Bluetooth cannot detect any device and cannot be detected by other devices
Hello! I have a Dell Vostro 5568 with Intel Killer 1550(AC9260NGW), I installed Manjaro KDE and found that I cannot use bluetooth to connect anything but wireless works fine.
I tried solutions from archwiki and other posts, but seemed to get worse. I’m new to using Linux and don’t know what to do next. Any help would greatly appreciated.
Here’s some information that might help.
$ /usr/lib/bluetooth/bluetoothd -n -d
bluetoothd[6576]: Bluetooth daemon 5.68
bluetoothd[6576]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
bluetoothd[6576]: src/main.c:parse_config_string() General.DiscoverableTimeout = 0
D-Bus setup failed: Connection ":1.88" is not allowed to own the service "org.bluez" due to security policies in the configuration file
bluetoothd[6576]: src/main.c:main() Unable to get on D-Bus
this executed under normal privileges.
# /usr/lib/bluetooth/bluetoothd -n -d
bluetoothd[7603]: Bluetooth daemon 5.68
bluetoothd[7603]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
bluetoothd[7603]: src/main.c:parse_config_string() General.DiscoverableTimeout = 0
D-Bus setup failed: Name already in use
bluetoothd[7603]: src/main.c:main() Unable to get on D-Bus
this executed under root privileges.
$ sudo inxi --admin --verbosity=7 --filter --width
  Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=c458fc26-81c2-4903-b2b1-9d56ce3ea05a rw quiet splash
    resume=UUID=70db792e-7f01-4c2d-bd2b-5f451552e5a4 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Dell product: Vostro 5568 v: N/A serial: <filter>
    Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0927W0 v: A00 serial: <filter> UEFI: Dell v: 1.20.0
    date: 03/11/2022
  ID-1: BAT0 charge: 22.9 Wh (100.0%) condition: 22.9/42.0 Wh (54.6%)
    volts: 12.6 min: 11.4 model: Samsung SDI DELL CYMGM04 type: Li-ion
    serial: <filter> status: full
  System RAM: total: 8 GiB available: 7.66 GiB used: 3.89 GiB (50.8%)
    igpu: 32 MiB
  Device-1: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 4 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: curr: 1.2
    min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: Micron
    part-no: 4ATF51264HZ-2G3B1 serial: <filter>
  Device-2: DIMM 2 type: DDR4 detail: synchronous unbuffered (unregistered)
    part-no: 4ATF51264HZ-2G3E2 serial: <filter>
  Info: model: Intel Core i7-7500U socket: U3E1 bits: 64 type: MT MCP
    arch: Amber/Kaby Lake note: check gen: core 7 level: v3 note: check
    built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF2
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2425 high: 2900 min/max: 400/3500 base/boost: 2600/2700
    scaling: driver: intel_pstate governor: powersave volts: 0.8 V
    ext-clock: 100 MHz cores: 1: 2900 2: 1000 3: 2900 4: 2900 bogomips: 23209
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
    class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia
    v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d
    class-ID: 0302
  Device-3: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:568a
  Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x06a9 built: 2015 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel HD Graphics 620 (KBL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_skl
    bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
  API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.74 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Wireless-AC 9260 vendor: Rivet Networks driver: iwlwifi
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0
    chip-ID: 8086:2526 class-ID: 0280
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: utun state: unknown speed: 10 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
    all]
  Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5
    chip-ID: 8087:0025 class-ID: e001
  Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 3.0
    lmp-v: 5.1 sub-v: 100 hci-v: 5.1 rev: 100
  Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
    link-mode: peripheral accept service-classes: rendering, capturing, object
    transfer, audio, telephony
  Local Storage: total: 704.24 GiB used: 365.44 GiB (51.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-9WS142
    family: Laptop HDD size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B sata: 2.6 speed: 3.0 Gb/s tech: HDD rpm: 5400
    serial: <filter> fw-rev: LVM1 temp: 36 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 12d 20h cycles: 2475
    Old-Age: g-sense error rate: 427 Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: X400 M.2 2280 256GB
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0012 temp: 39 C
    scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 112d 1h cycles: 3047
    read: 42.33 TiB written: 16.66 TiB
  ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%)
    used: 60.21 GiB (26.8%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
    maj-min: 8:18 label: N/A uuid: c458fc26-81c2-4903-b2b1-9d56ce3ea05a
    used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
    label: N/A uuid: 2FF6-B0AC
  ID-3: /run/media/nyan/MPB raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
    used: 305.23 GiB (65.5%) fs: btrfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: MPB uuid: 9285d0eb-d1ed-476e-bafa-4ca0b1bdab1f
    dev: /dev/sdb3 maj-min: 8:19 label: swap
    uuid: 70db792e-7f01-4c2d-bd2b-5f451552e5a4
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-4:2 info: Lenovo Ultraslim Plus Wireless Keyboard and Mouse
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 17ef:6022 class-ID: 0301
  Device-2: 1-5:3 info: Realtek Integrated Webcam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0bda:568a class-ID: 0e02 serial: <filter>
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-4: 1-8:5 info: Intel Wireless-AC 9260 Bluetooth Adapter
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-5: 1-9:6 info: Validity Sensors VFS5011 Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
    chip-ID: 138a:0011 class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 45.0 C pch: 41.5 C mobo: 41.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 4431
  Processes: 255 Uptime: 2h 17m wakeups: 1 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 1415 pm: pacman pkgs: 1404 libs: 444 tools: pamac,yay pm: flatpak
  pkgs: 11 Shell: Sudo (sudo) v: 1.9.14p1 default: Bash v: 5.1.16
  running-in: alacritty inxi: 3.3.28
$ bluetoothctl
Agent registered
[bluetooth]# list
Controller 94:B8:6D:F4:01:68 DESU [default]
[bluetooth]#
The list appears when I open “Add new device” window in GUI bluetooth settings, when close that window it appears
[CHG] Controller 94:B8:6D:F4:01:68 Discovering: no
$ sudo dmesg | grep blu
$ rfkill
ID TYPE      DEVICE      SOFT      HARD
 0 bluetooth hci0   unblocked unblocked
 1 wlan      phy0   unblocked unblocked
$ journalctl --catalog --priority=3 --boot=-1 | grep blu
8月 06 17:26:14 DESU bluetoothd[7535]: src/main.c:main() Unable to get on D-Bus
8月 06 17:28:36 DESU bluetoothd[7671]: src/main.c:main() Unable to get on D-Bus
8月 06 17:30:58 DESU bluetoothd[7780]: Failed to set mode: Failed (0x03)
8月 06 17:30:59 DESU bluetoothd[7780]: Failed to set mode: Failed (0x03)
8月 06 17:31:20 DESU bluetoothd[7785]: src/main.c:main() Unable to get on D-Bus
$ systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Sun 2023-08-06 18:01:22 CST; 2h 24min ago
       Docs: man:bluetoothd(8)
   Main PID: 460 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 9378)
     Memory: 2.8M
        CPU: 92ms
     CGroup: /system.slice/bluetooth.service
             └─460 /usr/lib/bluetooth/bluetoothd
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/aptx
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/aptx
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/sbc
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/sbc
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/sbc_xq_453
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/sbc_xq_453
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/sbc_xq_512
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/sbc_xq_512
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSink/sbc_xq_552
8月 06 18:01:38 DESU bluetoothd[460]: Endpoint registered: sender=:1.59 path=/MediaEndpoint/A2DPSource/sbc_xq_552
