Hi.
My PC was running 24 hrs, and after a power outage in the neighborhood, the bluetooth (BT) becomes disabled.
Before the power outage, the BT worked fine and can connect to my BT headset.
Currently, the BT icon appears grey in task tray, and cannot be enabled through system setting.
My system:
KDE Plasma 5.26.5
Kernel: 6.1.12.1
# rfkill list all
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Mon 2023-03-06 20:48:07 +08; 33min ago
Docs: man:bluetoothd(8)
Main PID: 3773 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18976)
Memory: 860.0K
CPU: 22ms
CGroup: /system.slice/bluetooth.service
└─3773 /usr/lib/bluetooth/bluetoothd
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: MinConnectionInterval=(0)
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: MaxConnectionInterval=(0)
Mar 06 20:48:07 X570S-APAX-MJR systemd[1]: Started Bluetooth service.
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: ConnectionLatency=(0)
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: ConnectionSupervisionTimeout=(0)
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: Autoconnecttimeout=(0)
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: AdvMonAllowlistScanDuration=300(300)
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: AdvMonNoFilterScanDuration=500(500)
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: Starting SDP server
Mar 06 20:48:07 X570S-APAX-MJR bluetoothd[3773]: Bluetooth management interface 1.22 initialized
Considering the issue only arise after power outage, and the above seems to be in order, where else should I troubleshoot?
Thanks.
