[ 6.549]
X.Org X Server 1.20.9
[ 6.549] Build Operating System: Linux Manjaro Linux
[ 6.549] Current Operating System: Linux philip-pc 5.8.18-1-MANJARO #1 SMP PREEMPT Sun Nov 1 14:10:04 UTC 2020 x86_64
[ 6.549] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=35c6153a-6ef7-4823-901c-88bf3a1ee126 rw quiet apparmor=1 security=apparmor resume=UUID=aff51195-3fe9-45be-a825-8df34b94bc84 udev.log_priority=3
[ 6.549] Build Date: 02 September 2020 07:39:17AM
[ 6.549]
[ 6.549] Current version of pixman: 0.40.0
[ 6.549] Before reporting problems, check http://wiki.x.org
[ 6.549] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.549] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 18 08:56:41 2020
[ 6.550] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.550] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.551] (==) No Layout section. Using the first Screen section.
[ 6.551] (==) No screen section available. Using defaults.
[ 6.551] (**) |-->Screen "Default Screen Section" (0)
[ 6.551] (**) | |-->Monitor "<default monitor>"
[ 6.551] (==) No monitor specified for screen "Default Screen Section".
[ 6.551] (==) Automatically adding devices
[ 6.551] (==) Automatically enabling devices
[ 6.551] (==) Automatically adding GPU devices
[ 6.551] (==) Automatically binding GPU devices
[ 6.551] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.552] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 6.552] Entry deleted from font path.
[ 6.552] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 6.552] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 6.552] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 6.552] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.552] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.552] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 6.552] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 6.552] (==) FontPath set to:
[ 6.552] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.552] (II) The server relies on udev to provide the list of input devices.
[ 6.552] (II) Module ABI versions:
[ 6.552] X.Org ANSI C Emulation: 0.4
[ 6.552] X.Org Video Driver: 24.1
[ 6.552] X.Org XInput driver : 24.1
[ 6.552] X.Org Server Extension : 10.0
[ 6.552] (++) using VT number 7
[ 6.552] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.553] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.553] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 6.557] (--) PCI:*(1@0:0:0) 1002:6938:174b:e308 rev 241, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xefe00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 6.557] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.557] (II) LoadModule: "glx"
[ 6.559] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.568] (II) Module glx: vendor="X.Org Foundation"
[ 6.568] compiled for 1.20.9, module version = 1.0.0
[ 6.568] ABI class: X.Org Server Extension, version 10.0
[ 6.568] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 6.568] loading driver: amdgpu
[ 6.568] (==) Matched amdgpu as autoconfigured driver 0
[ 6.568] (==) Matched ati as autoconfigured driver 1
[ 6.568] (==) Matched modesetting as autoconfigured driver 2
[ 6.568] (==) Matched fbdev as autoconfigured driver 3
[ 6.568] (==) Matched vesa as autoconfigured driver 4
[ 6.568] (==) Assigned the driver to the xf86ConfigLayout
[ 6.568] (II) LoadModule: "amdgpu"
[ 6.568] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 6.571] (II) Module amdgpu: vendor="X.Org Foundation"
[ 6.571] compiled for 1.20.8, module version = 19.1.0
[ 6.571] Module class: X.Org Video Driver
[ 6.571] ABI class: X.Org Video Driver, version 24.1
[ 6.571] (II) LoadModule: "ati"
[ 6.571] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 6.571] (II) Module ati: vendor="X.Org Foundation"
[ 6.572] (II) LoadModule: "modesetting"
[ 6.572] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 6.573] (II) Module modesetting: vendor="X.Org Foundation"
[ 6.573] compiled for 1.20.9, module version = 1.20.9
[ 6.573] Module class: X.Org Video Driver
[ 6.573] ABI class: X.Org Video Driver, version 24.1
[ 6.573] (II) LoadModule: "fbdev"
[ 6.573] (WW) Warning, couldn't open module fbdev
[ 6.573] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 6.573] (II) LoadModule: "vesa"
[ 6.573] (WW) Warning, couldn't open module vesa
[ 6.573] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 6.573] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 6.573] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 6.574] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[ 6.574] (WW) Falling back to old probe method for modesetting
[ 6.574] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 6.574] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 6.574] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 6.574] (==) AMDGPU(0): Default visual is TrueColor
[ 6.574] (==) AMDGPU(0): RGB weight 888
[ 6.574] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 6.574] (--) AMDGPU(0): Chipset: "AMD Radeon (TM) R9 380 Series" (ChipID = 0x6938)
[ 6.574] (II) Loading sub module "fb"
[ 6.574] (II) LoadModule: "fb"
[ 6.574] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 6.575] (II) Module fb: vendor="X.Org Foundation"
[ 6.575] compiled for 1.20.9, module version = 1.0.0
[ 6.575] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.575] (II) Loading sub module "dri2"
[ 6.575] (II) LoadModule: "dri2"
[ 6.575] (II) Module "dri2" already built-in
[ 6.798] (II) Loading sub module "glamoregl"
[ 6.798] (II) LoadModule: "glamoregl"
[ 6.798] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 6.814] (II) Module glamoregl: vendor="X.Org Foundation"
[ 6.814] compiled for 1.20.9, module version = 1.0.1
[ 6.814] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.842] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon (TM) R9 380 Series (TONGA, DRM 3.38.0, 5.8.18-1-MANJARO, LLVM 10.0.1)
[ 6.842] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 6.842] (==) AMDGPU(0): TearFree property default: auto
[ 6.842] (==) AMDGPU(0): VariableRefresh: disabled
[ 6.842] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 6.842] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 6.842] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 6.843] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[ 6.844] (II) AMDGPU(0): Output DVI-D-1 has no monitor section
[ 6.873] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 6.873] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 6.874] (II) AMDGPU(0): EDID for output DVI-D-0
[ 6.874] (II) AMDGPU(0): Manufacturer: ACR Model: 2f9 Serial#: 1414533744
[ 6.874] (II) AMDGPU(0): Year: 2015 Week: 45
[ 6.874] (II) AMDGPU(0): EDID Version: 1.3
[ 6.874] (II) AMDGPU(0): Digital Display Input
[ 6.874] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 53 vert.: 30
[ 6.874] (II) AMDGPU(0): Gamma: 2.20
[ 6.874] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend
[ 6.874] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 6.874] (II) AMDGPU(0): First detailed timing is preferred mode
[ 6.874] (II) AMDGPU(0): redX: 0.646 redY: 0.329 greenX: 0.310 greenY: 0.616
[ 6.874] (II) AMDGPU(0): blueX: 0.151 blueY: 0.072 whiteX: 0.312 whiteY: 0.328
[ 6.874] (II) AMDGPU(0): Supported established timings:
[ 6.874] (II) AMDGPU(0): 720x400@70Hz
[ 6.874] (II) AMDGPU(0): 640x480@60Hz
[ 6.874] (II) AMDGPU(0): 640x480@67Hz
[ 6.874] (II) AMDGPU(0): 640x480@72Hz
[ 6.874] (II) AMDGPU(0): 640x480@75Hz
[ 6.874] (II) AMDGPU(0): 800x600@56Hz
[ 6.874] (II) AMDGPU(0): 800x600@60Hz
[ 6.874] (II) AMDGPU(0): 800x600@72Hz
[ 6.874] (II) AMDGPU(0): 800x600@75Hz
[ 6.874] (II) AMDGPU(0): 832x624@75Hz
[ 6.874] (II) AMDGPU(0): 1024x768@60Hz
[ 6.874] (II) AMDGPU(0): 1024x768@70Hz
[ 6.874] (II) AMDGPU(0): 1024x768@75Hz
[ 6.874] (II) AMDGPU(0): 1280x1024@75Hz
[ 6.874] (II) AMDGPU(0): 1152x864@75Hz
[ 6.874] (II) AMDGPU(0): Manufacturer's mask: 0
[ 6.874] (II) AMDGPU(0): Supported standard timings:
[ 6.874] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 6.874] (II) AMDGPU(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 6.874] (II) AMDGPU(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 6.874] (II) AMDGPU(0): #3: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 6.874] (II) AMDGPU(0): #4: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 6.874] (II) AMDGPU(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 6.874] (II) AMDGPU(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 6.874] (II) AMDGPU(0): #7: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 6.874] (II) AMDGPU(0): Supported detailed timing:
[ 6.874] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 531 x 299 mm
[ 6.874] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 6.874] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 6.874] (II) AMDGPU(0): Ranges: V min: 56 V max: 144 Hz, H min: 30 H max: 160 kHz, PixClock max 335 MHz
[ 6.874] (II) AMDGPU(0): Monitor name: GN246HL
[ 6.874] (II) AMDGPU(0): Serial No: LW3EE0058532
[ 6.874] (II) AMDGPU(0): clock: 235.5 MHz Image Size: 531 x 298 mm
[ 6.875] (II) AMDGPU(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 6.875] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1133 v_border: 0
[ 6.875] (II) AMDGPU(0): Supported detailed timing:
[ 6.875] (II) AMDGPU(0): clock: 285.5 MHz Image Size: 531 x 298 mm
[ 6.875] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1144 v_border: 0
[ 6.875] (II) AMDGPU(0): clock: 325.1 MHz Image Size: 531 x 298 mm
[ 6.875] (II) AMDGPU(0): h_active: 1920 h_sync: 1944 h_sync_end 1976 h_blank_end 2056 h_border: 0
[ 6.875] (II) AMDGPU(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1098 v_border: 0
[ 6.875] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 6.875] (II) AMDGPU(0): EDID (in hex):
[ 6.875] (II) AMDGPU(0): 00ffffffffffff000472f90270125054
[ 6.875] (II) AMDGPU(0): 2d19010380351e78ca57e0a5544f9d26
[ 6.875] (II) AMDGPU(0): 125054bfef80714f8140818081c08100
[ 6.875] (II) AMDGPU(0): 9500b300d1c0023a801871382d40582c
[ 6.875] (II) AMDGPU(0): 4500132b2100001e000000fd0038901e
[ 6.875] (II) AMDGPU(0): a021000a202020202020000000fc0047
[ 6.875] (II) AMDGPU(0): 4e323436484c0a2020202020000000ff
[ 6.875] (II) AMDGPU(0): 004c57334545303035383533320a01f3
[ 6.875] (II) AMDGPU(0): 02010400fe5b80a07038354030203500
[ 6.875] (II) AMDGPU(0): 132a2100001a866f80a0703840403020
[ 6.875] (II) AMDGPU(0): 3500132a2100001afc7e808870381240
[ 6.875] (II) AMDGPU(0): 18203500132a2100001e000000000000
[ 6.875] (II) AMDGPU(0): 00000000000000000000000000000000
[ 6.875] (II) AMDGPU(0): 000000000000000000000000000000c7
[ 6.875] (II) AMDGPU(0): Printing probed modes for output DVI-D-0
[ 6.875] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 6.875] (II) AMDGPU(0): Modeline "1920x1080"x144.0 325.08 1920 1944 1976 2056 1080 1083 1088 1098 +hsync +vsync (158.1 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1920x1080"x120.0 285.50 1920 1968 2000 2080 1080 1083 1088 1144 +hsync -vsync (137.3 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1920x1080"x99.9 235.50 1920 1968 2000 2080 1080 1083 1088 1133 +hsync -vsync (113.2 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.875] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6.876] (II) AMDGPU(0): EDID for output DVI-D-1
[ 6.876] (II) AMDGPU(0): Manufacturer: ACR Model: 12b Serial#: 596659669
[ 6.876] (II) AMDGPU(0): Year: 2012 Week: 39
[ 6.876] (II) AMDGPU(0): EDID Version: 1.3
[ 6.876] (II) AMDGPU(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 6.876] (II) AMDGPU(0): Sync: Separate
[ 6.876] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 52 vert.: 29
[ 6.876] (II) AMDGPU(0): Gamma: 2.20
[ 6.876] (II) AMDGPU(0): DPMS capabilities: Off; RGB/Color Display
[ 6.876] (II) AMDGPU(0): First detailed timing is preferred mode
[ 6.876] (II) AMDGPU(0): redX: 0.647 redY: 0.334 greenX: 0.284 greenY: 0.607
[ 6.876] (II) AMDGPU(0): blueX: 0.151 blueY: 0.071 whiteX: 0.313 whiteY: 0.329
[ 6.876] (II) AMDGPU(0): Supported established timings:
[ 6.877] (II) AMDGPU(0): 720x400@70Hz
[ 6.877] (II) AMDGPU(0): 640x480@60Hz
[ 6.877] (II) AMDGPU(0): 640x480@67Hz
[ 6.877] (II) AMDGPU(0): 640x480@72Hz
[ 6.877] (II) AMDGPU(0): 640x480@75Hz
[ 6.877] (II) AMDGPU(0): 800x600@56Hz
[ 6.877] (II) AMDGPU(0): 800x600@60Hz
[ 6.877] (II) AMDGPU(0): 800x600@72Hz
[ 6.877] (II) AMDGPU(0): 800x600@75Hz
[ 6.877] (II) AMDGPU(0): 832x624@75Hz
[ 6.877] (II) AMDGPU(0): 1024x768@60Hz
[ 6.877] (II) AMDGPU(0): 1024x768@70Hz
[ 6.877] (II) AMDGPU(0): 1024x768@75Hz
[ 6.877] (II) AMDGPU(0): 1280x1024@75Hz
[ 6.877] (II) AMDGPU(0): 1152x864@75Hz
[ 6.877] (II) AMDGPU(0): Manufacturer's mask: 0
[ 6.877] (II) AMDGPU(0): Supported standard timings:
[ 6.877] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 6.877] (II) AMDGPU(0): #1: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 6.877] (II) AMDGPU(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 6.877] (II) AMDGPU(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 6.877] (II) AMDGPU(0): #4: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 6.877] (II) AMDGPU(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 6.877] (II) AMDGPU(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 6.877] (II) AMDGPU(0): Supported detailed timing:
[ 6.877] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 521 x 293 mm
[ 6.877] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 6.877] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 6.877] (II) AMDGPU(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 6.877] (II) AMDGPU(0): Monitor name: Acer G245HQ
[ 6.877] (II) AMDGPU(0): Serial No: LKK0W0144340
[ 6.877] (II) AMDGPU(0): EDID (in hex):
[ 6.877] (II) AMDGPU(0): 00ffffffffffff0004722b01d54d9023
[ 6.877] (II) AMDGPU(0): 2716010368341d782aeed5a555489b26
[ 6.877] (II) AMDGPU(0): 125054bfef80714f810081809500950f
[ 6.877] (II) AMDGPU(0): b300d1c00101023a801871382d40582c
[ 6.877] (II) AMDGPU(0): 450009252100001e000000fd00384b1e
[ 6.877] (II) AMDGPU(0): 5311000a202020202020000000fc0041
[ 6.877] (II) AMDGPU(0): 636572204732343548510a20000000ff
[ 6.877] (II) AMDGPU(0): 004c4b4b3057303134343334300a008e
[ 6.877] (II) AMDGPU(0): Printing probed modes for output DVI-D-1
[ 6.877] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 6.877] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1280x720"x60.0 148.50 1280 2008 2052 2200 720 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.877] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6.877] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 6.877] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 6.877] (II) AMDGPU(0): Output DVI-D-0 connected
[ 6.877] (II) AMDGPU(0): Output DVI-D-1 connected
[ 6.877] (II) AMDGPU(0): Using spanning desktop for initial modes
[ 6.877] (II) AMDGPU(0): Output DVI-D-0 using initial mode 1920x1080 +0+0
[ 6.877] (II) AMDGPU(0): Output DVI-D-1 using initial mode 1920x1080 +1920+0
[ 6.877] (II) AMDGPU(0): mem size init: gart size :ff875000 vram size: s:feeea000 visible:f2ea000
[ 6.877] (==) AMDGPU(0): DPI set to (96, 96)
[ 6.877] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.877] (II) Loading sub module "ramdac"
[ 6.877] (II) LoadModule: "ramdac"
[ 6.877] (II) Module "ramdac" already built-in
[ 6.878] (II) UnloadModule: "modesetting"
[ 6.878] (II) Unloading modesetting
[ 6.878] (II) AMDGPU(0): [DRI2] Setup complete
[ 6.878] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 6.878] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 6.879] (II) AMDGPU(0): Front buffer pitch: 15360 bytes
[ 6.880] (II) AMDGPU(0): SYNC extension fences enabled
[ 6.880] (II) AMDGPU(0): Present extension enabled
[ 6.881] (==) AMDGPU(0): DRI3 enabled
[ 6.881] (==) AMDGPU(0): Backing store enabled
[ 6.881] (II) AMDGPU(0): Direct rendering enabled
[ 6.907] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 6.907] (II) AMDGPU(0): Acceleration enabled
[ 6.907] (==) AMDGPU(0): DPMS enabled
[ 6.907] (==) AMDGPU(0): Silken mouse disabled
[ 6.907] (II) AMDGPU(0): Set up textured video (glamor)
[ 6.941] (II) Initializing extension Generic Event Extension
[ 6.942] (II) Initializing extension SHAPE
[ 6.942] (II) Initializing extension MIT-SHM
[ 6.942] (II) Initializing extension XInputExtension
[ 6.943] (II) Initializing extension XTEST
[ 6.943] (II) Initializing extension BIG-REQUESTS
[ 6.944] (II) Initializing extension SYNC
[ 6.944] (II) Initializing extension XKEYBOARD
[ 6.945] (II) Initializing extension XC-MISC
[ 6.945] (II) Initializing extension SECURITY
[ 6.945] (II) Initializing extension XFIXES
[ 6.946] (II) Initializing extension RENDER
[ 6.946] (II) Initializing extension RANDR
[ 6.947] (II) Initializing extension COMPOSITE
[ 6.947] (II) Initializing extension DAMAGE
[ 6.947] (II) Initializing extension MIT-SCREEN-SAVER
[ 6.948] (II) Initializing extension DOUBLE-BUFFER
[ 6.948] (II) Initializing extension RECORD
[ 6.948] (II) Initializing extension DPMS
[ 6.949] (II) Initializing extension Present
[ 6.949] (II) Initializing extension DRI3
[ 6.949] (II) Initializing extension X-Resource
[ 6.950] (II) Initializing extension XVideo
[ 6.950] (II) Initializing extension XVideo-MotionCompensation
[ 6.950] (II) Initializing extension GLX
[ 6.964] (II) AIGLX: Loaded and initialized radeonsi
[ 6.964] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 6.964] (II) Initializing extension XFree86-VidModeExtension
[ 6.964] (II) Initializing extension XFree86-DGA
[ 6.964] (II) Initializing extension XFree86-DRI
[ 6.964] (II) Initializing extension DRI2
[ 6.971] (II) AMDGPU(0): Setting screen physical size to 1016 x 285
[ 7.130] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 7.130] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.130] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.130] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.130] (II) LoadModule: "libinput"
[ 7.130] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.136] (II) Module libinput: vendor="X.Org Foundation"
[ 7.136] compiled for 1.20.8, module version = 0.30.0
[ 7.136] Module class: X.Org XInput Driver
[ 7.136] ABI class: X.Org XInput driver, version 24.1
[ 7.136] (II) Using input driver 'libinput' for 'Power Button'
[ 7.136] (**) Power Button: always reports core events
[ 7.136] (**) Option "Device" "/dev/input/event2"
[ 7.136] (**) Option "_source" "server/udev"
[ 7.143] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.144] (II) event2 - Power Button: device is a keyboard
[ 7.144] (II) event2 - Power Button: device removed
[ 7.162] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 7.162] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.162] (**) Option "xkb_model" "pc105"
[ 7.162] (**) Option "xkb_layout" "se"
[ 7.207] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 7.207] (II) event2 - Power Button: device is a keyboard
[ 7.208] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.208] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.208] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.208] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.208] (II) Using input driver 'libinput' for 'Power Button'
[ 7.208] (**) Power Button: always reports core events
[ 7.208] (**) Option "Device" "/dev/input/event1"
[ 7.208] (**) Option "_source" "server/udev"
[ 7.209] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.209] (II) event1 - Power Button: device is a keyboard
[ 7.210] (II) event1 - Power Button: device removed
[ 7.242] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 7.242] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 7.242] (**) Option "xkb_model" "pc105"
[ 7.242] (**) Option "xkb_layout" "se"
[ 7.245] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.245] (II) event1 - Power Button: device is a keyboard
[ 7.246] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 7.246] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 7.246] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 7.246] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 7.246] (II) Using input driver 'libinput' for 'Sleep Button'
[ 7.246] (**) Sleep Button: always reports core events
[ 7.246] (**) Option "Device" "/dev/input/event0"
[ 7.246] (**) Option "_source" "server/udev"
[ 7.249] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 7.249] (II) event0 - Sleep Button: device is a keyboard
[ 7.250] (II) event0 - Sleep Button: device removed
[ 7.269] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 7.269] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 7.269] (**) Option "xkb_model" "pc105"
[ 7.269] (**) Option "xkb_layout" "se"
[ 7.272] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 7.273] (II) event0 - Sleep Button: device is a keyboard
[ 7.275] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event4)
[ 7.275] (II) No input driver specified, ignoring this device.
[ 7.275] (II) This device may have been added with another device file.
[ 7.276] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event5)
[ 7.276] (II) No input driver specified, ignoring this device.
[ 7.276] (II) This device may have been added with another device file.
[ 7.277] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event6)
[ 7.277] (II) No input driver specified, ignoring this device.
[ 7.277] (II) This device may have been added with another device file.
[ 7.279] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event7)
[ 7.279] (II) No input driver specified, ignoring this device.
[ 7.279] (II) This device may have been added with another device file.
[ 7.280] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event8)
[ 7.280] (II) No input driver specified, ignoring this device.
[ 7.280] (II) This device may have been added with another device file.
[ 7.281] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event9)
[ 7.281] (II) No input driver specified, ignoring this device.
[ 7.281] (II) This device may have been added with another device file.
[ 7.282] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event10)
[ 7.282] (II) No input driver specified, ignoring this device.
[ 7.282] (II) This device may have been added with another device file.
[ 7.283] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event11)
[ 7.283] (II) No input driver specified, ignoring this device.
[ 7.283] (II) This device may have been added with another device file.
[ 7.284] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event12)
[ 7.284] (II) No input driver specified, ignoring this device.
[ 7.284] (II) This device may have been added with another device file.
[ 7.285] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event13)
[ 7.285] (II) No input driver specified, ignoring this device.
[ 7.285] (II) This device may have been added with another device file.
[ 7.286] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event14)
[ 7.286] (II) No input driver specified, ignoring this device.
[ 7.286] (II) This device may have been added with another device file.
[ 7.287] (II) config/udev: Adding input device PC Speaker (/dev/input/event3)
[ 7.287] (II) No input driver specified, ignoring this device.
[ 7.287] (II) This device may have been added with another device file.
[ 8.161] (II) AMDGPU(0): EDID vendor "ACR", prod id 299
[ 8.162] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 8.162] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 8.162] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 8.162] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 8.162] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 8.162] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 8.206] (EE) AMDGPU(0): drmmode_do_crtc_dpms cannot get last vblank counter
[ 8.207] (II) AMDGPU(0): Allocate new frame buffer 3000x1920
[ 8.207] (II) AMDGPU(0): => pitch 12288 bytes
[ 9.004] (II) AMDGPU(0): EDID vendor "ACR", prod id 299
[ 9.004] (II) AMDGPU(0): Using hsync ranges from config file
[ 9.004] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 9.004] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 9.004] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 9.004] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 9.004] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 13.770] (II) AMDGPU(0): EDID vendor "ACR", prod id 299
[ 13.770] (II) AMDGPU(0): Using hsync ranges from config file
[ 13.770] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 13.770] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 13.770] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 13.770] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 13.770] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 28.771] (II) AMDGPU(0): EDID vendor "ACR", prod id 299
[ 28.771] (II) AMDGPU(0): Using hsync ranges from config file
[ 28.771] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 28.771] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 28.771] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 28.771] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 28.771] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 28.771] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 28.772] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 53.777] (II) AMDGPU(0): EDID vendor "ACR", prod id 299
[ 53.777] (II) AMDGPU(0): Using hsync ranges from config file
[ 53.777] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 53.777] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 53.777] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 53.777] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 53.777] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 89.808] (II) config/udev: Adding input device USB Keyboard (/dev/input/event19)
[ 89.808] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 89.808] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 89.808] (**) USB Keyboard: Applying InputClass "system-keyboard"
[ 89.808] (II) Using input driver 'libinput' for 'USB Keyboard'
[ 89.808] (**) USB Keyboard: always reports core events
[ 89.808] (**) Option "Device" "/dev/input/event19"
[ 89.808] (**) Option "_source" "server/udev"
[ 89.809] (II) event19 - USB Keyboard: is tagged by udev as: Keyboard
[ 89.810] (II) event19 - USB Keyboard: device is a keyboard
[ 89.810] (II) event19 - USB Keyboard: device removed
[ 89.825] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.2/0003:04D9:0141.0003/input/input19/event19"
[ 89.825] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 9)
[ 89.825] (**) Option "xkb_model" "pc105"
[ 89.825] (**) Option "xkb_layout" "se"
[ 89.826] (II) event19 - USB Keyboard: is tagged by udev as: Keyboard
[ 89.827] (II) event19 - USB Keyboard: device is a keyboard
[ 89.827] (II) config/udev: Adding input device USB Keyboard (/dev/input/event15)
[ 89.827] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 89.827] (**) USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 89.827] (**) USB Keyboard: Applying InputClass "system-keyboard"
[ 89.827] (II) Using input driver 'libinput' for 'USB Keyboard'
[ 89.827] (**) USB Keyboard: always reports core events
[ 89.827] (**) Option "Device" "/dev/input/event15"
[ 89.827] (**) Option "_source" "server/udev"
[ 89.829] (II) event15 - USB Keyboard: is tagged by udev as: Keyboard
[ 89.829] (II) event15 - USB Keyboard: device is a keyboard
[ 89.829] (II) event15 - USB Keyboard: device removed
[ 89.847] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:04D9:0141.0001/input/input15/event15"
[ 89.847] (II) XINPUT: Adding extended input device "USB Keyboard" (type: KEYBOARD, id 10)
[ 89.847] (**) Option "xkb_model" "pc105"
[ 89.847] (**) Option "xkb_layout" "se"
[ 89.849] (II) event15 - USB Keyboard: is tagged by udev as: Keyboard
[ 89.849] (II) event15 - USB Keyboard: device is a keyboard
[ 89.850] (II) config/udev: Adding input device USB Keyboard System Control (/dev/input/event16)
[ 89.850] (**) USB Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 89.850] (**) USB Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 89.850] (**) USB Keyboard System Control: Applying InputClass "system-keyboard"
[ 89.850] (II) Using input driver 'libinput' for 'USB Keyboard System Control'
[ 89.850] (**) USB Keyboard System Control: always reports core events
[ 89.850] (**) Option "Device" "/dev/input/event16"
[ 89.850] (**) Option "_source" "server/udev"
[ 89.851] (II) event16 - USB Keyboard System Control: is tagged by udev as: Keyboard
[ 89.851] (II) event16 - USB Keyboard System Control: device is a keyboard
[ 89.851] (II) event16 - USB Keyboard System Control: device removed
[ 89.864] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.2/0003:04D9:0141.0003/input/input16/event16"
[ 89.864] (II) XINPUT: Adding extended input device "USB Keyboard System Control" (type: KEYBOARD, id 11)
[ 89.864] (**) Option "xkb_model" "pc105"
[ 89.864] (**) Option "xkb_layout" "se"
[ 89.865] (II) event16 - USB Keyboard System Control: is tagged by udev as: Keyboard
[ 89.866] (II) event16 - USB Keyboard System Control: device is a keyboard
[ 89.867] (II) config/udev: Adding input device USB Keyboard Consumer Control (/dev/input/event17)
[ 89.867] (**) USB Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 89.867] (**) USB Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 89.867] (**) USB Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 89.867] (II) Using input driver 'libinput' for 'USB Keyboard Consumer Control'
[ 89.867] (**) USB Keyboard Consumer Control: always reports core events
[ 89.867] (**) Option "Device" "/dev/input/event17"
[ 89.867] (**) Option "_source" "server/udev"
[ 89.868] (II) event17 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 89.868] (II) event17 - USB Keyboard Consumer Control: device is a keyboard
[ 89.868] (II) event17 - USB Keyboard Consumer Control: device removed
[ 89.922] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.2/0003:04D9:0141.0003/input/input17/event17"
[ 89.922] (II) XINPUT: Adding extended input device "USB Keyboard Consumer Control" (type: KEYBOARD, id 12)
[ 89.922] (**) Option "xkb_model" "pc105"
[ 89.922] (**) Option "xkb_layout" "se"
[ 89.925] (II) event17 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 89.925] (II) event17 - USB Keyboard Consumer Control: device is a keyboard
[ 89.927] (II) config/udev: Adding input device USB Keyboard Mouse (/dev/input/event18)
[ 89.927] (**) USB Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[ 89.927] (**) USB Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[ 89.927] (II) Using input driver 'libinput' for 'USB Keyboard Mouse'
[ 89.927] (**) USB Keyboard Mouse: always reports core events
[ 89.927] (**) Option "Device" "/dev/input/event18"
[ 89.927] (**) Option "_source" "server/udev"
[ 89.929] (II) event18 - USB Keyboard Mouse: is tagged by udev as: Mouse
[ 89.930] (II) event18 - USB Keyboard Mouse: device is a pointer
[ 89.930] (II) event18 - USB Keyboard Mouse: device removed
[ 89.975] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.2/0003:04D9:0141.0003/input/input18/event18"
[ 89.975] (II) XINPUT: Adding extended input device "USB Keyboard Mouse" (type: MOUSE, id 13)
[ 89.977] (**) Option "AccelerationScheme" "none"
[ 89.978] (**) USB Keyboard Mouse: (accel) selected scheme none/0
[ 89.978] (**) USB Keyboard Mouse: (accel) acceleration factor: 2.000
[ 89.978] (**) USB Keyboard Mouse: (accel) acceleration threshold: 4
[ 89.983] (II) event18 - USB Keyboard Mouse: is tagged by udev as: Mouse
[ 89.983] (II) event18 - USB Keyboard Mouse: device is a pointer
[ 89.986] (II) config/udev: Adding input device USB Keyboard Mouse (/dev/input/mouse0)
[ 89.986] (II) No input driver specified, ignoring this device.
[ 89.986] (II) This device may have been added with another device file.
[ 89.988] (II) config/udev: Adding input device Microsoft® LifeCam HD-3000: Mi (/dev/input/event21)
[ 89.988] (**) Microsoft® LifeCam HD-3000: Mi: Applying InputClass "evdev keyboard catchall"
[ 89.988] (**) Microsoft® LifeCam HD-3000: Mi: Applying InputClass "libinput keyboard catchall"
[ 89.988] (**) Microsoft® LifeCam HD-3000: Mi: Applying InputClass "system-keyboard"
[ 89.988] (II) Using input driver 'libinput' for 'Microsoft® LifeCam HD-3000: Mi'
[ 89.988] (**) Microsoft® LifeCam HD-3000: Mi: always reports core events
[ 89.988] (**) Option "Device" "/dev/input/event21"
[ 89.988] (**) Option "_source" "server/udev"
[ 89.992] (II) event21 - Microsoft® LifeCam HD-3000: Mi: is tagged by udev as: Keyboard
[ 89.993] (II) event21 - Microsoft® LifeCam HD-3000: Mi: device is a keyboard
[ 89.993] (II) event21 - Microsoft® LifeCam HD-3000: Mi: device removed
[ 90.055] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input21/event21"
[ 90.055] (II) XINPUT: Adding extended input device "Microsoft® LifeCam HD-3000: Mi" (type: KEYBOARD, id 14)
[ 90.055] (**) Option "xkb_model" "pc105"
[ 90.055] (**) Option "xkb_layout" "se"
[ 90.061] (II) event21 - Microsoft® LifeCam HD-3000: Mi: is tagged by udev as: Keyboard
[ 90.061] (II) event21 - Microsoft® LifeCam HD-3000: Mi: device is a keyboard
[ 90.064] (II) config/udev: Adding input device Kingsis Peripherals ZOWIE Gaming mouse (/dev/input/event20)
[ 90.064] (**) Kingsis Peripherals ZOWIE Gaming mouse: Applying InputClass "evdev pointer catchall"
[ 90.064] (**) Kingsis Peripherals ZOWIE Gaming mouse: Applying InputClass "libinput pointer catchall"
[ 90.064] (II) Using input driver 'libinput' for 'Kingsis Peripherals ZOWIE Gaming mouse'
[ 90.064] (**) Kingsis Peripherals ZOWIE Gaming mouse: always reports core events
[ 90.064] (**) Option "Device" "/dev/input/event20"
[ 90.064] (**) Option "_source" "server/udev"
[ 90.126] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: is tagged by udev as: Mouse
[ 90.127] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device set to 800 DPI
[ 90.127] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device is a pointer
[ 90.127] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device removed
[ 90.215] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:1AF3:0001.0004/input/input20/event20"
[ 90.215] (II) XINPUT: Adding extended input device "Kingsis Peripherals ZOWIE Gaming mouse" (type: MOUSE, id 15)
[ 90.216] (**) Option "AccelerationScheme" "none"
[ 90.217] (**) Kingsis Peripherals ZOWIE Gaming mouse: (accel) selected scheme none/0
[ 90.217] (**) Kingsis Peripherals ZOWIE Gaming mouse: (accel) acceleration factor: 2.000
[ 90.217] (**) Kingsis Peripherals ZOWIE Gaming mouse: (accel) acceleration threshold: 4
[ 90.276] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: is tagged by udev as: Mouse
[ 90.277] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device set to 800 DPI
[ 90.277] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device is a pointer
[ 90.278] (II) config/udev: Adding input device Kingsis Peripherals ZOWIE Gaming mouse (/dev/input/mouse1)
[ 90.278] (II) No input driver specified, ignoring this device.
[ 90.278] (II) This device may have been added with another device file.
[ 110.153] (EE) event15 - USB Keyboard: client bug: event processing lagging behind by 24ms, your system is too slow
[ 357.599] (EE) event15 - USB Keyboard: client bug: event processing lagging behind by 14ms, your system is too slow
[ 433.378] (II) config/udev: Adding input device Logitech G533 Gaming Headset Consumer Control (/dev/input/event22)
[ 433.378] (**) Logitech G533 Gaming Headset Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 433.378] (**) Logitech G533 Gaming Headset Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 433.378] (**) Logitech G533 Gaming Headset Consumer Control: Applying InputClass "system-keyboard"
[ 433.378] (II) Using input driver 'libinput' for 'Logitech G533 Gaming Headset Consumer Control'
[ 433.378] (**) Logitech G533 Gaming Headset Consumer Control: always reports core events
[ 433.378] (**) Option "Device" "/dev/input/event22"
[ 433.378] (**) Option "_source" "server/udev"
[ 433.379] (II) event22 - Logitech G533 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 433.379] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device is a keyboard
[ 433.380] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device removed
[ 433.392] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.3/0003:046D:0A66.0005/input/input22/event22"
[ 433.392] (II) XINPUT: Adding extended input device "Logitech G533 Gaming Headset Consumer Control" (type: KEYBOARD, id 16)
[ 433.392] (**) Option "xkb_model" "pc105"
[ 433.392] (**) Option "xkb_layout" "se"
[ 433.406] (II) event22 - Logitech G533 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 433.406] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device is a keyboard
[ 433.407] (II) config/udev: Adding input device Logitech G533 Gaming Headset (/dev/input/event23)
[ 433.407] (**) Logitech G533 Gaming Headset: Applying InputClass "evdev keyboard catchall"
[ 433.407] (**) Logitech G533 Gaming Headset: Applying InputClass "libinput keyboard catchall"
[ 433.407] (**) Logitech G533 Gaming Headset: Applying InputClass "system-keyboard"
[ 433.407] (II) Using input driver 'libinput' for 'Logitech G533 Gaming Headset'
[ 433.407] (**) Logitech G533 Gaming Headset: always reports core events
[ 433.407] (**) Option "Device" "/dev/input/event23"
[ 433.407] (**) Option "_source" "server/udev"
[ 433.408] (II) event23 - Logitech G533 Gaming Headset: is tagged by udev as: Keyboard
[ 433.408] (II) event23 - Logitech G533 Gaming Headset: device is a keyboard
[ 433.408] (II) event23 - Logitech G533 Gaming Headset: device removed
[ 433.467] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.3/0003:046D:0A66.0005/input/input23/event23"
[ 433.467] (II) XINPUT: Adding extended input device "Logitech G533 Gaming Headset" (type: KEYBOARD, id 17)
[ 433.467] (**) Option "xkb_model" "pc105"
[ 433.467] (**) Option "xkb_layout" "se"
[ 433.470] (II) event23 - Logitech G533 Gaming Headset: is tagged by udev as: Keyboard
[ 433.470] (II) event23 - Logitech G533 Gaming Headset: device is a keyboard
[ 433.472] (II) config/udev: Adding input device Logitech G533 Gaming Headset (/dev/input/event24)
[ 433.472] (II) No input driver specified, ignoring this device.
[ 433.472] (II) This device may have been added with another device file.
[ 459.004] (II) config/udev: removing device Logitech G533 Gaming Headset Consumer Control
[ 459.004] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device removed
[ 459.016] (II) UnloadModule: "libinput"
[ 459.023] (II) config/udev: removing device Logitech G533 Gaming Headset
[ 459.023] (II) event23 - Logitech G533 Gaming Headset: device removed
[ 459.050] (II) UnloadModule: "libinput"
[ 463.308] (II) config/udev: Adding input device Logitech G533 Gaming Headset Consumer Control (/dev/input/event22)
[ 463.308] (**) Logitech G533 Gaming Headset Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 463.308] (**) Logitech G533 Gaming Headset Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 463.308] (**) Logitech G533 Gaming Headset Consumer Control: Applying InputClass "system-keyboard"
[ 463.308] (II) Using input driver 'libinput' for 'Logitech G533 Gaming Headset Consumer Control'
[ 463.308] (**) Logitech G533 Gaming Headset Consumer Control: always reports core events
[ 463.308] (**) Option "Device" "/dev/input/event22"
[ 463.308] (**) Option "_source" "server/udev"
[ 463.309] (II) event22 - Logitech G533 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 463.309] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device is a keyboard
[ 463.309] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device removed
[ 463.325] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.3/0003:046D:0A66.0006/input/input26/event22"
[ 463.325] (II) XINPUT: Adding extended input device "Logitech G533 Gaming Headset Consumer Control" (type: KEYBOARD, id 16)
[ 463.325] (**) Option "xkb_model" "pc105"
[ 463.325] (**) Option "xkb_layout" "se"
[ 463.326] (II) event22 - Logitech G533 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 463.326] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device is a keyboard
[ 463.327] (II) config/udev: Adding input device Logitech G533 Gaming Headset (/dev/input/event23)
[ 463.327] (**) Logitech G533 Gaming Headset: Applying InputClass "evdev keyboard catchall"
[ 463.327] (**) Logitech G533 Gaming Headset: Applying InputClass "libinput keyboard catchall"
[ 463.327] (**) Logitech G533 Gaming Headset: Applying InputClass "system-keyboard"
[ 463.327] (II) Using input driver 'libinput' for 'Logitech G533 Gaming Headset'
[ 463.327] (**) Logitech G533 Gaming Headset: always reports core events
[ 463.327] (**) Option "Device" "/dev/input/event23"
[ 463.327] (**) Option "_source" "server/udev"
[ 463.328] (II) event23 - Logitech G533 Gaming Headset: is tagged by udev as: Keyboard
[ 463.329] (II) event23 - Logitech G533 Gaming Headset: device is a keyboard
[ 463.329] (II) event23 - Logitech G533 Gaming Headset: device removed
[ 463.382] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.3/0003:046D:0A66.0006/input/input27/event23"
[ 463.382] (II) XINPUT: Adding extended input device "Logitech G533 Gaming Headset" (type: KEYBOARD, id 17)
[ 463.382] (**) Option "xkb_model" "pc105"
[ 463.382] (**) Option "xkb_layout" "se"
[ 463.384] (II) event23 - Logitech G533 Gaming Headset: is tagged by udev as: Keyboard
[ 463.385] (II) event23 - Logitech G533 Gaming Headset: device is a keyboard
[ 463.386] (II) config/udev: Adding input device Logitech G533 Gaming Headset (/dev/input/event24)
[ 463.386] (II) No input driver specified, ignoring this device.
[ 463.386] (II) This device may have been added with another device file.
[ 1378.613] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: SYN_DROPPED event - some input events have been lost.
[ 1378.614] (II) event2 - Power Button: device removed
[ 1378.649] (II) event1 - Power Button: device removed
[ 1378.665] (II) event0 - Sleep Button: device removed
[ 1378.693] (II) event19 - USB Keyboard: device removed
[ 1378.713] (II) event15 - USB Keyboard: device removed
[ 1378.733] (II) event16 - USB Keyboard System Control: device removed
[ 1378.766] (II) event17 - USB Keyboard Consumer Control: device removed
[ 1378.816] (II) event18 - USB Keyboard Mouse: device removed
[ 1378.869] (II) event21 - Microsoft® LifeCam HD-3000: Mi: device removed
[ 1378.936] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device removed
[ 1379.016] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device removed
[ 1379.096] (II) event23 - Logitech G533 Gaming Headset: device removed
[ 1379.162] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 1391.426] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 1391.584] (II) AMDGPU(0): EDID vendor "ACR", prod id 299
[ 1391.585] (II) AMDGPU(0): Using hsync ranges from config file
[ 1391.585] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 1391.585] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 1391.585] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 1391.585] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 1391.585] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 1391.601] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 1391.602] (II) event2 - Power Button: device is a keyboard
[ 1391.603] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 1391.603] (II) event1 - Power Button: device is a keyboard
[ 1391.605] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 1391.605] (II) event0 - Sleep Button: device is a keyboard
[ 1391.608] (II) event19 - USB Keyboard: is tagged by udev as: Keyboard
[ 1391.608] (II) event19 - USB Keyboard: device is a keyboard
[ 1391.611] (II) event15 - USB Keyboard: is tagged by udev as: Keyboard
[ 1391.611] (II) event15 - USB Keyboard: device is a keyboard
[ 1391.614] (II) event16 - USB Keyboard System Control: is tagged by udev as: Keyboard
[ 1391.614] (II) event16 - USB Keyboard System Control: device is a keyboard
[ 1391.616] (II) event17 - USB Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 1391.616] (II) event17 - USB Keyboard Consumer Control: device is a keyboard
[ 1391.619] (II) event18 - USB Keyboard Mouse: is tagged by udev as: Mouse
[ 1391.619] (II) event18 - USB Keyboard Mouse: device is a pointer
[ 1391.622] (II) event21 - Microsoft® LifeCam HD-3000: Mi: is tagged by udev as: Keyboard
[ 1391.622] (II) event21 - Microsoft® LifeCam HD-3000: Mi: device is a keyboard
[ 1391.683] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: is tagged by udev as: Mouse
[ 1391.683] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device set to 800 DPI
[ 1391.683] (II) event20 - Kingsis Peripherals ZOWIE Gaming mouse: device is a pointer
[ 1391.689] (II) event22 - Logitech G533 Gaming Headset Consumer Control: is tagged by udev as: Keyboard
[ 1391.690] (II) event22 - Logitech G533 Gaming Headset Consumer Control: device is a keyboard
[ 1391.695] (II) event23 - Logitech G533 Gaming Headset: is tagged by udev as: Keyboard
[ 1391.696] (II) event23 - Logitech G533 Gaming Headset: device is a keyboard
