Bluetooth doesn't work after suspend
After waking up from suspend bluetooth doesn’t start , though wifi works just fine.
Kernel 5.13.4
Well, I’m afraid you won’t get replies from other users if you don’t provide good information.
Check this out (if you haven’t done that yet):
Sorry i ddin’t know what else to provide
Kernel: 5.13.5-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: root=UUID=ee9da72e-87ff-4c77-a150-c1b49e39fcbb rw quiet
udev.log_priority=3 initrd=boot\initramfs-5.13-x86_64.img
Desktop: bspwm 0.9.10 info: polybar dm: GDM 40.1 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05
serial: Chassis: type: 10 v: IdeaPad 5 14ARE05 serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN serial:
UEFI: LENOVO v: DTCN24WW(V1.10) date: 12/25/2020
ID-1: BAT1 charge: 31.1 Wh (59.6%) condition: 52.2/56.5 Wh (92.4%)
volts: 11.9 min: 11.6
model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x31 0x39 0x43 0x33 0x50 0x5650
type: Li-ion serial: status: Unknown cycles: 141
RAM: total: 7.15 GiB used: 4.01 GiB (56.1%)
Array-1: capacity: 64 GiB note: check slots: 2 EC: None
Device-1: DIMM 0 size: 4 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Micron Technology part-no: 4ATF51264HZ-3G2J1
serial: N/A
Device-2: DIMM 0 size: 4 GiB speed: 3200 MT/s type: DDR4
serial: N/A
Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics socket: FP6
bits: 64 type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB bogomips: 31959
Speed: 1397 MHz min/max: 1400/2000 MHz base/boost: 2000/4200 boost: enabled
volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1397
4: 1397 5: 1390 6: 1397 7: 1397 8: 1330
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56ff class-ID: 0e02
Display: server: X.Org 1.20.11 compositor: picom v: git-60eb0 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.5-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.13.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 31.24 GiB (6.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L2
lanes: 4 type: SSD serial: rev: AL2QFXV7 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 31.18 GiB (31.9%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: ee9da72e-87ff-4c77-a150-c1b49e39fcbb
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 59.6 MiB (23.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM_DRV uuid: 48D1-8C46
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 375.69 GiB fs: ntfs
label: Windows-SSD uuid: D2BCD237BCD21637
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: 86EED43FEED428E7
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Elan Micro ELAN:Fingerprint type:
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c4d class-ID: 0000
Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.2 C mobo: 49.0 C gpu: amdgpu temp: 49.0 C
Processes: 297 Uptime: 4h 40m wakeups: 19860 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1248
lib: 378 Shell: fish (sudo) v: 3.3.1 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.06
Has this issue been resolved in the meantime? Have recent kernel patches or distro updates resolved the issue, or do you still have problems with Bluetooth after suspend?
You user experience hasn’t been great… Someone chides you for not providing enough information, sends you to a generic page but doesn’t specify what info is relevant to your case and when you provide all the data you can you get silence.
I’m no guru, but if the issue is still current I’ll do what I can to help.
Hi Ayush you may want to run the following command sudo rfkill list to make sure it has not been blocked if it has the you can run the following command sudo rfkill unblock bluetooth i will also link an artical that i found very useful How to Troubleshoot Bluetooth in Manjaro
let us know if this helps .
This solution unfortunately does not help. It only says to update bluez to latest version, but i already have bluez on latest version and i have the same problem as OP.
when you run sudo rfkill list what happens?
you should get the following list yours will be diffrent make sure you do not have any block .
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hp-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hp-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
8: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
also what ver do you have BlueZ do you have as i see the latest seem to be 5.62 packages list
BlueZ
bluez-libs
bluez-qt
bluez-utils
check to see if they are uptodate
This is output of rfkill before suspend when everything is working and i am listening to music on my bluetooth speaker
➜  ~ rfkill list
0: ideapad_wlan: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: ideapad_bluetooth: Bluetooth
	Soft blocked: yes
	Hard blocked: no
2: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
3: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
This is output of rfkill list after waking up from suspend when bluetooth is constantly off and cannot be turned on
➜  ~ rfkill list
	Soft blocked: no
	Hard blocked: no
	Soft blocked: yes
	Hard blocked: no
	Soft blocked: no
	Hard blocked: no
i already tried systemctl restart bluetooth and systemctl restart bluetooth.service, it did nothing
My bluez is on 5.61-1 but there seems to be no update available for me
➜  ~ pacman -Qi bluez
Version         : 5.61-1
Description     : Daemons for the bluetooth protocol stack
Architecture    : x86_64
URL             : http://www.bluez.org/
Licenses        : GPL2
Groups          : None
Provides        : None
Depends On      : libical  dbus  glib2  alsa-lib  json-c
Optional Deps   : None
Required By     : bluez-tools  gnome-bluetooth  pulseaudio-bluetooth
Optional For    : networkmanager
Conflicts With  : obexd-client  obexd-server
Replaces        : None
Installed Size  : 2,66 MiB
Packager        : Felix Yan <felixonmars@archlinux.org>
Build Date      : czw, 26 sie 2021, 12:42:08
Install Date    : pon, 8 lis 2021, 21:19:37
Install Reason  : Installed as a dependency for another package
Install Script  : No
Validated By    : Signature
ok could you please run the following command
Lastly, verify if the Bluetooth service is enabled and active.
sudo systemctl status bluetooth
Bluetooth not available after Sleep/Startup
Bluetooth gets disable after the restart, sleep or hibernate. This process causes the user to re-enable every time from the taskbar or CLI. As soon as the system resumes (before manually enabling Bluetooth), use the above-mentioned command rfkill to verify adapter settings. If the command output is similar to the above, it confirms that the issue is not with the driver.
hope this help
hello. there are a few threads here about the AX200 intel bluetooth - wifi module, the last fix was to downgrade the firmware. Me personally, installed the latest firmware and the problem seem to be fixed, maybe you could give it a try kernel/git/firmware/linux-firmware.git - Repository of firmware blobs for use with the Linux kernel
Hey, sudo rfkill unblock bluetooth doesnt do anything.
Checking if bluetooth service is active shows that it is active but the output shows some kind of warning that i don’t understand
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
     Active: active (running) since Wed 2021-11-10 18:54:39 CET; 5h 7min ago
       Docs: man:bluetoothd(8)
   Main PID: 792 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 18603)
     Memory: 2.6M
        CPU: 92ms
     CGroup: /system.slice/bluetooth.service
             └─792 /usr/lib/bluetooth/bluetoothd
lis 10 18:55:25 nikodem-20sl bluetoothd[792]: /org/bluez/hci0/dev_30_21_D2_11_98_A1/sep1/fd0: fd(39) ready
lis 10 18:55:25 nikodem-20sl bluetoothd[792]: profiles/audio/avctp.c:avctp_control_confirm() Control: Refusing unexpected connect
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSink/sbc
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSource/sbc
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSink/sbc_xq_453
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSource/sbc_xq_453
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSink/sbc_xq_512
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSource/sbc_xq_512
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSink/sbc_xq_552
lis 10 21:49:48 nikodem-20sl bluetoothd[792]: Endpoint unregistered: sender=:1.67 path=/MediaEndpoint/A2DPSource/sbc_xq_552
