Hi! I’m new with manjaro, and hope for your help.
So the problem my games freezes mid games. The whole display freezes , I can’t tab or anything. I can’t switch tty. Only mouse moving and music continue playing.
Before it freeze I have 120+ fps, like game launched on nvidia gpu.
Also I have this error when launching apps in port proton
Debug: Log from RUNTIME and WINE:
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 156 (NV-GLX)
Minor opcode of failed request: 43 ()
Serial number of failed request: 657
Current serial number in output stream: 658
grep: warning: stray \ before -
mhwd -l output
> 0000:01:00.0 (0300:10de:249d) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:46a6) Display controller Intel Corporation:
mhwd -li output
> Installed PCI configs:
inxi -Fazy output
Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=68974c37-53f2-4e30-932b-bf0321a1eadd rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: GIGABYTE product: AORUS 5 SE v: N/A
serial: <superuser required> Chassis: type: 10 v: y.y
Mobo: GIGABYTE model: AORUS 5 SE v: WIN11 serial: <superuser required>
UEFI: American Megatrends LLC. v: FB06 date: 04/13/2022
ID-1: BAT1 charge: 99.0 Wh (100.0%) condition: 99.0/99.0 Wh (100.0%)
volts: 16.9 min: 15.2 model: GIGABYTE Aorus 15 type: Li-ion serial: N/A
status: full
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x42C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 500 high: 784 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 632 4: 400
5: 771 6: 400 7: 585 8: 400 9: 619 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 784 17: 691 18: 721 19: 400 20: 400 bogomips: 107560
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Gigabyte
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: Gigabyte
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:4 chip-ID: 13d3:56a2
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Sharp LQ156M1JW03 built: 2021 res: 1920x1080
hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 2e:00.0
IF: enp46s0 state: down mac: <filter>
IF-ID-1: vpn0 state: down mac: N/A
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 18 state: up address: see --recommends
Local Storage: total: 953.87 GiB used: 226.91 GiB (23.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: AG470S1TB-SI B10
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIOM31.4 temp: 20.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 226.91 GiB (24.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 32.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 509 Uptime: 4d 5h 0m wakeups: 63240 Memory: total: 64 GiB
note: est. available: 62.53 GiB used: 15.37 GiB (24.6%) Init: systemd v: 254
Packages: 1394 pm: pacman pkgs: 1378 libs: 441 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 16 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: guake inxi: 3.3.29
inxi -G output
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] driver: nvidia
v: 535.104.05
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting,nvidia
dri: iris gpu: i915 resolution: 1920x1080~240Hz
