I’m using Manjaro GNOME, Kernel: 5.15.93-1-MANJARO. The Bluetooth seems to be on but when I try to scan for devices it doesn’t give any results.
I’m using this adaptador bluetooth device: Amazon.com.mx
You can ask me for more information to try to help me
THANKS IN ADVANCE!!
My outputs:
sudo rfkill list
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
sudo systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Mon 2023-02-13 08:25:25 CST; 1h 32min ago
Docs: man:bluetoothd(8)
Main PID: 567 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19091)
Memory: 2.6M
CPU: 72ms
CGroup: /system.slice/bluetooth.service
└─567 /usr/lib/bluetooth/bluetoothd
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/aptx
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/aptx
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_453
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_453
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_512
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_512
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSink/sbc_xq_552
feb 13 08:50:08 h4ckerman-systemproductname bluetoothd[567]: Endpoint registered: sender=:1.58 path=/MediaEndpoint/A2DPSource/sbc_xq_552
sudo dmesg |grep -i bluetooth
[ 4.768067] Bluetooth: Core ver 2.22
[ 4.768078] NET: Registered PF_BLUETOOTH protocol family
[ 4.768079] Bluetooth: HCI device and connection manager initialized
[ 4.768081] Bluetooth: HCI socket layer initialized
[ 4.768083] Bluetooth: L2CAP socket layer initialized
[ 4.768085] Bluetooth: SCO socket layer initialized
[ 5.806530] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.806534] Bluetooth: BNEP filters: protocol multicast
[ 5.806540] Bluetooth: BNEP socket layer initialized
[ 13.881848] Bluetooth: RFCOMM TTY layer initialized
[ 13.881855] Bluetooth: RFCOMM socket layer initialized
[ 13.881858] Bluetooth: RFCOMM ver 1.11
[ 1487.415956] usb 1-7: Product: Bluetooth Radio
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 1224:2a25 Jieli Technology USB PHY 2.0
Bus 001 Device 007: ID 2b89:8761 Realtek Bluetooth Radio
Bus 001 Device 004: ID 08bb:2902 Texas Instruments PCM2902 Audio Codec
Bus 001 Device 003: ID 4653:0001 foostan Corne
Bus 001 Device 002: ID 046d:c084 Logitech, Inc. G203 Gaming Mouse
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
bluetoothctl
Agent registered
[bluetooth]# show
Controller 0A:62:21:21:2F:D8 (public)
Alias: h4ckerman-systemproductname
Class: 0x007c0104
Powered: yes
Discoverable: yes
DiscoverableTimeout: 0x00000000
Pairable: yes
UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: OBEX Object Push (00001105-0000-1000-8000-00805f9b34fb)
UUID: Message Access Server (00001132-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: IrMC Sync (00001104-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (00005005-0000-1000-8000-0002ee000001)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Phonebook Access Server (0000112f-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Handsfree Audio Gateway (0000111f-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: OBEX File Transfer (00001106-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d0542
Discovering: no
Roles: central
Roles: peripheral
Advertising Features:
ActiveInstances: 0x00 (0)
SupportedInstances: 0x04 (4)
SupportedIncludes: tx-power
SupportedIncludes: appearance
SupportedIncludes: local-name
SupportedSecondaryChannels: 1M
SupportedSecondaryChannels: 2M
SupportedSecondaryChannels: Coded
btmgmt info
Index list with 1 item
hci0: Primary controller
addr 0A:62:21:21:2F:D8 version 10 manufacturer 93 class 0x7c0104
supported settings: powered connectable fast-connectable discoverable bondable link-security ssp br/edr le advertising secure-conn debug-keys privacy static-addr phy-configuration
current settings: powered connectable discoverable bondable ssp br/edr le secure-conn
name h4ckerman-systemproductname
short name
