Hi there , I’m getting straight into the topic ; As mentioned in the title manjaro ( single booted ) is not discovering bluetooth devices . If i go to the device settings > Bluetooth and add a new device , its searching for a device forewer and not discovering my bluetooth headset or my android . I tried many ways out there in the internet to solve this but i didn’t found anything as a solution for this .
This is the inxi --admin --verbosity=7 --filter --no-host --width
output
Kernel: 5.4.143-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2926b362-37db-4efb-becd-3a28896fcc84 rw quiet
resume=UUID=843efb71-9e31-4c19-a057-f46b0c0f388f udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland
vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 80CB v: 99.53 serial: <filter> UEFI: Insyde v: F.28
date: 05/17/2019
ID-1: BAT1 charge: 33.0 Wh (100.0%) condition: 33.0/33.0 Wh (100.0%)
volts: 16.7 min: 14.6 model: 131-42-6E HS04041 type: Unknown
serial: <filter> status: Full
RAM: total: 6.74 GiB used: 2.48 GiB (36.8%)
Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
microcode: 7030106 cache: L2: 2 MiB bogomips: 17573
Speed: 998 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz):
1: 998 2: 998 3: 998 4: 998
Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall wdt xsave
xsaveopt
disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
chip-ID: 1002:9851 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: USB
driver: uvcvideo bus-ID: 4-1.1:3 chip-ID: 05c8:0382 class-ID: 0e02
Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.143-1-MANJARO LLVM 12.0.1)
v: 4.5 Mesa 21.2.1 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
class-ID: 0403
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.4.143-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma port: 3100 bus-ID: 02:00.0 chip-ID: 14e4:4365
class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-1.4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Local Storage: total: 931.51 GiB used: 15.91 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUB0N rev: UB00 dev-links: cdrom
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 11.28 GiB (23.1%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 2926b362-37db-4efb-becd-3a28896fcc84
ID-2: /boot/efi raw-size: 1 GiB size: 1022.6 MiB (99.80%)
used: 288 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 26EB-9915
ID-3: /home raw-size: 75 GiB size: 73.27 GiB (97.69%) used: 4.62 GiB (6.3%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 34c87a45-8559-4757-8afe-b76fb1d24130
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 843efb71-9e31-4c19-a057-f46b0c0f388f
ID-1: /dev/sda5 maj-min: 8:5 size: 381 GiB fs: ntfs label: Gaming
uuid: 6C38EEE738EEAEF0
ID-2: /dev/sda6 maj-min: 8:6 size: 273.9 GiB fs: ntfs label: Others
uuid: B0CAF063CAF0276E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-2:3 info: China Resource Semico Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 3-1.4:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
Device-1: 4-1.1:3
info: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: Video
System Temperatures: cpu: 60.0 C mobo: 20.0 C gpu: radeon temp: 54.0 C
Processes: 183 Uptime: 1h 12m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1162 lib: 325
Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
rfkill list
output
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo systemctl status bluetooth
output
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2021-09-15 17:43:32 IST; 1h 14min ago
Docs: man:bluetoothd(8)
Main PID: 751 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 8259)
Memory: 2.9M
CPU: 159ms
CGroup: /system.slice/bluetooth.service
└─751 /usr/lib/bluetooth/bluetoothd
Sep 15 17:43:33 shervin-manjaro bluetoothd[751]: Bluetooth management interface 1.14 initialized
Sep 15 17:43:33 shervin-manjaro bluetoothd[751]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors:>
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/sbc
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/sbc
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/sbc_xq_4>
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/sbc_xq_5>
Sep 15 17:44:34 shervin-manjaro bluetoothd[751]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Waiting for a solution
