Hi this is my first ever support post so sorry if any of the formatting is weird, my bluetooth has been having some weird issues, currently it will not discover or connect to any bluetooth device, and if I turn bluetooth off from the settings menu it will not turn back on. Earlier rfkill list
showed bluetooth as soft blocked but that hasn’t happened again after I did rfkill unblock bluetooth
. here is the output of inxi no host:
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6c36af5c-1975-456d-ad56-dcee66a8a1ae rw quiet splash apparmor=1
security=apparmor resume=UUID=e5765052-c2e3-495c-bf2e-db783c1b37b5
udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: MOTILE product: M141 v: Standard serial: <filter>
Mobo: MOTILE model: PF4PU1F v: Standard serial: <filter>
UEFI: American Megatrends v: N.1.06 date: 11/27/2019
ID-1: BAT0 charge: 24.5 Wh (58.1%) condition: 42.2/46.7 Wh (90.2%)
volts: 12.9 min: 11.4 model: standard type: Li-ion serial: <filter>
status: Charging
RAM: total: 3.28 GiB used: 2.55 GiB (77.8%)
RAM Report:
Info: Dual Core model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24)
stepping: 1 microcode: 8108102 cache: L2: 1024 KiB bogomips: 20768
Speed: 1348 MHz min/max: 1400/2600 MHz boost: enabled Core speeds (MHz):
1: 1348 2: 2551 3: 1254 4: 1520
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Picasso vendor: Tongfang Hongkong Limited driver: amdgpu
v: kernel bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-2: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.41.0
5.13.11-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Tongfang Hongkong Limited driver: snd_hda_intel v: kernel
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Tongfang Hongkong Limited
driver: snd_hda_intel v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: f000 bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6.4:5 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 119.24 GiB used: 10.94 GiB (9.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Motile model: SSM28128GPTCB3B-S112611
size: 119.24 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 61.3 scheme: GPT
ID-1: / raw-size: 111.73 GiB size: 109.41 GiB (97.93%)
used: 10.14 GiB (9.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6c36af5c-1975-456d-ad56-dcee66a8a1ae
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: A293-1526
ID-1: swap-1 type: partition size: 7.22 GiB used: 827.8 MiB (11.2%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: e5765052-c2e3-495c-bf2e-db783c1b37b5
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-5:2 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b68b
Hub-2: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.2:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-6.4:5 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 60.4 C mobo: N/A gpu: amdgpu temp: 60.0 C
Processes: 252 Uptime: 35m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1134 lib: 294 flatpak: 0
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
