I have a Notebook HP 15s-fq1034nl fresh install Manjaro XFCE with a RTL8822CE with integrated bluetooth (via usb) and everything works fine till i suspend the system.
After resume the Bluetooth disappears completely from the system and the blue applet is gone, inxi
will no more list any Bluetooth card whereas the WiFi will continue working.
I understand now that the issue has nothing to do with Manjaro or XFCE, as I tried many other distributions and i get the same problem with Bluetooth after suspend.
I tried with every kernel from 5.4 to 5.12 but still same problem.
Only system in which it works after suspend is Windows.
Here is my full inxi
output:
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Laptop System: HP product: HP Laptop 15s-fq1xxx v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 86C9 v: 56.32 serial: <filter> UEFI: AMI v: F.13
date: 07/15/2020
ID-1: BAT0 charge: 42.4 Wh (100.2%) condition: 42.3/42.3 Wh (100.0%)
volts: 12.8 min: 11.4 model: HP Primary type: Li-ion serial: N/A
status: Unknown
RAM: total: 7.47 GiB used: 1.73 GiB (23.1%)
RAM Report:
Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake rev: 5 cache: L2: 8 MiB bogomips: 23968
Speed: 1200 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1200 2: 1201
3: 1201 4: 1201 5: 1200 6: 1201 7: 1201 8: 1201
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G7 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56c9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:34c8
class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Report: ID: hci0 state: up address: <filter>
Message: No LVM data was found.
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30
class-ID: 0104
Local Storage: total: 476.94 GiB used: 19.27 GiB (4.0%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG40ZNV512G KIOXIA
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
rev: HP00AE00 temp: 22.9 C scheme: GPT
ID-1: / size: 105.13 GiB used: 19.27 GiB (18.3%) fs: ext4
dev: /dev/nvme0n1p7 label: N/A uuid: ab183c13-8d2d-4881-8c8e-717fbc5d056c
ID-2: /boot/efi size: 511 MiB used: 332 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p5 label: N/A uuid: 801E-FFE8
ID-1: swap-1 type: partition size: 3.96 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 label: N/A
uuid: e1d9f914-be64-4f16-834f-5c09ad6571ac
ID-1: /dev/nvme0n1p1 size: 260 MiB fs: vfat label: SYSTEM uuid: 0842-FA09
ID-2: /dev/nvme0n1p10 size: 78.24 GiB fs: ext4 label: N/A
uuid: 79e7fe7d-19cd-472f-aa2c-50ac1609edc8
ID-3: /dev/nvme0n1p11 size: 65.06 GiB fs: ext4 label: N/A
uuid: 3a447d65-7860-4e6b-b370-7839dcf744b5
ID-4: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-5: /dev/nvme0n1p3 size: 63.28 GiB fs: ntfs label: Windows
uuid: 1C8AE57E8AE554B4
ID-6: /dev/nvme0n1p4 size: 529 MiB fs: ntfs label: Windows RE tools
uuid: 2E24C82B24C7F3BD
ID-7: /dev/nvme0n1p8 size: 78.75 GiB fs: ext4 label: N/A
uuid: f06022e7-45a9-45fd-8218-f734d173c54c
ID-8: /dev/nvme0n1p9 size: 78.53 GiB fs: ext4 label: N/A
uuid: 225f6048-05ef-4423-995a-aa90a269bb48
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: IMC Networks HP TrueVision HD Camera type: Video
Device-2: 1-7:3 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c00 class-ID: 0000
Device-3: 1-10:4 info: Realtek 802.11ac WLAN Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 234 Uptime: 11m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1191 Shell: Bash v: 5.1.0
running-in: xfce4-terminal inxi: 3.3.03
I’ve already tried:
in
/etc/tlp.conf
change#USB_BLACKLIST_BTUSB=0
toUSB_BLACKLIST_BTUSB=1
but that didn’t work. -
Put
autoenable=true
in/etc/bluetooth/main.conf
but that made no difference either. -
After suspend tried:
sudo rmmod btusb
and then
sudo modprobe btusb
But nothing happened neither.
