Bluetooth headphone not connecting and sound not redirected to BT headphone
Hi,
since last update sound is not redirected to bluetooth headphone while they are paired and connected.
For unknown reason I did not have the following line “load-module module-switch-on-connect” in ‘/etc/pulse/default.pa’ file.
So I added it and restarted PC, but nothing changed.
Any idea what could be the issue ?
I use KDE on Manjaro.
thx
I’m facing the same problem here.
  Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=993ff748-547e-43f3-a017-8eec249109be rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 81V7 v: Lenovo IdeaPad S145-15API
    serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15API
  Mobo: LENOVO model: LNVNB161216 v: 2020202020202020NO DPK
    serial: <superuser required> UEFI: LENOVO v: BUCN28WW date: 01/12/2021
  ID-1: BAT0 charge: 17.4 Wh (99.4%) condition: 17.5/30.0 Wh (58.2%) volts: 8.1
    min: 7.4 model: LGC L16L2PB2 type: Li-poly serial: <filter>
    status: not charging cycles: 462
  Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
    built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
    stepping: 1 microcode: 0x8108102
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1789 high: 3663 min/max: 1400/2100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1477 2: 1400
    3: 1400 4: 3663 5: 1400 6: 1400 7: 1477 8: 2100 bogomips: 33548
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 56.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 174f:1176
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0757 built: 2017
    res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
    diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Vega 8 Graphics (raven
    LLVM 15.0.7 DRM 3.49 6.1.31-2-MANJARO) direct-render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3 chip-ID: 0cf3:e500
    class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: <filter>
  Local Storage: total: 1.38 TiB used: 103.82 GiB (7.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fanxiang model: S500PRO 512GB
    lanes: 4 tech: SSD serial: <filter> fw-rev: SN10613 temp: 39.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 103.82 GiB (22.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 3 GiB used: 297.5 MiB (9.7%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 55.5 C mobo: N/A gpu: amdgpu temp: 55.0 C
  Processes: 264 Uptime: 1h 21m wakeups: 19 Memory: available: 5.67 GiB
  used: 4.96 GiB (87.5%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1375 libs: 464 tools: pamac Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.27
