Bluetooth can't connect to devices, fails saying org.bluez.Error.Failed br-connection-timeout
I installed manjaro gnome on my Redmibook 14 pro and I can’t connect to devices via bluetooth. In the settings for bluetooth no devices are shown. I tried finding a solution on the internet but that didn’t help.
Here is an inxi --admin --verbosity=7 --filter --no-host command output
  Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=f2ff5777-9d34-4b4b-9a2a-1af95aaa5cd9 rw quiet splash apparmor=1
  Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM
    v: 45.0.1 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: TIMI product: Redmi Book Pro 14 2022 v: N/A
  Mobo: TIMI model: TM2107 v: V54C2 serial: <superuser required> UEFI: TIMI
    v: RMARB4B0P1010 date: 06/28/2023
  ID-1: BAT0 charge: 34.1 Wh (60.5%) condition: 56.4/56.0 Wh (100.7%)
    power: 11.4 W volts: 15.5 min: 15.4 model: SCUD R14B06W type: Li-ion
    serial: <filter> status: discharging
  System RAM: total: 16 GiB note: est. available: 14.82 GiB
    used: 5.82 GiB (39.3%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 5 6600H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1014 high: 2462 min/max: 400/4564 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1331 2: 400 3: 2462
    4: 400 5: 400 6: 1937 7: 1305 8: 400 9: 1406 10: 400 11: 1337 12: 400
    bogomips: 79080
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate
    ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx
    mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
    ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
    perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
    v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
    wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Rembrandt [Radeon 680M] vendor: Xiaomi driver: amdgpu
    v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 39.0 C
  Device-2: SunplusIT XiaoMi USB 2.0 Webcam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 2b7e:b557
  Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: BOE Display 0x0a92 built: 2022 res: 2560x1600
    dpi: 215 gamma: 1.2 size: 302x189mm (11.89x7.44") diag: 356mm (14")
    ratio: 16:10 modes: max: 2560x1600 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
    drv: radeonsi inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
    16.0.6 DRM 3.54 6.6.8-2-MANJARO) device-ID: 1002:1681 memory: 500 MiB
    unified: no display-ID: :0.0
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Xiaomi
    bus-ID: 03:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Xiaomi
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
    class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Xiaomi driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-1: Opticis Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2 chip-ID: 0cb8:c559
  Report: btmgmt ID: hci0 rfk-id: 33 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
  Local Storage: total: 476.94 GiB used: 18.16 GiB (3.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: ANXA0105 temp: 30.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 18.16 GiB (3.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: f2ff5777-9d34-4b4b-9a2a-1af95aaa5cd9
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: F2C7-5795
  Device-1: 1-3:2 info: FPC Sensor Controller L:0001 FW:021.26.2.031
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 10a5:9201 class-ID: 0000
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: Opticis Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0cb8:c559 class-ID: e001 serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: SunplusIT XiaoMi USB 2.0 Webcam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 2b7e:b557 class-ID: 0e02
    serial: <filter>
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 40.2 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Fan Speeds (rpm): N/A
  Processes: 340 Uptime: 8d 13h 7m wakeups: 32 Init: systemd v: 254
  Packages: pm: pacman pkgs: 1242 libs: 352 tools: gnome-software,pamac
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.31
I also read that rfkill list info might be useful:
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
33: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
So when I go into bluetoothctl and try to pair with my headphones it finds them, pairs with them, but can’t connect. It just tries to connect for a long time and then terminates because of timeout. Here’s an ouput:
[bluetooth]# [NEW] Device 74:2A:8A:8B:D1:5D JBL TUNE510BT
Attempting to pair with 74:2A:8A:8B:D1:5D
[CHG] Device 74:2A:8A:8B:D1:5D Connected: yes
Attempting to connect to 74:2A:8A:8B:D1:5D
Failed to connect: org.bluez.Error.Failed br-connection-timeout
Don’t really know why it’s happening. I hope some of you will help me.
Well the device you would like to connect to is simply not responding to the request or answered in time. Probably the PIN is needed on the the other device? No idea.
