Dear all,
I can’t get my bluetooth running on a new PC. Basically, bluetooth manager doesn’t show any adaptors, when I open the adaptor menu, it only contains the “exit” item. I can enable bluetooth, but that doesn’t do anything other than setting the rfkill soft-blocked flag to no (default is yes).
Inxi:
system:
Host: izumo Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm
root=UUID=dcea1bc2-7b48-4506-8eb4-5f0adf8a0b36 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: Gigabyte product: X870 EAGLE WIFI7 v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X870 EAGLE WIFI7 v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F2
date: 08/23/2024
Info: model: AMD Ryzen 9 9950X bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB40401A
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 600 min/max: 600/5752 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 600 2: 600 3: 600
4: 600 5: 600 6: 600 7: 600 8: 600 9: 600 10: 600 11: 600 12: 600 13: 600
14: 600 15: 600 16: 600 17: 600 18: 600 19: 600 20: 600 21: 600 22: 600
23: 600 24: 600 25: 600 26: 600 27: 600 28: 600 29: 600 30: 600 31: 600
32: 600 bogomips: 274782
apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext bus_lock_detect
cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc
cpb cppc cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe movdir64b movdiri msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_adjust tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd
wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA GA102GL [RTX A6000] driver: N/A alternate: nouveau
non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2230
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 75:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 37.0 C
Display: x11 server: X.org v: 1.21.1.14 compositor: xfwm4 v: 4.18.0
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: EIZO NANAO CG277
serial: 49371028 built: 2018 res: 2560x1440 hz: 30 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
raphael_mendocino LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO)
device-ID: 1002:13c0 memory: 1.95 GiB unified: no
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 75:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 75:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8125
v: 9.014.01-NAPI modules: r8169 pcie: gen: 2 speed: 5 GT/s lanes: 1
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: 10:ff:e0:6c:71:d6
Device-2: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 14c3:7925
class-ID: 0280
IF: wlp8s0 state: down mac: a2:3e:61:53:99:96
Device-3: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
driver: hid-generic,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 9-1.3:4 chip-ID: 0458:6001 class-ID: 0301
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 0489:e124
class-ID: e001 serial: 000000000
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: N/A
Local Storage: total: 1.82 TiB used: 26.68 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 990 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: S7GCNS0X308706L fw-rev: 0B2QKXJ7 temp: 42.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 EVO 1TB
lanes: 4 tech: SSD serial: S7GCNS0X308749H fw-rev: 0B2QKXJ7 temp: 35.9 C
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 26.68 GiB (2.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:6
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 40.8 C mobo: 31.0 C gpu: amdgpu temp: 37.0 C
Fan Speeds (rpm): N/A
Weather:
Report: temperature: 5.69 C (42 F) conditions: overcast clouds wind: from
WSW at 2.6 m/s (9 km/h, 6 mph) cloud cover: 100% humidity: 80%
pressure: 1014 mb (34 in)
Locale: Ludwigshafen am Rhein, RP, Unknown current time: Fr 20 Dez 2024
00:42:25 CET (Europe/Berlin) observation time: Fr 20 Dez 2024 00:15:58 CET
sunrise: 08:19:41 sunset: 16:28:32 Source: OpenWeatherMap.org
Memory: total: 128 GiB available: 123.43 GiB used: 2.69 GiB (2.2%)
Processes: 489 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 49.33 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 256
Packages: pm: pacman pkgs: 1112 libs: 346 tools: pamac pm: flatpak pkgs: 0
Compilers: gcc: 14.2.1 alt: 13 Shell: Bash v: 5.2.37
running-in: xfce4-terminal inxi: 3.3.36
dmesg:
[ 6.659975] Bluetooth: Core ver 2.22
[ 6.659985] NET: Registered PF_BLUETOOTH protocol family
[ 6.659985] Bluetooth: HCI device and connection manager initialized
[ 6.659988] Bluetooth: HCI socket layer initialized
[ 6.659989] Bluetooth: L2CAP socket layer initialized
[ 6.659991] Bluetooth: SCO socket layer initialized
[ 6.692373] Bluetooth: hci0: Opcode 0x0c03 failed: -16
[ 7.609599] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 7.609601] Bluetooth: BNEP filters: protocol multicast
[ 7.609605] Bluetooth: BNEP socket layer initialized
systemctl:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2024-12-20 00:29:50 CET; 21min ago
Invocation: 14847a5e304e4ae6acabb4cbb8fdf7aa
Docs: man:bluetoothd(8)
Main PID: 1012 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 151439)
Memory: 2.1M (peak: 2.6M)
CPU: 10ms
CGroup: /system.slice/bluetooth.service
└─1012 /usr/lib/bluetooth/bluetoothd
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support bap plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support bass plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support mcp plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support vcp plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support micp plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support ccp plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support csip plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: src/plugin.c:init_plugin() System does not support asha plugin
Dez 20 00:29:50 izumo bluetoothd[1012]: Bluetooth management interface 1.23 initialized
