Bluetooth Clicking "Add New Device..." does nothing
Please supply this information when submitting a bug report.
  • What device are you using? Pinebook Pro
  • What edition of Manjaro-ARM is installed? (eg minimal, server, etc.) Latest release. 19.12
  • When did you last run updates and reboot? 5 minutes ago
  • What package contains the bug? not sure.
  • Describe the bug the best you can. What where you doing when the bug happened?
    Clicking add a new device in bluetooth settings does nothing. it shows the button being pressed. but no window comes up with a list of devices. It used to work fine. bluetooth service looks healthy.
  • Any workarounds or known fixes?
    Was able to connect using bluetoothctl from the command line.
I have the same behavior with Plasma on Pinebook Pro.
And "Erreur de segmentation (core dumped)" when bluedevile.
Try this :
Works for me :slight_smile:
Upgrading plasma-integration (5.17.5-2 -> 5.17.5-2.1)... fixes the bug!!!
