Hi everybody,
I experienced twice the same crash after suspend.
It happened just a few seconds after the system seemed to have completely halted: I could hear the HDD restart without notice…
I couldn’t restart. The only way I found has been to remove the battery on the motherboard. Unplug and plug after some minutes (I’ve tried with 2 hours) was not enough.
Before anything, my machine with
inxi -Fxzc
Kernel: 5.15.28-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma 5.24.3 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: ASUSTeK product: K30AM-J_A_F_K31AM-J v: 1004
serial: <superuser required>
Mobo: ASUSTeK model: K30AM-J_A_F_K31AM-J v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 1004
date: 10/23/2015
Device-1: hid-2b:24:13:db:7c:99-battery model: DIAFIELD Keyboard
charge: N/A status: Discharging
Info: dual core model: Intel Celeron J1800 bits: 64 type: MCP
arch: Silvermont rev: 8 cache: L1: 112 KiB L2: 1024 KiB
Speed (MHz): avg: 1736 high: 2139 min/max: 1333/2582 cores: 1: 2139
2: 1333 bogomips: 9671
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
gpu: i915 resolution: 1280x1024~75Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 21.3.7
direct render: Yes
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: ASUSTeK H81M-C driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu
bus-ID: 1-1.4:6
IF: wlp0s20u1u4 state: up mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1.3:4
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 596.18 GiB used: 18.04 GiB (3.0%)
ID-1: /dev/sda vendor: Hitachi model: HTS725032A9A364 size: 298.09 GiB
ID-2: /dev/sdb vendor: Samsung model: HD321KJ size: 298.09 GiB
ID-1: / size: 292.35 GiB used: 18.04 GiB (6.2%) fs: ext4 dev: /dev/sdb1
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 169 Uptime: 34m Memory: 3.72 GiB used: 2.31 GiB (62.1%)
Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1296
Shell: Zsh v: 5.8.1 inxi: 3.3.13
Here the output of journalctl | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Stack trace of thread 812:
#0 0x00007f6aa1c1215a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f6aa1c14c64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x00007f6aa218dc84 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebc84)
#3 0x00007f6aa218ab47 n/a (libQt5Core.so.5 + 0xe8b47)
#4 0x00007f6aa21868cc n/a (libQt5Core.so.5 + 0xe48cc)
#5 0x00007f6aa1c155c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f6aa1c9a584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 818:
#0 0x00007f6aa1c8e2af __poll (libc.so.6 + 0x1062af)
#1 0x00007f6aa0825086 n/a (libglib-2.0.so.0 + 0xab086)
#2 0x00007f6aa07cc455 g_main_context_iteration (libglib-2.0.so.0 + 0x52455)
#3 0x00007f6aa237b08a _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d908a)
#4 0x00007f6aa232739b _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28539b)
#5 0x00007f6aa2189a56 _ZN7QThread4execEv (libQt5Core.so.5 + 0xe7a56)
#6 0x00007f6aa3d78d00 n/a (libQt5Qml.so.5 + 0x2c6d00)
#7 0x00007f6aa21868cc n/a (libQt5Core.so.5 + 0xe48cc)
#8 0x00007f6aa1c155c2 start_thread (libc.so.6 + 0x8d5c2)
#9 0x00007f6aa1c9a584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 880:
#1 0x00007f6aa1c14960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x00007f6aa218dcfc _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebcfc)
#3 0x00007f6aa40bdbef n/a (libQt5Quick.so.5 + 0x200bef)
Stack trace of thread 811:
Stack trace of thread 689:
#1 0x00007f6aa44fd63b n/a (libxcb.so.1 + 0xc63b)
#2 0x00007f6aa44ff37b xcb_wait_for_event (libxcb.so.1 + 0xe37b)
#3 0x00007f6a9d439b12 n/a (libQt5XcbQpa.so.5 + 0x61b12)
mars 21 18:22:56 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18038, resource id: 41943228, major code: 15 (QueryTree), minor code: 0
mars 21 18:22:56 jcw-k30amjafk31amj kernel: audit: type=1131 audit(1647883376.865:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-910-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:22:56 jcw-k30amjafk31amj audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-910-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:22:56 jcw-k30amjafk31amj systemd[1]: systemd-coredump@0-910-0.service: Deactivated successfully.
mars 21 18:22:56 jcw-k30amjafk31amj systemd[1]: systemd-coredump@0-910-0.service: Consumed 5.621s CPU time.
mars 21 18:22:56 jcw-k30amjafk31amj audit: BPF prog-id=0 op=UNLOAD
mars 21 18:22:56 jcw-k30amjafk31amj kernel: audit: type=1334 audit(1647883376.979:93): prog-id=0 op=UNLOAD
mars 21 18:22:56 jcw-k30amjafk31amj kernel: audit: type=1334 audit(1647883376.979:94): prog-id=0 op=UNLOAD
mars 21 18:22:56 jcw-k30amjafk31amj kernel: audit: type=1334 audit(1647883376.979:95): prog-id=0 op=UNLOAD
mars 21 18:22:58 jcw-k30amjafk31amj systemd[517]: Started Konsole - Terminal.
mars 21 18:22:58 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 18731, resource id: 50331733, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:23:00 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20122, resource id: 14681976, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:23:00 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 20123, resource id: 14681976, major code: 14 (GetGeometry), minor code: 0
mars 21 18:23:08 jcw-k30amjafk31amj xdg-desktop-portal-kde[808]: xdp-kde-background: GetAppState called: no parameters
mars 21 18:23:18 jcw-k30amjafk31amj systemd[1]: systemd-hostnamed.service: Deactivated successfully.
mars 21 18:23:18 jcw-k30amjafk31amj audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:23:18 jcw-k30amjafk31amj kernel: audit: type=1131 audit(1647883398.422:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:23:18 jcw-k30amjafk31amj audit: BPF prog-id=0 op=UNLOAD
mars 21 18:23:18 jcw-k30amjafk31amj kernel: audit: type=1334 audit(1647883398.475:97): prog-id=0 op=UNLOAD
mars 21 18:23:18 jcw-k30amjafk31amj kernel: audit: type=1334 audit(1647883398.475:98): prog-id=0 op=UNLOAD
mars 21 18:23:18 jcw-k30amjafk31amj kernel: audit: type=1334 audit(1647883398.475:99): prog-id=0 op=UNLOAD
mars 21 18:23:19 jcw-k30amjafk31amj systemd[1]: blueman-mechanism.service: Deactivated successfully.
mars 21 18:23:19 jcw-k30amjafk31amj audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:23:19 jcw-k30amjafk31amj kernel: audit: type=1131 audit(1647883399.532:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:23:40 jcw-k30amjafk31amj plasma_waitforname[901]: org.kde.knotifications: WaitForName: Service was not registered within timeout
mars 21 18:23:40 jcw-k30amjafk31amj dbus-daemon[539]: [session uid=1000 pid=539] Activated service 'org.kde.KSplash' failed: Process org.kde.KSplash exited with status 1
mars 21 18:25:18 jcw-k30amjafk31amj plasmashell[611]: trying to show an empty dialog
mars 21 18:25:31 jcw-k30amjafk31amj plasmashell[611]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/logic.js:22: TypeError: Cannot read property 'devices' of undefined
mars 21 18:25:31 jcw-k30amjafk31amj kernel: Bluetooth: HIDP (Human Interface Emulation) ver 1.2
mars 21 18:25:31 jcw-k30amjafk31amj kernel: Bluetooth: HIDP socket layer initialized
mars 21 18:25:31 jcw-k30amjafk31amj kernel: hid-generic 0005:04E8:7021.0005: unknown main item tag 0x0
mars 21 18:25:31 jcw-k30amjafk31amj kernel: input: DIAFIELD Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0/bluetooth/hci0/hci0:2/0005:04E8:7021.0005/input/input22
mars 21 18:25:31 jcw-k30amjafk31amj kernel: input: DIAFIELD Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0/bluetooth/hci0/hci0:2/0005:04E8:7021.0005/input/input23
mars 21 18:25:31 jcw-k30amjafk31amj kernel: hid-generic 0005:04E8:7021.0005: input,hidraw4: BLUETOOTH HID v1.1b Keyboard [DIAFIELD Keyboard] on 8c:88:2b:65:26:57
mars 21 18:25:31 jcw-k30amjafk31amj systemd-logind[336]: Watching system buttons on /dev/input/event20 (DIAFIELD Keyboard)
mars 21 18:25:32 jcw-k30amjafk31amj upowerd[667]: treated changed event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.3/1-1.3:1.0/bluetooth/hci0/hci0:2/0005:04E8:7021.0005/power_supply/hid-2b:24:13:db:7c:99-battery
mars 21 18:25:34 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 27405, resource id: 69206021, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:25:36 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29035, resource id: 41943285, major code: 15 (QueryTree), minor code: 0
mars 21 18:25:49 jcw-k30amjafk31amj systemd[517]: Started Dolphin - Gestionnaire de fichiers.
mars 21 18:26:01 jcw-k30amjafk31amj dolphin[1058]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
mars 21 18:26:01 jcw-k30amjafk31amj systemd[517]: Started Kate - Éditeur de texte avancé.
mars 21 18:26:01 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33594, resource id: 69206038, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:26:04 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so : (libaspell.so.15: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:26:04 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so : (libhspell.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:26:04 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so : (libvoikko.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:26:04 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:26:04 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:26:05 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:26:05 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:26:08 jcw-k30amjafk31amj kioslave5[1098]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:27:55 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:27:55 jcw-k30amjafk31amj kate[1083]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:27:55 jcw-k30amjafk31amj kate[1083]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 9891, resource id: 14683996, major code: 40 (TranslateCoords), minor code: 0
mars 21 18:27:55 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43467, resource id: 73400331, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:27:55 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43507, resource id: 71303316, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:27:56 jcw-k30amjafk31amj systemd[517]: app-org.kde.kate-b08987fff52b4fdeb10cfe3e806799fe.scope: Consumed 9.312s CPU time.
mars 21 18:27:56 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43579, resource id: 69206039, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:28:12 jcw-k30amjafk31amj kioslave5[1119]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:28:18 jcw-k30amjafk31amj kioslave5[1129]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:28:19 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45708, resource id: 71303179, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:28:21 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 45749, resource id: 73400331, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:28:23 jcw-k30amjafk31amj kioslave5[1156]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:28:24 jcw-k30amjafk31amj kioslave5[1162]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:28:25 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46538, resource id: 71303179, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:28:26 jcw-k30amjafk31amj kioslave5[1170]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:28:42 jcw-k30amjafk31amj dolphin[1058]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
mars 21 18:28:42 jcw-k30amjafk31amj systemd[517]: Started Kate - Éditeur de texte avancé.
mars 21 18:28:43 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so : (libaspell.so.15: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:28:43 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so : (libhspell.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:28:43 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so : (libvoikko.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:28:43 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:28:43 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:28:44 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:28:44 jcw-k30amjafk31amj kate[1178]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:28:46 jcw-k30amjafk31amj kioslave5[1192]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:29:08 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49936, resource id: 75497483, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:08 jcw-k30amjafk31amj systemd[517]: app-org.kde.kate-93a9dc852cfb4898b27a9c058daeaca2.scope: Consumed 3.994s CPU time.
mars 21 18:29:08 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49954, resource id: 73400437, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:08 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 49972, resource id: 69206069, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:14 jcw-k30amjafk31amj dolphin[1058]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
mars 21 18:29:14 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50607, resource id: 69206070, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:14 jcw-k30amjafk31amj systemd[517]: Started Kate - Éditeur de texte avancé.
mars 21 18:29:14 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 50616, resource id: 69206071, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:15 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so : (libaspell.so.15: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:29:15 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so : (libhspell.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:29:15 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Impossible de charger la bibliothèque /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so : (libvoikko.so.1: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type)"
mars 21 18:29:15 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:29:15 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:29:16 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: No language dictionaries for the language: "fr_FR" trying to load en_US as default
mars 21 18:29:16 jcw-k30amjafk31amj kate[1200]: kf.sonnet.core: No language dictionaries for the language: "en_US"
mars 21 18:29:18 jcw-k30amjafk31amj kioslave5[1214]: Qt: Session management error: networkIdsList argument is NULL
mars 21 18:29:36 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53350, resource id: 75497483, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:36 jcw-k30amjafk31amj systemd[517]: app-org.kde.kate-4d0b2d5b7196449e94ff1c1c0b2a6286.scope: Consumed 4.146s CPU time.
mars 21 18:29:36 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53378, resource id: 73400437, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:36 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 53396, resource id: 69206072, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:40 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54015, resource id: 71303179, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:40 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 54019, resource id: 69206075, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:29:40 jcw-k30amjafk31amj systemd[517]: app-org.kde.dolphin-81b0458a2bc54d789f3a03b35e7fc405.scope: Consumed 15.095s CPU time.
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56158, resource id: 67108871, major code: 19 (DeleteProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56172, resource id: 67108871, major code: 19 (DeleteProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56173, resource id: 67108871, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56174, resource id: 67108871, major code: 19 (DeleteProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56175, resource id: 67108871, major code: 19 (DeleteProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56176, resource id: 67108871, major code: 19 (DeleteProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56177, resource id: 67108871, major code: 7 (ReparentWindow), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56178, resource id: 67108871, major code: 6 (ChangeSaveSet), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56179, resource id: 67108871, major code: 2 (ChangeWindowAttributes), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56180, resource id: 67108871, major code: 10 (UnmapWindow), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56383, resource id: 67108954, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:31:07 jcw-k30amjafk31amj systemd[517]: app-org.kde.konsole-9bea619cc07f4d6dbaa80f5bcf10508c.scope: Consumed 7.661s CPU time.
mars 21 18:31:07 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 56411, resource id: 50331740, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:31:15 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 58410, resource id: 41943328, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:31:15 jcw-k30amjafk31amj systemd[517]: Started Configuration du système - Configuration du système.
mars 21 18:31:17 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:31:17 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:31:17 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:220:5: QML Heading: Binding loop detected for property "verticalAlignment"
mars 21 18:31:18 jcw-k30amjafk31amj systemsettings[1280]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mars 21 18:31:18 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:31:18 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:31:18 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_landingpage/contents/ui/main.qml:130:9: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
mars 21 18:31:18 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_landingpage/contents/ui/main.qml:20:9: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
mars 21 18:31:18 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 60048, resource id: 69206028, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:32:08 jcw-k30amjafk31amj systemsettings[1280]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mars 21 18:32:08 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:08 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:08 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_workspace/contents/ui/main.qml:18:5: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
mars 21 18:32:09 jcw-k30amjafk31amj systemsettings[1280]: qml: The item SubCategoryPage_QMLTYPE_114(0x56326c76e770) is already in the PageRow
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "0 instead of 3 arguments to message {%1, par %2 (%3)} supplied before conversion."
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "0 instead of 2 arguments to message {%1 (%2)} supplied before conversion."
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:220:5: QML Heading: Binding loop detected for property "verticalAlignment"
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:27 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_sddm/contents/ui/main.qml:22:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
mars 21 18:32:28 jcw-k30amjafk31amj systemsettings[1280]: qml: The item SubCategoryPage_QMLTYPE_114(0x56326c76e770) is already in the PageRow
mars 21 18:32:28 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_sddm/contents/ui/main.qml:22:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
mars 21 18:32:28 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "0 instead of 2 arguments to message {%1 (%2)} supplied before conversion."
mars 21 18:32:28 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "0 instead of 3 arguments to message {%1, par %2 (%3)} supplied before conversion."
mars 21 18:32:34 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_sddm/contents/ui/Advanced.qml:18:5: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:220:5: QML Heading: Binding loop detected for property "verticalAlignment"
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_autostart/contents/ui/main.qml:22:13: QML InlineMessage: Cannot anchor to an item that isn't a parent or sibling.
mars 21 18:32:40 jcw-k30amjafk31amj systemsettings[1280]: qml: The item SubCategoryPage_QMLTYPE_114(0x56326c76e770) is already in the PageRow
mars 21 18:32:45 jcw-k30amjafk31amj systemsettings[1280]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mars 21 18:32:45 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:45 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:45 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm5_kded/contents/ui/main.qml:35:13: QML ColumnLayout: Cannot anchor to an item that isn't a parent or sibling.
mars 21 18:32:45 jcw-k30amjafk31amj systemsettings[1280]: qml: The item SubCategoryPage_QMLTYPE_114(0x56326c76e770) is already in the PageRow
mars 21 18:32:59 jcw-k30amjafk31amj systemsettings[1280]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mars 21 18:32:59 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:59 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to all of them.
mars 21 18:32:59 jcw-k30amjafk31amj systemsettings[1280]: file:///usr/share/kpackage/kcms/kcm_smserver/contents/ui/main.qml:36:5: QML FormLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredHeight"
mars 21 18:32:59 jcw-k30amjafk31amj systemsettings[1280]: qml: The item SubCategoryPage_QMLTYPE_114(0x56326c76e770) is already in the PageRow
mars 21 18:34:27 jcw-k30amjafk31amj systemsettings[1280]: Detected systemd 0
mars 21 18:34:27 jcw-k30amjafk31amj systemsettings[1280]: Persistent partition size found to: 299362 MB
mars 21 18:34:27 jcw-k30amjafk31amj systemsettings[1280]: Volatile partition size found to: 1903 MB
mars 21 18:34:27 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:34:30 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: Refreshing session list...
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: "Successfully read /etc/systemd/system.conf"
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: "Successfully read /etc/systemd/journald.conf"
mars 21 18:34:31 jcw-k30amjafk31amj systemsettings[1280]: "Successfully read /etc/systemd/logind.conf"
mars 21 18:35:22 jcw-k30amjafk31amj kwin_x11[579]: kwin_core: XCB error: 152 (BadDamage), sequence: 11745, resource id: 14686478, major code: 143 (DAMAGE), minor code: 2 (Destroy)
mars 21 18:35:22 jcw-k30amjafk31amj kwin_x11[579]: kwin_core: XCB error: 3 (BadWindow), sequence: 11746, resource id: 67109207, major code: 129 (SHAPE), minor code: 6 (Input)
mars 21 18:35:22 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11747, resource id: 67109207, major code: 2 (ChangeWindowAttributes), minor code: 0
mars 21 18:35:51 jcw-k30amjafk31amj systemd[1]: Starting Cleanup of Temporary Directories...
mars 21 18:35:51 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:35:54 jcw-k30amjafk31amj systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
mars 21 18:35:54 jcw-k30amjafk31amj audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:35:54 jcw-k30amjafk31amj audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:35:54 jcw-k30amjafk31amj systemd[1]: Finished Cleanup of Temporary Directories.
mars 21 18:35:54 jcw-k30amjafk31amj kernel: audit: type=1130 audit(1647884154.087:101): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:35:54 jcw-k30amjafk31amj kernel: audit: type=1131 audit(1647884154.087:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 21 18:35:54 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:35:54 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:35:54 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:35:54 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:35:56 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:35:56 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:35:56 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:35:56 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:35:59 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:35:59 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:35:59 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:35:59 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:01 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:01 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:01 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:01 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:04 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:04 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:04 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:04 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:06 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:06 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:06 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:06 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:09 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:09 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:09 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:09 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:11 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:11 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:11 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:11 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:13 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:13 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:13 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:14 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:16 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:16 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:16 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:16 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:19 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:19 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:19 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:19 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:21 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:21 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:21 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:21 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:24 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:24 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:24 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:24 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:26 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:26 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:26 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:26 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:29 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:29 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:29 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:36:29 jcw-k30amjafk31amj systemsettings[1280]: Refreshing system units...
mars 21 18:36:31 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:36:31 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:36:31 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:38:00 jcw-k30amjafk31amj kwin_x11[579]: kwin_core: XCB error: 152 (BadDamage), sequence: 23515, resource id: 14687301, major code: 143 (DAMAGE), minor code: 2 (Destroy)
mars 21 18:38:00 jcw-k30amjafk31amj kwin_x11[579]: kwin_core: XCB error: 3 (BadWindow), sequence: 23516, resource id: 67109293, major code: 129 (SHAPE), minor code: 6 (Input)
mars 21 18:38:00 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 23517, resource id: 67109293, major code: 2 (ChangeWindowAttributes), minor code: 0
mars 21 18:40:26 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30001, resource id: 14685461, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:40:26 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 30002, resource id: 14685461, major code: 14 (GetGeometry), minor code: 0
mars 21 18:40:31 jcw-k30amjafk31amj systemd[517]: Started Firefox - Navigateur Web.
mars 21 18:40:31 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:40:32 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:40:32 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:40:32 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:40:32 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:40:33 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:40:33 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:40:33 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:40:33 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:40:34 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:40:34 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:40:34 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:40:34 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:40:35 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:40:35 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:40:35 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:40:35 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:40:37 jcw-k30amjafk31amj xdg-desktop-portal-kde[808]: xdp-kde-settings: Read called with parameters:
mars 21 18:40:37 jcw-k30amjafk31amj xdg-desktop-portal-kde[808]: xdp-kde-settings: group: "org.freedesktop.appearance"
mars 21 18:40:37 jcw-k30amjafk31amj xdg-desktop-portal-kde[808]: xdp-kde-settings: key: "color-scheme"
mars 21 18:40:40 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 5 threads of 3 processes of 1 users.
mars 21 18:40:41 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 5 threads of 3 processes of 1 users.
mars 21 18:40:41 jcw-k30amjafk31amj rtkit-daemon[677]: Successfully made thread 1464 of process 1357 owned by '1000' RT at priority 10.
mars 21 18:40:41 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:40:41 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33690, resource id: 14688226, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:40:41 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 33691, resource id: 14688226, major code: 14 (GetGeometry), minor code: 0
mars 21 18:40:42 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:40:43 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:40:46 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:41:05 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:41:20 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:41:32 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:42:53 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:43:03 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:43:07 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:46:22 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:46:23 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:48:53 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:50:11 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:50:15 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:50:20 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 6 threads of 4 processes of 1 users.
mars 21 18:50:21 jcw-k30amjafk31amj rtkit-daemon[677]: Successfully made thread 2008 of process 1896 owned by '1000' RT at priority 10.
mars 21 18:50:21 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 7 threads of 5 processes of 1 users.
mars 21 18:52:49 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33787, resource id: 14688219, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:52:49 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 33788, resource id: 14688219, major code: 14 (GetGeometry), minor code: 0
mars 21 18:52:51 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34567, resource id: 50331749, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:52:51 jcw-k30amjafk31amj systemd[517]: Started Konsole - Terminal.
mars 21 18:52:51 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:52:51 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 34627, resource id: 50331750, major code: 18 (ChangeProperty), minor code: 0
mars 21 18:52:52 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:52:52 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:52:52 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:52:52 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:52:53 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:52:53 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:52:53 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:52:53 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:52:53 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36131, resource id: 14695545, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:52:53 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 36132, resource id: 14695545, major code: 14 (GetGeometry), minor code: 0
mars 21 18:52:54 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:52:54 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:52:54 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:52:54 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:52:55 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:52:55 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:52:55 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:52:55 jcw-k30amjafk31amj systemsettings[1280]: Refreshing user units...
mars 21 18:52:56 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 unit} not supplied before conversion."
mars 21 18:52:56 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 active} not supplied before conversion."
mars 21 18:52:56 jcw-k30amjafk31amj systemsettings[1280]: kf.i18n: "Plural argument to message {1 displayed} not supplied before conversion."
mars 21 18:53:16 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 38391, resource id: 14695719, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:53:16 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 38392, resource id: 14695719, major code: 14 (GetGeometry), minor code: 0
mars 21 18:53:32 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42064, resource id: 14696030, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:53:32 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 42065, resource id: 14696030, major code: 14 (GetGeometry), minor code: 0
mars 21 18:54:19 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 46745, resource id: 14696355, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:54:19 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 46746, resource id: 14696355, major code: 14 (GetGeometry), minor code: 0
mars 21 18:54:55 jcw-k30amjafk31amj polkitd[284]: Registered Authentication Agent for unix-process:2174:204467 (system bus name :1.103 [/sbin/flatpak list], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
mars 21 18:54:55 jcw-k30amjafk31amj polkitd[284]: Unregistered Authentication Agent for unix-process:2174:204467 (system bus name :1.103, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale C)
mars 21 18:55:57 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 7 threads of 5 processes of 1 users.
mars 21 18:59:19 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63774, resource id: 14696692, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 18:59:19 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 63775, resource id: 14696692, major code: 14 (GetGeometry), minor code: 0
mars 21 19:01:01 jcw-k30amjafk31amj CROND[2285]: (root) CMD (run-parts /etc/cron.hourly)
mars 21 19:01:01 jcw-k30amjafk31amj CROND[2284]: (root) CMDEND (run-parts /etc/cron.hourly)
mars 21 19:03:19 jcw-k30amjafk31amj rtkit-daemon[677]: Supervising 7 threads of 5 processes of 1 users.
mars 21 19:06:42 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 61052, resource id: 14698127, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 19:06:42 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 61053, resource id: 14698127, major code: 14 (GetGeometry), minor code: 0
mars 21 19:08:11 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4410, resource id: 14704148, major code: 3 (GetWindowAttributes), minor code: 0
mars 21 19:08:11 jcw-k30amjafk31amj kwin_x11[579]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4411, resource id: 14704148, major code: 14 (GetGeometry), minor code: 0
Difficult for me to see the problem out of this output.
The only thing I can think of is that I disabled balooctl
this afternoon, after checking which process was continuously writing on the disk.
EDIT: What happened, I can’t say. But I did not change anything and there is no more problem!
EDIT2: It did happen again! Meanwhile, I did not change anything in the system apart accepting 2 minor mods this moning fom the package manager. Again, I had to open the machine and remove the motherbard’s battery for a while.
