Hi.
I have an old pc and put manjaro xfce there and i can’t make my bluetooth work.
it works on my manjaro kde.
thank you.
Hi.
thank you.
Do you have installed bluez and bluez-utils? If not then install them running:
sudo pacman -S bluez bluez-utils
Load the generic bluetooth driver:
sudo modprobe btusb
Then enable and start the bluetooth.service
sudo systemctl enable bluetooth.service --now
i tried typing this code sir but my bluetooth still doesn’t work.
actually, the system detects the bluetooth dongle but can’t see my bluetooth speaker.
the bluetooth hardware I have doesn’t support linux. I bought a new one and it works now. thank you.
