Hello forum,
I changed my bluetooth 4 adapter for a bluetooth 5 adapter. The new adapter works on a Windows machine (LED on and Rx/Tx), but on my desktop there is no LED on. It just seems dead. I have tried other USB ports, and rebooted.
blueman-adapters shows:
blueman-adapters 13.48.45 ERROR Adapter:53 __init__ : No adapter(s) found
inxi -Fazy
inxi -Fazy:inxi -fazy 127
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
bogomips: 81469
Speed: 1377 MHz min/max: 1550/3400 MHz boost: enabled Core speeds (MHz):
1: 1377 2: 1427 3: 1543 4: 1466 5: 1378 6: 1376 7: 1489 8: 1377 9: 1480
10: 1471 11: 1478 12: 1480
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
lee ~ inxi -Fazy
Kernel: 5.10.41-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2da13361-3914-4269-a8f9-cf1731568275 rw quiet
sysrq_always_enabled=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 1
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-K v: Rev X.0x
serial: <filter> UEFI-[Legacy]: American Megatrends v: 2202 date: 07/14/2020
bogomips: 81469
1: 1377 2: 1375 3: 1457 4: 1372 5: 1378 6: 1380 7: 1444 8: 1373 9: 1537
10: 1464 11: 1476 12: 1395
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK PH-GTX1050TI-4G
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: nvidia display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 465.31 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.10.41-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.18 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI modules: r8169 port: f000
bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vpnac-uk5 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-3:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 4.55 TiB used: 94.09 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1ER162
rotation: 7200 rpm serial: <filter> rev: CC45 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM005-2CW102
rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: BUP Slim BK
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
serial: <filter> rev: 0304 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate model: BUP Slim RD
ID-1: / raw-size: 166.26 GiB size: 162.65 GiB (97.83%)
used: 94.09 GiB (57.8%) fs: ext4 dev: /dev/sdd4 maj-min: 8:52
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 9.95 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdd3 maj-min: 8:51
System Temperatures: cpu: 39.8 C mobo: 0 C gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 282 Uptime: 9m wakeups: 0 Memory: 15.63 GiB used: 2.8 GiB (17.9%)
Init: systemd v: 247 tool: systemctl Compilers: gcc: 11.1.0 alt: 10/8/9
clang: 11.1.0 Packages: pacman: 1864 lib: 460 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.04
bluetoothctl show
No default controller available
rfkill list
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Bluetooth service:
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2021-06-10 13:35:58 CST; 18min ago
Docs: man:bluetoothd(8)
Main PID: 644 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19106)
Memory: 2.3M
CGroup: /system.slice/bluetooth.service
└─644 /usr/lib/bluetooth/bluetoothd
Jun 10 13:35:51 lee-pc systemd[1]: Starting Bluetooth service...
Jun 10 13:35:52 lee-pc bluetoothd[644]: Bluetooth daemon 5.58
Jun 10 13:35:58 lee-pc systemd[1]: Started Bluetooth service.
Jun 10 13:35:58 lee-pc bluetoothd[644]: Starting SDP server
Jun 10 13:35:58 lee-pc bluetoothd[644]: Bluetooth management interface 1.18 initialized
lsusb:
Bus 004 Device 002: ID 0bc2:ab24 Seagate RSS LLC Backup Plus Portable Drive
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 04b4:6009 Cypress Semiconductor Corp.
Bus 003 Device 003: ID 18f8:1485 [Maxxter] USB OPTICAL MOUSE
Bus 003 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. USB3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0bda:8771 Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub```
