Thanks @Wollie for taking a look!
I am not dual booting.
Here are the outputs:
inxi -zv8:
**System:**
**Kernel:** 6.18.0-1-MANJARO **arch:** x86_64 **bits:** 64 **compiler:** gcc **v:** 15.2.1
**clocksource:** tsc **avail:** hpet,acpi_pm
**parameters:** BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64
root=UUID=3df6426e-3ffb-4dcd-bcb4-ee19b6f6ec76 rw quiet splash
resume=UUID=7092b49d-a928-4af0-bc33-47e91b7f722e udev.log_priority=3
**Desktop:** KDE Plasma **v:** 6.5.3 **tk:** Qt **v:** N/A **wm:** kwin_wayland **dm:** SDDM
**Distro:** Manjaro **base:** Arch Linux
**Machine:**
**Type:** Desktop **System:** PCSpecialist **product:** Amd Am5 Workstation **v:** N/A
**serial:**
**Mobo:** ASUSTeK **model:** TUF GAMING B850-PLUS WIFI **v:** Rev 1.xx
**serial:** **part-nu:** 3222318 **uuid:** ab4f0ed6-9711-34c2-374e-a0ad9f239736
**Firmware:** UEFI **vendor:** American Megatrends **v:** 1079 **date:** 07/21/2025
**Battery:**
**Device-1:** hidpp_battery_1 **model:** Logitech Wireless Keyboard **serial:**
**charge:** 55% (should be ignored) **rechargeable:** yes **status:** discharging
**Device-2:** hidpp_battery_2 **model:** Logitech MX Vertical Advanced Ergonomic
Mouse **serial:** **charge:** 50% (should be ignored) **rechargeable:** yes
**status:** charging
**Memory:**
**System RAM:** **total:** 32 GiB **available:** 30.5 GiB **used:** 8.07 GiB (26.5%)
**Array-1:** **capacity:** 256 GiB **slots:** 4 **modules:** 1 **EC:** None
**max-module-size:** 64 GiB **note:** est.
**Device-1:** Channel-A DIMM 0 **type:** no module installed
**Device-2:** Channel-A DIMM 1 **type:** DDR5 **detail:** synchronous unbuffered
(unregistered) **size:** 32 GiB **speed:** 4800 MT/s **volts:** **curr:** 1.1 **min:** 1.1
**max:** 1.1 **width (bits):** **data:** 64 **total:** 64 **manufacturer:** Corsair
**part-no:** CMK5X32G2B56Z40A2 **serial:** N/A
**Device-3:** Channel-B DIMM 0 **type:** no module installed
**Device-4:** Channel-B DIMM 1 **type:** no module installed
**PCI Slots:**
**Slot:** 0 **type:** PCIe **gen:** 4 **status:** in use **length:** long **volts:** 3.3
**bus-ID:** 00:01.1 **children:** **1:** 01:00.0 **class-ID:** 0300 **type:** display **2:** 01:00.1
**class-ID:** 0403 **type:** audio
**Slot:** 1 **type:** PCIe **gen:** 4 **status:** available **length:** long **volts:** 3.3
**bus-ID:** 00:1f.7
**Slot:** 2 **type:** PCIe **gen:** 4 **status:** available **length:** short **volts:** 3.3
**bus-ID:** 00:1f.7
**Slot:** 3 **type:** PCIe **gen:** 4 **status:** available **length:** short **volts:** 3.3
**bus-ID:** 00:1f.7
**Slot:** N/A **type:** N/A **status:** in use **info:** M.2 **length:** long **volts:** 3.3
**bus-ID:** 00:01.2 **children:** **1:** 02:00.0 **class-ID:** 0108 **type:** mass-storage
**Slot:** N/A **type:** N/A **status:** available **info:** M.2 **length:** long **volts:** 3.3
**bus-ID:** 00:1f.7
**bus-ID:** 00:1f.7
**Slot:** N/A **type:** N/A **status:** in use **info:** M.2 **length:** short **volts:** 3.3
**bus-ID:** 04:0b.0
**CPU:**
**Info:** **model:** AMD Ryzen 7 9700X **socket:** AM5 **bits:** 64 **type:** MT MCP **arch:** Zen 5
**gen:** 5 **level:** v4 **note:** check **built:** 2024+ **process:** TSMC n4 (4nm)
**family:** 0x1A (26) **model-id:** 0x44 (68) **stepping:** 0 **microcode:** 0xB404035
**Topology:** **cpus:** 1x **dies:** 1 **clusters:** 1 **cores:** 8 **threads:** 16 **tpc:** 2
**smt:** enabled **cache:** **L1:** 640 KiB **desc:** d-8x48 KiB; i-8x32 KiB **L2:** 8 MiB
**desc:** 8x1024 KiB **L3:** 32 MiB **desc:** 1x32 MiB
**Speed (MHz):** **avg:** 5473 **min/max:** 605/5582 **boost:** enabled
**base/boost:** 3800/5550 **scaling:** **driver:** amd-pstate-epp **governor:** powersave
**volts:** 1.3 V **ext-clock:** 100 MHz **cores:** **1:** 5473 **2:** 5473 **3:** 5473 **4:** 5473
**5:** 5473 **6:** 5473 **7:** 5473 **8:** 5473 **9:** 5473 **10:** 5473 **11:** 5473 **12:** 5473
**13:** 5473 **14:** 5473 **15:** 5473 **16:** 5473 **bogomips:** 121378
**Flags:** 3dnowprefetch abm adx aes amd_lbr_pmc_freeze amd_lbr_v2 aperfmperf
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
**Vulnerabilities:**
**Type:** gather_data_sampling **status:** Not affected
**Type:** ghostwrite **status:** Not affected
**Type:** indirect_target_selection **status:** Not affected
**Type:** itlb_multihit **status:** Not affected
**Type:** l1tf **status:** Not affected
**Type:** mds **status:** Not affected
**Type:** meltdown **status:** Not affected
**Type:** mmio_stale_data **status:** Not affected
**Type:** old_microcode **status:** Not affected
**Type:** reg_file_data_sampling **status:** Not affected
**Type:** retbleed **status:** Not affected
**Type:** spec_rstack_overflow **mitigation:** IBPB on VMEXIT only
**Type:** spec_store_bypass **mitigation:** Speculative Store Bypass disabled via
**Type:** spectre_v1 **mitigation:** usercopy/swapgs barriers and \__user pointer
**Type:** spectre_v2 **mitigation:** Enhanced / Automatic IBRS; IBPB:
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
**Type:** srbds **status:** Not affected
**Type:** tsa **status:** Not affected
**Type:** tsx_async_abort **status:** Not affected
**Type:** vmscape **mitigation:** IBPB on VMEXIT
**Graphics:**
**Device-1:** NVIDIA AD104 \[GeForce RTX 4070 Ti\] **vendor:** Gigabyte **driver:** nvidia
**v:** 575.64.05 **alternate:** nouveau,nova_core,nvidia_drm **non-free:** 550-580.xx+
**status:** current (as of 2025-11) **arch:** Lovelace **code:** AD1xx
**process:** TSMC n4 (5nm) **built:** 2022+ **pcie:** **gen:** 4 **speed:** 16 GT/s **lanes:** 16
**ports:** **active:** HDMI-A-2 **empty:** DP-2,DP-3,DP-4 **bus-ID:** 01:00.0
**chip-ID:** 10de:2782 **class-ID:** 0300
**Device-2:** Advanced Micro Devices \[AMD/ATI\] Granite Ridge \[Radeon Graphics\]
**vendor:** ASUSTeK **driver:** amdgpu **v:** kernel **arch:** RDNA-2 **code:** Navi-2x
**process:** TSMC n7 (7nm) **built:** 2020-22 **pcie:** **gen:** 4 **speed:** 16 GT/s
**lanes:** 16 **ports:** **active:** none **empty:** DP-1,HDMI-A-1,Writeback-1
**bus-ID:** 0c:00.0 **chip-ID:** 1002:13c0 **class-ID:** 0300 **temp:** 46.0 C
**Display:** unspecified **server:** X.Org **v:** 24.1.9 **with:** Xwayland **v:** 24.1.9
**compositor:** kwin_wayland **driver:** **X:** **loaded:** amdgpu,nvidia
**unloaded:** modesetting,nouveau **alternate:** fbdev,nv,vesa **dri:** radeonsi
**gpu:** nvidia,nvidia-nvswitch **display-ID:** :1 **screens:** 1
**Screen-1:** 0 **s-res:** 3840x2160 **s-dpi:** 96 **s-size:** 1016x572mm (40.00x22.52")
**s-diag:** 1166mm (45.9")
**Monitor-1:** HDMI-A-2 **model:** Gigabyte AORUS FV43U **serial:**
**built:** 2021 **res:** **mode:** 3840x2160 **hz:** 144 **scale:** 100% (1) **dpi:** 104 **gamma:** 1.2
**chroma:** **red:** **x:** 0.694 **y:** 0.302 **green:** **x:** 0.220 **y:** 0.714 **blue:** **x:** 0.149
**y:** 0.067 **white:** **x:** 0.314 **y:** 0.329 **size:** 941x529mm (37.05x20.83")
**diag:** 690mm (27.2") **ratio:** 16:9 **modes:** 3840x2160, 2560x1440, 1920x1080,
1680x1050, 1280x1024, 1440x900, 1280x960, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480
**EDID-Warnings:** **1:** parse_edid: unhandled CEA mode 97 **2:** parse_edid:
unhandled CEA mode 118 **3:** parse_edid: unhandled CEA mode 93 **4:** parse_edid:
unknown tag 112
**API:** EGL **v:** 1.5 **hw:** **drv:** nvidia **drv:** amd radeonsi **platforms:** **device:** 0
**drv:** nvidia **device:** 2 **drv:** radeonsi **device:** 3 **drv:** swrast **gbm:** **drv:** nvidia
**surfaceless:** **drv:** nvidia **x11:** **drv:** nvidia **inactive:** wayland,device-1
**API:** OpenGL **v:** 4.6.0 **compat-v:** 4.5 **vendor:** nvidia mesa **v:** 575.64.05
**glx-v:** 1.4 **direct-render:** yes **renderer:** NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
**memory:** 11.71 GiB
**API:** Vulkan **v:** 1.4.328 **layers:** 7 **device:** 0 **type:** discrete-gpu **name:** NVIDIA
GeForce RTX 4070 Ti **driver:** nvidia **v:** 575.64.05 **device-ID:** 10de:2782
**surfaces:** N/A **device:** 1 **type:** integrated-gpu **name:** AMD Ryzen 7 9700X
8-Core Processor (RADV RAPHAEL_MENDOCINO) **driver:** mesa radv
**v:** 25.3.1-arch1.2 **device-ID:** 1002:13c0 **surfaces:** N/A
**Info:** **Tools:** **api:** clinfo, eglinfo, glxinfo, vulkaninfo
**de:** kscreen-console,kscreen-doctor **gpu:** nvidia-settings,nvidia-smi
**wl:** wayland-info **x11:** xdpyinfo, xprop, xrandr
**Audio:**
**Device-1:** NVIDIA AD104 High Definition Audio **vendor:** Gigabyte
**driver:** snd_hda_intel **v:** kernel **pcie:** **gen:** 4 **speed:** 16 GT/s **lanes:** 16
**bus-ID:** 01:00.1 **chip-ID:** 10de:22bc **class-ID:** 0403
**Device-2:** Advanced Micro Devices \[AMD/ATI\] Radeon High Definition Audio
\[Rembrandt/Strix\] **vendor:** ASUSTeK **driver:** snd_hda_intel **v:** kernel **pcie:**
**gen:** 4 **speed:** 16 GT/s **lanes:** 16 **bus-ID:** 0c:00.1 **chip-ID:** 1002:1640
**class-ID:** 0403
**Device-3:** Advanced Micro Devices \[AMD\] Family 17h/19h/1ah HD Audio
**vendor:** ASUSTeK **driver:** snd_hda_intel **v:** kernel **pcie:** **gen:** 4 **speed:** 16 GT/s
**lanes:** 16 **bus-ID:** 0c:00.6 **chip-ID:** 1022:15e3 **class-ID:** 0403
**API:** ALSA **v:** k6.18.0-1-MANJARO **status:** kernel-api **with:** aoss
**type:** oss-emulator **tools:** alsactl,alsamixer,amixer
**Server-1:** sndiod **v:** N/A **status:** off **tools:** aucat,midicat,sndioctl
**Server-2:** JACK **v:** 1.9.22 **status:** off **tools:** N/A
**Server-3:** PipeWire **v:** 1.4.9 **status:** n/a (root, process) **with:**
**1:** pipewire-pulse **status:** active **2:** wireplumber **status:** active
**3:** pipewire-alsa **type:** plugin **tools:** pactl,pw-cat,pw-cli,wpctl
**Network:**
**Device-1:** Realtek RTL8125 2.5GbE **vendor:** ASUSTeK **driver:** r8169 **v:** kernel
**pcie:** **gen:** 2 **speed:** 5 GT/s **lanes:** 1 **port:** e000 **bus-ID:** 08:00.0
**chip-ID:** 10ec:8125 **class-ID:** 0200
**IF:** eno1 **state:** down **mac:**
**Device-2:** MEDIATEK **vendor:** AzureWave **driver:** mt7925e **v:** kernel **pcie:**
**gen:** 2 **speed:** 5 GT/s **lanes:** 1 **port:** N/A **bus-ID:** 09:00.0 **chip-ID:** 14c3:7925
**class-ID:** 0280
**IF:** wlp9s0 **state:** up **mac:**
**IP v4:** **type:** dynamic noprefixroute **scope:** global
**broadcast:**
**IP v6:** **type:** noprefixroute **scope:** link
**IF-ID-1:** docker0 **state:** down **mac:**
**IP v4:** **scope:** global **broadcast:**
**Info:** **services:** NetworkManager, systemd-timesyncd, wpa_supplicant
**WAN IP:**
**Bluetooth:**
**Message:** No bluetooth data found.
**Logical:**
**Message:** No logical block device data found.
**RAID:**
**Message:** No RAID data found.
**Drives:**
**Local Storage:** **total:** 11.83 TiB **used:** 2.98 TiB (25.2%)
**ID-1:** /dev/nvme0n1 **maj-min:** 259:0 **vendor:** Crucial **model:** CT2000P310SSD8
**size:** 1.82 TiB **block-size:** **physical:** 512 B **logical:** 512 B **speed:** 63.2 Gb/s
**lanes:** 4 **tech:** SSD **serial:** **fw-rev:** V8CR001 **temp:** 35.9 C
**scheme:** GPT
**SMART:** yes **health:** PASSED **on:** 38d 11h **cycles:** 79
**read-units:** 3,947,571 \[2.02 TB\] **written-units:** 5,931,808 \[3.03 TB\]
**ID-2:** /dev/sda **maj-min:** 8:0 **vendor:** Seagate **model:** ST8000NT001-3LZ101
**size:** 7.28 TiB **block-size:** **physical:** 4096 B **logical:** 512 B **sata:** 3.3
**speed:** 6.0 Gb/s **tech:** HDD **rpm:** 7200 **serial:** **fw-rev:** EN01
**temp:** 38 C **scheme:** GPT
**SMART:** yes **state:** enabled **health:** PASSED **on:** 38d 17h **cycles:** 76
**read:** 1.52 TiB **written:** 4.56 TiB **Pre-Fail:** **attribute:** Spin_Retry_Count
**value:** 100 **worst:** 100 **threshold:** 97
**ID-3:** /dev/sdb **maj-min:** 8:16 **vendor:** Seagate **model:** ST3000DM001-1ER166
**family:** Barracuda 7200.14 (AF) **size:** 2.73 TiB **block-size:** **physical:** 4096 B
**logical:** 512 B **sata:** 3.1 **speed:** 6.0 Gb/s **tech:** HDD **rpm:** 7200
**serial:** **fw-rev:** CC45 **temp:** 34 C **scheme:** GPT
**SMART:** yes **state:** enabled **health:** PASSED **on:** 1y 177d 16h **cycles:** 527
**read:** 180.95 TiB **written:** 4.25 TiB **Pre-Fail:** **attribute:** Spin_Retry_Count
**Message:** No optical or floppy data found.
**Partition:**
**ID-1:** / **raw-size:** 1.79 TiB **size:** 1.76 TiB (98.37%) **used:** 96.03 GiB (5.3%)
**fs:** ext4 **block-size:** 4096 B **dev:** /dev/nvme0n1p2 **maj-min:** 259:2 **label:** N/A
**uuid:** 3df6426e-3ffb-4dcd-bcb4-ee19b6f6ec76
**ID-2:** /boot/efi **raw-size:** 300 MiB **size:** 299.4 MiB (99.80%)
**used:** 324 KiB (0.1%) **fs:** vfat **block-size:** 512 B **dev:** /dev/nvme0n1p1
**maj-min:** 259:1 **label:** N/A **uuid:** 8142-7FA7
**ID-3:** /mnt/diskas **raw-size:** 7.28 TiB **size:** 7.22 TiB (99.20%)
**used:** 2.88 TiB (39.9%) **fs:** ext4 **block-size:** 4096 B **dev:** /dev/sda1
**maj-min:** 8:1 **label:** N/A **uuid:** 67264752-b73b-483f-bd72-0226a005ffc1
**Swap:**
**Kernel:** **swappiness:** 60 (default) **cache-pressure:** 100 (default) **zswap:** yes
**compressor:** zstd **max-pool:** 20%
**ID-1:** swap-1 **type:** partition **size:** 33.56 GiB **used:** 0 KiB (0.0%)
**priority:** -2 **dev:** /dev/nvme0n1p3 **maj-min:** 259:3 **label:** swap
**uuid:** 7092b49d-a928-4af0-bc33-47e91b7f722e
**Unmounted:**
**ID-1:** /dev/sdb1 **maj-min:** 8:17 **size:** 2.73 TiB **fs:** exfat **label:** bakup
**uuid:** 78FD-FB17
**USB:**
**Hub-1:** 1-0:1 **info:** hi-speed hub with single TT **ports:** 12 **rev:** 2.0
**speed:** 480 Mb/s (57.2 MiB/s) **lanes:** 1 **mode:** 2.0 **chip-ID:** 1d6b:0002
**class-ID:** 0900
**Hub-2:** 1-4:3 **info:** ASMedia ASM1074 High-Speed hub **ports:** 4 **rev:** 2.1
**speed:** 480 Mb/s (57.2 MiB/s) **lanes:** 1 **mode:** 2.0 **power:** 100mA
**chip-ID:** 174c:2074 **class-ID:** 0900
**Device-1:** 1-11:8 **info:** ASUSTek AURA LED Controller **type:** HID
**driver:** hid-generic,usbhid **interfaces:** 2 **rev:** 2.0 **speed:** 12 Mb/s (1.4 MiB/s)
**lanes:** 1 **mode:** 1.1 **power:** 16mA **chip-ID:** 0b05:19af **class-ID:** 0300
**serial:**
**Hub-3:** 2-0:1 **info:** super-speed hub **ports:** 5 **rev:** 3.1
**speed:** 20 Gb/s (2.33 GiB/s) **lanes:** 2 **mode:** 3.2 gen-2x2 **chip-ID:** 1d6b:0003
**class-ID:** 0900
**Hub-4:** 2-4:2 **info:** ASMedia ASM1074 SuperSpeed hub **ports:** 4 **rev:** 3.0
**speed:** 5 Gb/s (596.0 MiB/s) **lanes:** 1 **mode:** 3.2 gen-1x1 **power:** 8mA
**chip-ID:** 174c:3074 **class-ID:** 0900
**Hub-5:** 3-0:1 **info:** hi-speed hub with single TT **ports:** 2 **rev:** 2.0
**class-ID:** 0900
**Hub-6:** 3-2:2 **info:** Realtek RTS5411 Hub **ports:** 5 **rev:** 2.1
**speed:** 480 Mb/s (57.2 MiB/s) **lanes:** 1 **mode:** 2.0 **chip-ID:** 0bda:5411
**class-ID:** 0900
**Device-1:** 3-2.2:4 **info:** Logitech MX Vertical Advanced Ergonomic Mouse
**type:** mouse,keyboard,HID **driver:** logitech-hidpp-device,usbhid **interfaces:** 3
**rev:** 2.0 **speed:** 12 Mb/s (1.4 MiB/s) **lanes:** 1 **mode:** 1.1 **power:** 500mA
**chip-ID:** 046d:c08a **class-ID:** 0300 **serial:**
**Device-2:** 3-2.5:3 **info:** Realtek HID Device **type:** HID
**driver:** hid-generic,usbhid **interfaces:** 1 **rev:** 2.0
**chip-ID:** 0bda:1100 **class-ID:** 0300
**Hub-7:** 4-0:1 **info:** super-speed hub **ports:** 2 **rev:** 3.1
**speed:** 10 Gb/s (1.16 GiB/s) **lanes:** 1 **mode:** 3.2 gen-2x1 **chip-ID:** 1d6b:0003
**class-ID:** 0900
**Hub-8:** 4-2:2 **info:** Realtek Hub **ports:** 2 **rev:** 3.2
**speed:** 5 Gb/s (596.0 MiB/s) **lanes:** 1 **mode:** 3.2 gen-1x1 **chip-ID:** 0bda:0411
**class-ID:** 0900
**Hub-9:** 5-0:1 **info:** hi-speed hub with single TT **ports:** 2 **rev:** 2.0
**class-ID:** 0900
**Device-1:** 5-1:2 **info:** Logitech Nano Receiver **type:** keyboard,mouse
**driver:** logitech-djreceiver,usbhid **interfaces:** 2 **rev:** 2.0
**speed:** 12 Mb/s (1.4 MiB/s) **lanes:** 1 **mode:** 1.1 **power:** 98mA
**chip-ID:** 046d:c534 **class-ID:** 0301
**Hub-10:** 6-0:1 **info:** super-speed hub **ports:** 2 **rev:** 3.1
**class-ID:** 0900
**Hub-11:** 7-0:1 **info:** hi-speed hub with single TT **ports:** 1 **rev:** 2.0
**class-ID:** 0900
**Sensors:**
**System Temperatures:** **cpu:** 73.2 C **mobo:** 45.5 C **gpu:** amdgpu **temp:** 46.0 C
**Fan Speeds (rpm):** N/A
**Repos:**
**Packages:** 1802 **pm:** pacman **pkgs:** 1755 **libs:** 504 **tools:** pamac **pm:** flatpak
**pkgs:** 47
**Active pacman repo servers in:** /etc/pacman.d/mirrorlist
**1:** https://mirrors.cicku.me/manjaro/stable/$repo/$arch
**2:** https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
**3:** https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
**4:** https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
**5:** https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
**6:** https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
**7:** https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
**8:** https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
**Processes:**
**CPU top:** 5 of 444
**1:** **cpu:** 109% **command:** whatsie **pid:** 3455 **mem:** 356.9 MiB (1.1%)
**2:** **cpu:** 109% **command:** whatsie **pid:** 9645 **mem:** 397.8 MiB (1.2%)
**3:** **cpu:** 13.0% **command:** systemd-journald **pid:** 446 **mem:** 298.5 MiB (0.9%)
**4:** **cpu:** 8.2% **command:** plasmashell **pid:** 1307 **mem:** 949.0 MiB (3.0%)
**5:** **cpu:** 8.2% **command:** firefox **pid:** 18859 **mem:** 824.8 MiB (2.6%)
**Memory top:** 5 of 444
**1:** **mem:** 1418.1 MiB (4.5%) **command:** firefox **pid:** 1600 **cpu:** 7.7%
**2:** **mem:** 949.0 MiB (3.0%) **command:** plasmashell **pid:** 1307 **cpu:** 8.2%
**3:** **mem:** 824.8 MiB (2.6%) **command:** firefox **pid:** 18859 **cpu:** 8.2%
**4:** **mem:** 774.7 MiB (2.4%) **command:** firefox **pid:** 17217 **cpu:** 1.8%
**5:** **mem:** 621.7 MiB (1.9%) **command:** firefox **pid:** 14158 **cpu:** 2.2%
**Info:**
**Processes:** 444 **Power:** **uptime:** 2h 34m **states:** freeze,mem,disk **suspend:** deep
**avail:** s2idle **wakeups:** 0 **hibernate:** platform **avail:** shutdown, reboot,
suspend, test_resume **image:** 12.14 GiB **services:** org_kde_powerdevil,
power-profiles-daemon, upowerd **Init:** systemd **v:** 258 **default:** graphical
**tool:** systemctl
**Compilers:** **clang:** 21.1.6 **gcc:** 1
5.2.1 **alt:** 14 **Shell:** Bash (su) **v:** 5.3.8
**running-in:** konsole **inxi:** 3.3.40
fdisk -l:
**Disk /dev/sda: 7.28 TiB, 8001563222016 bytes, 15628053168 sectors**
Disk model: ST8000NT001-3LZ1
Units: sectors of 1 \* 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: E963677E-86B7-4E7E-BEE5-9ED95B4FFCA2
**Device** **Start** **End** **Sectors** **Size** **Type**
/dev/sda1 2048 15628052479 15628050432 7.3T Microsoft basic data
**Disk /dev/sdb: 2.73 TiB, 3000592982016 bytes, 5860533168 sectors**
Disk model: ST3000DM001-1ER1
Disklabel type: gpt
Disk identifier: 2EDE8121-4187-4982-8F63-17600B54C9DE
/dev/sdb1 2048 5860532223 5860530176 2.7T Microsoft basic data
**Disk /dev/nvme0n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors**
Disk model: CT2000P310SSD8
Disklabel type: gpt
Disk identifier: A82B728A-361F-4D30-93AB-D97AF9508AB2
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 3836646243 3836027748 1.8T Linux filesystem
/dev/nvme0n1p3 3836646244 3907029101 70382858 33.6G Linux swap
Mod edit: Added Code formatting.
