Hi!
Before update i was running KDE 5.26 and kernel 6.1.22-1. My Logi MX Master 3s mouse perfectly discovered by ineternal Foxconn / Hon Hai MediaTek Bluetooth Adapter (0489:e0cd).
After big update to KDE 5.27 i have found mouse does not connect and does not discovered by Bluetooth.
Mouse is alive - it discovers on this laptop from Windows and from another laptop with fresh Manjaro and Intel 210ax adapter and works fine.
With Bold adapter mouse works, Solaar find it. But not Solaar has not ability to discover BT devices.
Yes, I have read bluetooth-le-logitech-mx-master-2-does-not-show-up-in-scan - 77403 theme. Defference is that mouse was working with BT before update and finished after update.
Yes, I have read Arch Wiki. hcitool lescan does not work at all at fresh system, so I revert from deprecated [bluez-utils-compat] to stable [bluez-utils] and still no effect on discover Logi MX 3s mouse.
Also I wonder serial of BT adapter is 000000000.
bluetoothctl works bad too. After update is found some unknown devices, without getting device names. But mouse MAC is not listed at all.
I have tried with 6.1, 6.2 and 6.3 rc kernels - no difference.
bluetoothctl scan on
Discovery started
[CHG] Controller 30:03:C8:2C:FA:AE Discovering: yes
[NEW] Device 30:32:35:9B:8E:75 30-32-35-9B-8E-75
HWscan:
inxi -Fa
Host: xsn018 Kernel: 6.3.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 parameters: BOOT_IMAGE=/vmlinuz-6.3-x86_64
root=UUID=d43e408d-642b-4008-ae11-4464d12df001 rw quiet
cryptdevice=UUID=22035316-b509-4681-8bbc-dcd2df574fad:luks-22035316-b509-4681-8bbc-dcd2df574fad
root=/dev/mapper/luks-22035316-b509-4681-8bbc-dcd2df574fad splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20XKA004CD v: ThinkPad T14 Gen 2a
serial: PF3SHXXX Chassis: type: 10 serial: PF3SHXXX
Mobo: LENOVO model: 20XKA004CD v: SDK0T76XXX WIN serial: L1HF24W0XXX
UEFI: LENOVO v: R1MET51W (1.21 ) date: 09/15/2022
ID-1: BAT0 charge: 51.5 Wh (96.8%) condition: 53.2/50.5 Wh (105.4%)
volts: 12.7 min: 11.5 model: SMP 5B10W51827 type: Li-poly serial: 7053
status: full cycles: 6
Info: model: AMD Ryzen 7 PRO 5850U with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1637 high: 1900 min/max: 1600/4505 boost: enabled
base/boost: 1900/4450 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1900 2: 1600 3: 1600 4: 1900
5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1600 11: 1600 12: 1600
13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 60718
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:1638
class-ID: 0300 temp: 40.0 C
Device-2: Luxvisions Innotech Integrated Camera type: USB driver: uvcvideo
bus-ID: 3-2:2 chip-ID: 30c9:003b class-ID: fe01 serial: 0001
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting,vesa alternate: fbdev dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x408d built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.0-1-MANJARO) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 07:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.3.0-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.67 status: n/a (root, process) with: wireplumber
status: active tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active (root, process)
tools: pacat,pactl
vendor: Lenovo driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0f0 state: down mac: 6c:24:08:50:e7:ce
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlp3s0 state: up mac: 30:03:c8:2c:fa:ad
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: down mac: 6c:24:08:50:e7:cd
IF-ID-1: br-e35c09532441 state: down mac: 02:42:15:90:f6:d2
IF-ID-2: docker0 state: down mac: 02:42:10:92:40:d6
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter type: USB
driver: btusb v: 0.8 bus-ID: 1-4:3 chip-ID: 0489:e0cd class-ID: e001
serial: 000000000
Local Storage: total: 1.82 TiB used: 118.87 GiB (6.4%)
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: S6P1NX0TB01459E
rev: 4B2QEXM7 temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 12 hrs cycles: 26
read-units: 988,257 [505 GB] written-units: 1,925,872 [986 GB]
ID-1: / raw-size: 272.46 GiB size: 267.12 GiB (98.04%)
used: 77.01 GiB (28.8%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-22035316-b509-4681-8bbc-dcd2df574fad
ID-2: /boot raw-size: 1000 MiB size: 965.9 MiB (96.59%)
used: 249.8 MiB (25.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 33.2 MiB (13.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-1: swap-1 type: partition size: 50.78 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 415 Uptime: 1h 14m wakeups: 7 Memory: 30.19 GiB
used: 4.82 GiB (16.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1304
pm: pacman pkgs: 1291 libs: 364 tools: pamac pm: flatpak pkgs: 13
Shell: Bash (su) v: 5.1.16 running-in: konsole inxi: 3.3.26
lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0489:e0cd Foxconn / Hon Hai MediaTek Bluetooth Adapter
Bus 001 Device 002: ID 06cb:00bd Synaptics, Inc. Prometheus MIS Touch Fingerprint Reader
Bus 001 Device 004: ID 046d:c548 Logitech, Inc. Logi Bolt Receiver
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 30c9:003b Luxvisions Innotech Limited Integrated Camera
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg | egrep -iA5 0489
egrep: warning: egrep is obsolescent; using grep -E
[ 1.439652] usb 1-4: New USB device found, idVendor=0489, idProduct=e0cd, bcdDevice= 1.00
[ 1.439661] usb 1-4: New USB device strings: Mfr=5, Product=6, SerialNumber=7
[ 1.439662] usb 1-4: Product: Wireless_Device
[ 1.439663] usb 1-4: Manufacturer: MediaTek Inc.
[ 1.439664] usb 1-4: SerialNumber: 000000000
[ 1.446042] tsc: Refined TSC clocksource calibration: 1911.016 MHz
dmesg | grep Bluetooth
[ 18.645675] Bluetooth: Core ver 2.22
[ 18.647131] Bluetooth: HCI device and connection manager initialized
[ 18.647136] Bluetooth: HCI socket layer initialized
[ 18.647138] Bluetooth: L2CAP socket layer initialized
[ 18.647144] Bluetooth: SCO socket layer initialized
[ 18.931319] Bluetooth: hci0: Device setup in 138616 usecs
[ 18.931322] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 19.243990] Bluetooth: hci0: AOSP extensions version v0.96
[ 19.243993] Bluetooth: hci0: AOSP quality report is not supported
[ 20.698141] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.698144] Bluetooth: BNEP filters: protocol multicast
[ 20.698147] Bluetooth: BNEP socket layer initialized
[ 20.699061] Bluetooth: MGMT ver 1.22
[ 27.847472] Bluetooth: RFCOMM TTY layer initialized
[ 27.847483] Bluetooth: RFCOMM socket layer initialized
[ 27.847486] Bluetooth: RFCOMM ver 1.11
[ 813.340935] Bluetooth: hci0: Name resolve takes too long.
[ 1984.215760] Bluetooth: hci0: Device setup in 138810 usecs
[ 1984.215770] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 1984.545443] Bluetooth: hci0: AOSP extensions version v0.96
[ 1984.545457] Bluetooth: hci0: AOSP quality report is not supported
[ 2063.046686] Bluetooth: hci0: Device setup in 139253 usecs
[ 2063.046696] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[ 2063.367313] Bluetooth: hci0: AOSP extensions version v0.96
[ 2063.367323] Bluetooth: hci0: AOSP quality report is not supported
[ 2161.195304] Bluetooth: hci0: Name resolve takes too long.
