Bluetooth connection problem with HK Onyx Studio 7
Good afternoon, I bought an HK Onyx Studio 7 speaker. At first everything worked fine, and my Manjarobox could connect with to the speaker. But for some reason now it cannot, in a sense. I can connect to the speaker now, but the tunneling gets split. Audio from Netflix and youtube goes through the computer speakers and when I try to test the audio goes to the Bluetooth speaker. At first I use to switch the configuration and that use to work, but now it does not. At first I thought it had to do with the latest upgrade. But after the upgrade it kept on working just fine. I deleted the pulse audio and left the pipewire on my system.
inxi -Faz         ✔
  Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=fb3b8569-3b15-4c53-ab66-d3dd1f3cb627 rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor
    resume=UUID=f2e22fa6-fc97-4195-b99c-425615b3ea4b udev.log_priority=3
  Desktop: GNOME v: 42.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
  Type: Laptop System: LENOVO product: 20U9005MUS v: ThinkPad X1 Carbon Gen 8
  Mobo: LENOVO model: 20U9005MUS v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: N2WET35W (1.25 )
    date: 02/23/2022
  ID-1: BAT0 charge: 49.4 Wh (100.0%) condition: 49.4/51.0 Wh (96.9%)
    volts: 17.2 min: 15.4 model: SMP 5B10W13931 type: Li-poly serial: <filter>
    status: full cycles: 28
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check gen: core 10 built: 2018
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xC (12)
    microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1126 high: 1600 min/max: 400/4900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1432 2: 1600 3: 1600
    4: 1577 5: 703 6: 703 7: 700 8: 700 bogomips: 36812
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Type: srbds mitigation: TSX disabled
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9b41 class-ID: 0300
  Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-8:2 chip-ID: 13d3:56bb class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    compositor: gnome-shell driver: X: loaded: modesetting
    alternate: fbdev,vesa gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
  Message: Wayland GBM/EGL data currently not available.
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-cnl
    alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
    bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 953.87 GiB used: 321.46 GiB (33.7%)
    model: PC SN730 SDBQNTY-1T00-1001 size: 953.87 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 11170101 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
    used: 321.44 GiB (34.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    used: 28 MiB (5.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
  ID-4: /var/log raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
  ID-1: swap-1 type: partition size: 16.41 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 55.0 C pch: 58.0 C mobo: N/A
  Fan Speeds (RPM): fan-1: 3012
  Processes: 356 Uptime: 45m wakeups: 4 Memory: 15.29 GiB
  used: 5.09 GiB (33.3%) Init: systemd v: 250 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1842
  pacman: 1794 lib: 487 flatpak: 36 snap: 12 Shell: Zsh v: 5.9
  running-in: gnome-terminal inxi: 3.3.17
I also think you might need this:
lsmod | grep btusb                                               ✔
btusb                  65536  0
btrtl                  28672  1 btusb
btbcm                  24576  1 btusb
btintel                45056  1 btusb
bluetooth             749568  51 btrtl,btintel,btbcm,bnep,btusb,rfcomm
Also, I believe you might need this as well:
sudo dmesg | grep -i 'bluetooth'                                 ✔
[sudo] password for pookito:
Sorry, try again.
Place your finger on the fingerprint reader
[    5.470600] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[    6.819139] Bluetooth: Core ver 2.22
[    6.819160] NET: Registered PF_BLUETOOTH protocol family
[    6.819161] Bluetooth: HCI device and connection manager initialized
[    6.819165] Bluetooth: HCI socket layer initialized
[    6.819167] Bluetooth: L2CAP socket layer initialized
[    6.819170] Bluetooth: SCO socket layer initialized
[    6.992249] Bluetooth: hci0: Bootloader revision 0.4 build 0 week 30 2018
[    6.993251] Bluetooth: hci0: Device revision is 2
[    6.993254] Bluetooth: hci0: Secure boot is enabled
[    6.993255] Bluetooth: hci0: OTP lock is enabled
[    6.993256] Bluetooth: hci0: API lock is enabled
[    6.993257] Bluetooth: hci0: Debug lock is disabled
[    6.993258] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    6.994754] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[    7.055207] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.055209] Bluetooth: BNEP filters: protocol multicast
[    7.055213] Bluetooth: BNEP socket layer initialized
[    8.885180] Bluetooth: hci0: Waiting for firmware download to complete
[    8.885227] Bluetooth: hci0: Firmware loaded in 1846161 usecs
[    8.885254] Bluetooth: hci0: Waiting for device to boot
[    8.900327] Bluetooth: hci0: Device booted in 14728 usecs
[    8.900365] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[    8.902351] Bluetooth: hci0: Applying Intel DDC parameters completed
[    8.905360] Bluetooth: hci0: Firmware revision 0.4 build 50 week 12 2022
[    8.993859] Bluetooth: RFCOMM TTY layer initialized
[    8.993865] Bluetooth: RFCOMM socket layer initialized
[    8.993868] Bluetooth: RFCOMM ver 1.1
Any help?
Please and Thank you.
