de>
Apr 01 15:41:55 manjaro dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.reso>
Apr 01 15:41:55 manjaro dbus-daemon[615]: [system] Activation via systemd failed for unit 'dbus-org.freedeskt>
Apr 01 15:41:55 manjaro audit: BPF prog-id=18 op=LOAD
Apr 01 15:41:55 manjaro audit[678]: SYSCALL arch=c000003e syscall=321 success=yes exit=26 a0=5 a1=7ffc20a7797>
Apr 01 15:41:55 manjaro audit: PROCTITLE proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D>
Apr 01 15:41:55 manjaro kernel: audit: type=1334 audit(1680363715.739:91): prog-id=18 op=LOAD
Apr 01 15:41:55 manjaro kernel: audit: type=1300 audit(1680363715.739:91): arch=c000003e syscall=321 success=>
Apr 01 15:41:55 manjaro kernel: audit: type=1327 audit(1680363715.739:91): proctitle=2F7573722F62696E2F4E6574>
Apr 01 15:41:55 manjaro dbus-daemon[615]: [system] Activating via systemd: service name='org.freedesktop.nm_d>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7464] device (wlo1): state change: ip-config>
Apr 01 15:41:55 manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
░░ Subject: A start job for unit NetworkManager-dispatcher.service has begun execution
░░ A start job for unit NetworkManager-dispatcher.service has begun execution.
░░ The job identifier is 829.
Apr 01 15:41:55 manjaro dbus-daemon[615]: [system] Successfully activated service 'org.freedesktop.nm_dispatc>
Apr 01 15:41:55 manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
░░ Subject: A start job for unit NetworkManager-dispatcher.service has finished successfully
░░ A start job for unit NetworkManager-dispatcher.service has finished successfully.
Apr 01 15:41:55 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkM>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7541] device (wlo1): state change: ip-check >
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7544] device (wlo1): state change: secondari>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7548] manager: NetworkManager state is now C>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7553] device (wlo1): Activation: successful,>
Apr 01 15:41:55 manjaro kernel: audit: type=1130 audit(1680363715.749:92): pid=1 uid=0 auid=4294967295 ses=42>
Apr 01 15:41:55 manjaro audit[678]: USYS_CONFIG pid=678 uid=0 auid=4294967295 ses=4294967295 msg='op=statisti>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.7796] audit: op="statistics" interface="wlo1>
Apr 01 15:41:55 manjaro kernel: audit: type=1111 audit(1680363715.776:93): pid=678 uid=0 auid=4294967295 ses=>
Apr 01 15:41:55 manjaro plasmashell[1506]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5591dfdf3d0>
Apr 01 15:41:55 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/co>
Apr 01 15:41:55 manjaro plasmashell[1506]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5591df4e92d>
Apr 01 15:41:55 manjaro NetworkManager[678]: <info> [1680363715.8458] manager: NetworkManager state is now C>
Apr 01 15:41:58 manjaro audit[678]: USYS_CONFIG pid=678 uid=0 auid=4294967295 ses=4294967295 msg='op=statisti>
Apr 01 15:41:58 manjaro NetworkManager[678]: <info> [1680363718.8322] audit: op="statistics" interface="wlo1>
Apr 01 15:41:58 manjaro kernel: audit: type=1111 audit(1680363718.826:94): pid=678 uid=0 auid=4294967295 ses=>
Apr 01 15:42:00 manjaro rtkit-daemon[1569]: Supervising 7 threads of 4 processes of 1 users.
Apr 01 15:42:05 manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 01 15:42:05 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkMa>
Apr 01 15:42:05 manjaro kernel: audit: type=1131 audit(1680363725.759:95): pid=1 uid=0 auid=4294967295 ses=42>
Apr 01 15:42:15 manjaro xdg-desktop-portal-kde[1883]: xdp-kde-background: GetAppState called: no parameters
Apr 01 15:42:18 manjaro rtkit-daemon[1569]: Supervising 7 threads of 4 processes of 1 users.
Apr 01 15:42:18 manjaro rtkit-daemon[1569]: Successfully made thread 2942 of process 2627 owned by '1000' RT >
Apr 01 15:42:18 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:42:33 manjaro pacman-key[903]: -> Disabled 59 keys.
Apr 01 15:42:33 manjaro pacman-key[903]: ==> Updating trust database...
Apr 01 15:42:34 manjaro pacman-key[2990]: gpg: marginals needed: 3 completes needed: 1 trust model: pgp
Apr 01 15:42:34 manjaro pacman-key[2990]: gpg: depth: 0 valid: 1 signed: 20 trust: 0-, 0q, 0n, 0m, 0f, >
Apr 01 15:42:34 manjaro pacman-key[2990]: gpg: depth: 1 valid: 20 signed: 85 trust: 0-, 0q, 0n, 20m, 0f,>
Apr 01 15:42:34 manjaro pacman-key[2990]: gpg: depth: 2 valid: 66 signed: 26 trust: 66-, 0q, 0n, 0m, 0f,>
Apr 01 15:42:34 manjaro pacman-key[2990]: gpg: next trustdb check due at 2023-04-21
Apr 01 15:42:34 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pacman-i>
Apr 01 15:42:34 manjaro systemd[1]: Finished Initialize Pacman keyring.
░░ Subject: A start job for unit pacman-init.service has finished successfully
░░ A start job for unit pacman-init.service has finished successfully.
░░ The job identifier is 81.
Apr 01 15:42:34 manjaro systemd[1]: Reached target Multi-User System.
░░ Subject: A start job for unit multi-user.target has finished successfully
░░ A start job for unit multi-user.target has finished successfully.
░░ The job identifier is 2.
Apr 01 15:42:34 manjaro systemd[1]: Reached target Graphical Interface.
░░ Subject: A start job for unit graphical.target has finished successfully
░░ A start job for unit graphical.target has finished successfully.
░░ The job identifier is 1.
Apr 01 15:42:34 manjaro systemd[1]: Startup finished in 8.370s (firmware) + 2.860s (loader) + 5.992s (kernel)>
░░ Subject: System start-up is now complete
░░ All system services necessary queued for starting at boot have been
░░ started. Note that this does not mean that the machine is now idle as services
░░ might still be busy with completing start-up.
░░ Kernel start-up required 5992520 microseconds.
░░ Initial RAM disk start-up required INITRD_USEC microseconds.
░░ Userspace start-up required 88527179 microseconds.
Apr 01 15:42:34 manjaro kernel: audit: type=1130 audit(1680363754.329:96): pid=1 uid=0 auid=4294967295 ses=42>
Apr 01 15:46:40 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:46:41 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:46:45 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:47:49 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/cont>
Apr 01 15:47:49 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15652>
Apr 01 15:47:49 manjaro systemd[1097]: Started Dolphin - File Manager.
░░ The job identifier is 284.
Apr 01 15:47:49 manjaro dolphin[3409]: org.kde.dolphin: Unknown class "" in session saved data!
Apr 01 15:47:50 manjaro dolphin[3409]: kf.kio.widgets: Cannot read information about filesystem under path "/>
Apr 01 15:48:08 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 21539>
Apr 01 15:48:08 manjaro systemd[1097]: Started Konsole - Terminal.
░░ The job identifier is 288.
Apr 01 15:48:37 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 28298>
Apr 01 15:48:43 manjaro dolphin[3409]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/fi>
Apr 01 15:48:43 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31158>
Apr 01 15:48:43 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31166>
Apr 01 15:48:43 manjaro systemd[1097]: Started Kate - Advanced Text Editor.
░░ The job identifier is 292.
Apr 01 15:48:44 manjaro kate[3678]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Apr 01 15:49:19 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 41547>
Apr 01 15:49:25 manjaro dolphin[3409]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/fi>
Apr 01 15:49:25 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44862>
Apr 01 15:49:25 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 44870>
Apr 01 15:49:25 manjaro systemd[1097]: Started Kate - Advanced Text Editor.
░░ The job identifier is 296.
Apr 01 15:49:25 manjaro kate[3678]: kf.sonnet.core: No language dictionaries for the language: "en_US"
Apr 01 15:50:21 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3080,>
Apr 01 15:50:21 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3084,>
Apr 01 15:50:21 manjaro systemd[1097]: app-org.kde.konsole-b70198c748c14ff19b9b43bb0059ff99.scope: Consumed 6>
Apr 01 15:50:21 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3105,>
Apr 01 15:52:20 manjaro kwin_x11[1428]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45215>
Apr 01 15:53:07 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:53:14 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:53:17 manjaro rtkit-daemon[1569]: Supervising 8 threads of 5 processes of 1 users.
Apr 01 15:53:17 manjaro rtkit-daemon[1569]: Successfully made thread 3859 of process 3343 owned by '1000' RT >
Apr 01 15:53:17 manjaro rtkit-daemon[1569]: Supervising 9 threads of 6 processes of 1 users.
Apr 01 15:53:29 manjaro systemd[1097]: Started Konsole - Terminal.
░░ The job identifier is 300.
Apr 01 15:53:29 manjaro plasmashell[1506]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/cont>
Apr 01 15:56:32 manjaro systemd[1]: Starting Cleanup of Temporary Directories...
░░ Subject: A start job for unit systemd-tmpfiles-clean.service has begun execution
░░ A start job for unit systemd-tmpfiles-clean.service has begun execution.
░░ The job identifier is 891.
Apr 01 15:56:32 manjaro systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
░░ The unit systemd-tmpfiles-clean.service has successfully entered the 'dead' state.
Apr 01 15:56:32 manjaro systemd[1]: Finished Cleanup of Temporary Directories.
░░ Subject: A start job for unit systemd-tmpfiles-clean.service has finished successfully
░░ A start job for unit systemd-tmpfiles-clean.service has finished successfully.
Apr 01 15:56:32 manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd->
Apr 01 15:56:32 manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-t>
Apr 01 15:56:32 manjaro kernel: audit: type=1130 audit(1680364592.466:97): pid=1 uid=0 auid=4294967295 ses=42>
Apr 01 15:56:32 manjaro kernel: audit: type=1131 audit(1680364592.466:98): pid=1 uid=0 auid=4294967295 ses=42>
Apr 01 16:01:01 manjaro CROND[4000]: (root) CMD (run-parts /etc/cron.hourly)
Apr 01 16:01:01 manjaro anacron[4008]: Anacron started on 2023-04-01
lines 3613-3639/3652 100%
Also, I am a casual user of Manjaro, so if you need any more info or asking other quesitons, please think of me as a noob.
Thanks for help in advance.
