Suddenly (I don’t think there was a recent update), when I try to connect my bluetooth headset to my Manjaro computer, I get an error - Connection failed: Protocol not available
Here are some logs -
[reik@reik-msi ~]$ journalctl -u bluetooth | tail
Jan 24 20:32:37 reik-msi bluetoothd[3742]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
Jan 24 20:32:37 reik-msi bluetoothd[3742]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
Jan 24 20:32:37 reik-msi bluetoothd[3742]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Jan 24 20:32:37 reik-msi bluetoothd[3742]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Jan 24 20:32:37 reik-msi bluetoothd[3742]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Jan 24 20:32:37 reik-msi systemd[1]: Started Bluetooth service.
Jan 24 20:32:37 reik-msi bluetoothd[3742]: Starting SDP server
Jan 24 20:32:37 reik-msi bluetoothd[3742]: Bluetooth management interface 1.14 initialized
Jan 24 21:08:09 reik-msi bluetoothd[3742]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 4C:87:5D:0A:F4:C8: Protocol not available
Jan 24 21:12:48 reik-msi bluetoothd[3742]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 4C:87:5D:0A:F4:C8: Protocol not available
Just a possibility:
when I do the journalctl -u bluetooth | tail
command I get almost exactly the same output
The difference is in the version that is reported.
Yours is: Bluetooth management interface 1.14 initialized
and then the errors
That leads me to think that an update is in order - or that a partial upgrade has occured.
It’s just a guess - 1.14 could be the current version in Manjaro.
I’m not on Manjaro, only have it as a VM.
I don’t know if it is the reason of your problem but pulseaudio-modules-bt-git looks like it is installed from the AUR and not the Manjaro repository. Maybe the AUR package is conflicting with some other Manjaro dependency. I would take a careful look at what packages you have installed from the AUR and which packages they have replaced that were preinstalled by Manjaro.
