I bought a USB Bluetooth dongle for my manjaro computer but unfortunately, this won’t be recognized when I plug it in.
Can anyone give me some advice, please?
Should I buy a new one that is compatible with manjaro?
how do you know?
how do you check whether it is recognized?
When I plug it in and use the Blueman I see no devices.
Let me know if I’m wrong or I can use another method to make sure
You are a long time member - and should know how to retrieve and provide information.
anyway
apart from info about your hardware
inxi -Fazy
preferably with the thing plugged in
you could use:
journalctl -f
in a terminal
and watch the output as you plug in
and disconnect
your device
you can do a similar thing with:
sudo dmesg -w
in a terminal
both commands will show you
in slightly different format
what the system sees when you plug in and remove the device
The most obvious thing to check (which I didn’t even think of until now) is:
is the bluetooth service started and running?
It might not be - because there was no bluetooth device when you installed the system and therefore no reason to configure the service.
The majority of bluetooth dongles works with Linux. Long time ago - years - I bought a cheap Deltaco bluétooth dongle - as I recall the price was around €8.
Check if it is recognized by listing USB devices
lsusb
Copy/paste the text from the terminal window into a reply - select the text and click the </>
in the comment toolbar and click the reply button.
Example from my system with the Deltaco bt dongle
$ lsusb
Bus 001 Device 010: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
I’ve got this one:
Bus 001 Device 006: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
But still cannot use it on Blueman
inxi -Fazy
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3a81af0d-a5c0-428a-95b7-84fb1fa4afe9 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: PRIME H510M-A v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0820
date: 04/27/2021
Info: model: Intel Core i3-10100 bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 3 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 57616
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: ASUSTeK driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 470.xx+
status: legacy-active (EOL~2023/24) arch: Fermi 2 process: TSMC 28nm
built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 10de:128b class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 54 s-size: 903x508mm (35.55x20.00")
s-diag: 1036mm (40.79")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 55
size: 885x498mm (34.84x19.61") diag: 1015mm (39.98") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 710/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
bus-ID: 1-9.3:5 chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
IF: wlp0s20f0u9u3 state: up mac: <filter>
IF-ID-1: br-44843efba035 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-83967b164190 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth8a39296 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethcdbf368 state: up speed: 10000 Mbps duplex: full
mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 342.81 GiB used: 132.28 GiB (38.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000LNP
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: VC0S032Q temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 01D2 scheme: GPT
ID-1: / raw-size: 145.25 GiB size: 141.91 GiB (97.70%)
used: 44.22 GiB (31.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 7.81 GiB used: 45.5 MiB (0.6%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 325 Uptime: 19m wakeups: 0 Memory: 7.62 GiB
used: 5.86 GiB (76.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1344
pacman: 1330 lib: 336 flatpak: 2 snap: 12 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.19
Maybe here is the problem:
sudo dmesg -w
[ 1390.441797] Bluetooth: hci0: CSR: Failed to suspend the device for our Barrot 8041a02 receive-issue workaround
… because my suggestion to check for it might have been overlooked:
is the service active?
systemctl status bluetooth.service
Yes, active and running
But still can’t use it.
It has the same device id as mine - and I have no issues connecting.
Albeit not blueman but bluedevil on KDE - you may need to do some low level troubleshooting
Check if you have bluez-utils package installed - otherwise install it
which bluetoothctl
Execute the command bluetoothctl which will open a bluetooth controller environment
list
Ensure the controller is powered
power on
Then scan for devices
scan on
Then stop scanning when you have seen it working
scan off
When I use list
command on bluetoothctl
environment I get nothing.
Also after using power on
I get an error: No default controller available
And same error for scan on
command
Then you have other issues
$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 010: ID 046d:0a44 Logitech, Inc. Headset H390
Bus 001 Device 008: ID 0451:8242 Texas Instruments, Inc.
Bus 001 Device 006: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 005: ID 0bc2:ab24 Seagate RSS LLC Backup Plus Portable Drive
Bus 001 Device 004: ID 060b:2312 Solid Year nkey Mechanic LED
Bus 001 Device 002: ID 1532:0060 Razer USA, Ltd RZ01-0213 Gaming Mouse [Lancehead Tournament Edition]
$ bluetoothctl
Agent registered
[bluetooth]# list
Controller 00:1A:7D:DA:71:0F tiger [default]
[bluetooth]# scan on
Discovery started
[CHG] Controller 00:1A:7D:DA:71:0F Discovering: yes
[NEW] Device 76:F7:48:A6:CA:E7 76-F7-48-A6-CA-E7
[NEW] Device 5A:04:CF:99:F6:3E 5A-04-CF-99-F6-3E
# help
Menu main:
Available commands:
advertise Advertise Options Submenu
monitor Advertisement Monitor Options Submenu
scan Scan Options Submenu
gatt Generic Attribute Submenu
admin Admin Policy Submenu
list List available controllers
show [ctrl] Controller information
select <ctrl> Select default controller
devices List available devices
paired-devices List paired devices
system-alias <name> Set controller alias
reset-alias Reset controller alias
power <on/off> Set controller power
pairable <on/off> Set controller pairable mode
discoverable <on/off> Set controller discoverable mode
discoverable-timeout [value] Set discoverable timeout
agent <on/off/capability> Enable/disable agent with given capability
default-agent Set agent as the default one
advertise <on/off/type> Enable/disable advertising with given type
set-alias <alias> Set device alias
scan <on/off/bredr/le> Scan for devices
info [dev] Device information
pair [dev] Pair with device
cancel-pairing [dev] Cancel pairing with device
trust [dev] Trust device
untrust [dev] Untrust device
block [dev] Block device
unblock [dev] Unblock device
remove <dev> Remove device
connect <dev> Connect device
disconnect [dev] Disconnect device
menu <name> Select submenu
version Display version
quit Quit program
exit Quit program
help Display help about this program
export Print environment variables
Can help me to solve the problem(s), please?
I have no idea …
