Bluetooth firmware upload failing after 'suspend'
Resuming my laptop after ‘suspend’ results in the bluetooth device no longer functioning, because the firmware upload failes
Bluetooth: hci0: Bootloader revision 0.0 build 2 week 52 2014
Bluetooth: hci0: Device revision is 5
Bluetooth: hci0: Secure boot is enabled
Bluetooth: hci0: OTP lock is enabled
Bluetooth: hci0: API lock is enabled
Bluetooth: hci0: Debug lock is disabled
Bluetooth: hci0: Minimum firmware build 1 week 10 2014
Bluetooth: hci0: Found device firmware: intel/ibt-11-5.sfi
Bluetooth: hci0: Failed to send firmware data (-38)
Sometimes
Bluetooth: hci0: Failed to send firmware data (-110)
The remedy is to completly disable bluetooth, remove all bt/bluetooth kernel modules and start all over again.
This happens since the update to kernel 4.16-rt, under 4.14-rt there was no problem.
Is there anything I can do, short of codeefying the module removal/adding in a shellscript?
Ah, would this explain my problem as well?
It used to be that when I looked at the Bluetooth device manager, my mouse would always show as “paired” even when I had not turned on my mouse. Now, Manjaro can not remember my bluetooth mouse after suspend and boot (and after usb-suspend (?) during lockscreen). The Bluetooth device manager now always shows my mouse as not paired.
Check with
dmesg | grep Blue
in a shell – it may be a device problem, the web is full from reports of a wide range of causes and remedies for bluetooth related problems
I see
quite often at boot. But not always. That never stopped my Bluetooth mouse from working fine before though.
Edit: yup, it’s also in the log now.
When my bluetooth adapter works, I see the following in the log
Bluetooth: hci0: Waiting for firmware download to complete
Bluetooth: hci0: Firmware loaded in 1448401 usecs
Maybe a subsequent try to load the firmware is successfull in your setup? Or the problem is unrelated to/different from mine – it is consistent in my case, firmare loaded bluetooth OK, firmware not loaded bluetooth not ok
First try at boot fails:
[ 11.009298] Bluetooth: hci0: Failed to send firmware data (-38)
A little later it succeeds:
[ 19.963502] Bluetooth: hci0: Firmware loaded in 1599607 usecs
After suspend it also fails and then works:
[ 3339.187438] Bluetooth: hci0: Failed to send firmware data (-38)
[ 3348.240209] Bluetooth: hci0: Firmware loaded in 1696461 usecs
Further investigating this problem, I found out that indeed in my case also, firmware loading does fail from time to time after a reboot; and further that is is sufficient to unload/load the btusb-module
sudo rmmod btusb
sleep 1
sudo modprobe btusb
I have this problem on a new Dell Precision 7540. Anyone know how to fix it???? Right after boot in journal.
Oct 12 15:15:43 josh-pc kernel: Bluetooth: hci0: command 0xfc09 tx timeout
Oct 12 15:15:45 josh-pc kernel: iwlwifi 0000:6e:00.0: BIOS contains WGDS but no WRDS
Oct 12 15:15:51 josh-pc kernel: Bluetooth: hci0: Failed to send firmware data (-110)
No necrobumping please:
Open your own help thread.
