BLE support and commands
Hi
I am using Khadas VIM3-Pro board with Manjaro KDE Plasma.
I installed essential pkg relented to bluetooth.
-pacman -S bluez
-pamac install manjaro-bluetooth
-pacman -F bluetoothctl
There are no hcitools or related command.
are there any way to install it ?
hcitools are deprecated and unmaintained sind years, use bluetoothctl.
See the notes in the install section Bluetooth - ArchWiki (archlinux.org)
If you really want to use ancient software you can install bluez-hcitool on x86_64 from AUR. Maybe it builds on Arm.
