Blank screen on reboot or system start
For the last few weeks I have noticed that whenever I try to reboot my laptop, during the boot process, the screen goes blank after the splash screen. Prior to the upgrade from today, simply powering down and powering on the laptop resolved the issue. To get the laptop to boot this morning, I had to switch my kernel from 6.7 to 6.6. Any ideas what is happening here?
  Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=d59c6405-794b-44c4-bfdb-c12ad6c14dd2 rw quiet splash
    resume=UUID=9fc21cde-2955-4e99-a3e5-e84c11f7c8a4 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 with: krunner,latte-dock vt: 2 dm: SDDM
  Type: Laptop System: LG product: 16ZB90R-G.AA75G v: 0.1
    serial: <superuser required> Chassis: type: 10 v: 0.1
  Mobo: LG model: 16ZB90R v: FAB1 serial: <superuser required> part-nu: EVO
    uuid: <superuser required> UEFI: Phoenix v: R4ZH0340 X64 date: 01/03/2023
  ID-1: BAT0 charge: 59.9 Wh (77.0%) condition: 77.8/80.0 Wh (97.2%)
    power: 6.6 W volts: 8.2 min: 7.7 model: LG LGC-LGC type: Li-ion
    serial: <filter> status: discharging cycles: 104
  System RAM: total: 16 GiB available: 15.34 GiB used: 4.13 GiB (26.9%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous size: 2 GiB
    speed: 4267 MT/s volts: curr: 0.6 width (bits): data: 16 total: 16
    manufacturer: SK Hynix part-no: H54G56CYRBX247N serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous size: 2 GiB
  Device-3: Controller0-ChannelC type: LPDDR4 detail: synchronous size: 2 GiB
  Device-4: Controller0-ChannelD type: LPDDR4 detail: synchronous size: 2 GiB
  Device-5: Controller1-ChannelA type: LPDDR4 detail: synchronous size: 2 GiB
  Device-6: Controller1-ChannelB type: LPDDR4 detail: synchronous size: 2 GiB
  Device-7: Controller1-ChannelC type: LPDDR4 detail: synchronous size: 2 GiB
  Device-8: Controller1-ChannelD type: LPDDR4 detail: synchronous size: 2 GiB
  Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x411C
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
    desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 400 min/max: 400/5000:3700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400
    bogomips: 83584
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: LG driver: i915
    v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
    active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:a7a0
    class-ID: 0300
  Device-2: Realtek LG Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 0bda:5641
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 model: LG Display 0x06eb built: 2021 res: 2560x1600 hz: 60
    dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 2560x1600
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 14.98 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-P) driver: mesa intel v: 24.0.2-manjaro1.1
    device-ID: 8086:a7a0 surfaces: xcb,xlib
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: LG
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51ca class-ID: 0401
  API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 127.45 GiB (26.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL4512HBLU-00B07
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HXC7102Q temp: 30.9 C
    scheme: GPT
  ID-1: / raw-size: 459.76 GiB size: 451.47 GiB (98.20%)
    used: 127.45 GiB (28.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: d59c6405-794b-44c4-bfdb-c12ad6c14dd2
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0B81-822E
  ID-1: swap-1 type: partition size: 16.88 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 9fc21cde-2955-4e99-a3e5-e84c11f7c8a4
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-2:2 info: Realtek LG Camera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0bda:5641 class-ID: 0e02 serial: <filter>
  Device-2: 3-6:3 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
    type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 1050:0407 class-ID: 0b00
  Device-3: 3-7:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 27c6:6a94 class-ID: ef00 serial: <filter>
  Device-4: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 347 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
    test_resume image: 6.13 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1471 libs: 481 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: yakuake inxi: 3.3.33
[    0.090144]   #1  #3  #5  #7
[    0.098121] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.563711] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[    0.565103] pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
[    1.058965] pnp 00:04: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[    1.115575] hpet_acpi_add: no address or irqs in _CRS
[    1.407059] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.412419] usb: port power management may be unreliable
[   10.368918] systemd-journald[340]: File /var/log/journal/31aa7f685e0f4395b099236ea0d7cb3a/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   10.455352] ACPI Error: No handler for Region [XIN1] (000000007d6c6366) [UserDefinedRegion] (20230628/evregion-130)
[   10.455357] ACPI Error: Region UserDefinedRegion (ID=143) has no handler (20230628/exfldio-261)
[   10.455361] ACPI Error: Aborting method \_SB.PC00.LPCB.LGEC.SEN1._TMP due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
[   10.465534] ACPI Error: No handler for Region [XIN1] (000000007d6c6366) [UserDefinedRegion] (20230628/evregion-130)
[   10.465542] ACPI Error: Region UserDefinedRegion (ID=143) has no handler (20230628/exfldio-261)
[   10.465547] ACPI Error: Aborting method \_SB.PC00.LPCB.LGEC.SEN1._TMP due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
[   10.465556] thermal thermal_zone2: failed to read out thermal zone (-5)
[   10.470652] ACPI Error: No handler for Region [XIN1] (000000007d6c6366) [UserDefinedRegion] (20230628/evregion-130)
[   10.470658] ACPI Error: Region UserDefinedRegion (ID=143) has no handler (20230628/exfldio-261)
[   10.470664] ACPI Error: Aborting method \_SB.PC00.LPCB.LGEC.SEN2._TMP due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
[   10.476484] ACPI Error: No handler for Region [XIN1] (000000007d6c6366) [UserDefinedRegion] (20230628/evregion-130)
[   10.476489] ACPI Error: Region UserDefinedRegion (ID=143) has no handler (20230628/exfldio-261)
[   10.476494] ACPI Error: Aborting method \_SB.PC00.LPCB.LGEC.SEN2._TMP due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
[   10.476501] thermal thermal_zone3: failed to read out thermal zone (-5)
[   10.613293] i2c i2c-0: Systems with more than 4 memory slots not supported yet, not instantiating SPD
[   10.724080] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[   10.894480] ACPI Warning: \_SB.PC00.XHCI.RHUB.HS10._DSM: Argument #4 type mismatch - Found [Integer], ACPI requires [Package] (20230628/nsarguments-61)
[   11.186073] thermal thermal_zone6: failed to read out thermal zone (-61)
[   11.195459] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[   11.526593] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[   11.851714] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[   12.401305] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[   12.426208] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[   12.426312] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[   12.426313] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6
[   12.426315] iwlwifi 0000:00:14.3: Loaded firmware version: 83.e8f84e98.0 so-a0-gf-a0-83.ucode
[   12.426316] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[   12.426317] iwlwifi 0000:00:14.3: 0x000002F0 | trm_hw_status0
[   12.426318] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[   12.426318] iwlwifi 0000:00:14.3: 0x004DB338 | branchlink2
[   12.426319] iwlwifi 0000:00:14.3: 0x0000821C | interruptlink1
[   12.426320] iwlwifi 0000:00:14.3: 0x0000821C | interruptlink2
[   12.426320] iwlwifi 0000:00:14.3: 0x0000F234 | data1
[   12.426321] iwlwifi 0000:00:14.3: 0x00000010 | data2
[   12.426321] iwlwifi 0000:00:14.3: 0x00000000 | data3
[   12.426322] iwlwifi 0000:00:14.3: 0x003A2108 | beacon time
[   12.426322] iwlwifi 0000:00:14.3: 0x00077C4D | tsf low
[   12.426323] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi
[   12.426323] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[   12.426324] iwlwifi 0000:00:14.3: 0x0008C079 | time gp2
[   12.426324] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[   12.426325] iwlwifi 0000:00:14.3: 0x00000053 | uCode version major
[   12.426325] iwlwifi 0000:00:14.3: 0xE8F84E98 | uCode version minor
[   12.426326] iwlwifi 0000:00:14.3: 0x00000370 | hw version
[   12.426326] iwlwifi 0000:00:14.3: 0x00C80002 | board version
[   12.426327] iwlwifi 0000:00:14.3: 0x80F2F500 | hcmd
[   12.426328] iwlwifi 0000:00:14.3: 0x00020000 | isr0
[   12.426328] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[   12.426328] iwlwifi 0000:00:14.3: 0x48F00002 | isr2
[   12.426329] iwlwifi 0000:00:14.3: 0x04C0000A | isr3
[   12.426329] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[   12.426330] iwlwifi 0000:00:14.3: 0x001D0103 | last cmd Id
[   12.426331] iwlwifi 0000:00:14.3: 0x0000F234 | wait_event
[   12.426331] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[   12.426332] iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
[   12.426332] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[   12.426333] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[   12.426333] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[   12.426334] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[   12.426334] iwlwifi 0000:00:14.3: 0x00003054 | flow_handler
[   12.426399] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[   12.426400] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7
[   12.426401] iwlwifi 0000:00:14.3: 0x2010190E | ADVANCED_SYSASSERT
[   12.426401] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[   12.426402] iwlwifi 0000:00:14.3: 0x80471ABC | umac branchlink2
[   12.426402] iwlwifi 0000:00:14.3: 0xC0081500 | umac interruptlink1
[   12.426403] iwlwifi 0000:00:14.3: 0x00000000 | umac interruptlink2
[   12.426403] iwlwifi 0000:00:14.3: 0x0102171C | umac data1
[   12.426404] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data2
[   12.426404] iwlwifi 0000:00:14.3: 0xDEADBEEF | umac data3
[   12.426405] iwlwifi 0000:00:14.3: 0x00000053 | umac major
[   12.426405] iwlwifi 0000:00:14.3: 0xE8F84E98 | umac minor
[   12.426406] iwlwifi 0000:00:14.3: 0x0008C073 | frame pointer
[   12.426406] iwlwifi 0000:00:14.3: 0xC0886BE0 | stack pointer
[   12.426407] iwlwifi 0000:00:14.3: 0x0025010D | last host cmd
[   12.426407] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[   12.426514] iwlwifi 0000:00:14.3: IML/ROM dump:
[   12.426515] iwlwifi 0000:00:14.3: 0x00000B03 | IML/ROM error/state
[   12.426523] iwlwifi 0000:00:14.3: 0x00008149 | IML/ROM data1
[   12.426531] iwlwifi 0000:00:14.3: 0x00000090 | IML/ROM WFPM_AUTH_KEY_0
[   12.426537] iwlwifi 0000:00:14.3: Fseq Registers:
[   12.426539] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[   12.426544] iwlwifi 0000:00:14.3: 0x003E0003 | FSEQ_TOP_INIT_VERSION
[   12.426593] iwlwifi 0000:00:14.3: 0x00190003 | FSEQ_CNVIO_INIT_VERSION
[   12.426643] iwlwifi 0000:00:14.3: 0x0000A652 | FSEQ_OTP_VERSION
[   12.426693] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION
[   12.426745] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[   12.426795] iwlwifi 0000:00:14.3: 0x00080400 | FSEQ_CNVI_ID
[   12.426847] iwlwifi 0000:00:14.3: 0x00400410 | FSEQ_CNVR_ID
[   12.426897] iwlwifi 0000:00:14.3: 0x00080400 | CNVI_AUX_MISC_CHIP
[   12.426951] iwlwifi 0000:00:14.3: 0x00400410 | CNVR_AUX_MISC_CHIP
[   12.427001] iwlwifi 0000:00:14.3: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[   12.427051] iwlwifi 0000:00:14.3: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[   12.427091] iwlwifi 0000:00:14.3: 0x00190003 | FSEQ_PREV_CNVIO_INIT_VERSION
[   12.427093] iwlwifi 0000:00:14.3: 0x003E0003 | FSEQ_WIFI_FSEQ_VERSION
[   12.427095] iwlwifi 0000:00:14.3: 0x003E0003 | FSEQ_BT_FSEQ_VERSION
[   12.427098] iwlwifi 0000:00:14.3: 0x000000C8 | FSEQ_CLASS_TP_VERSION
[   12.427106] iwlwifi 0000:00:14.3: UMAC CURRENT PC: 0x80493890
[   12.427108] iwlwifi 0000:00:14.3: LMAC1 CURRENT PC: 0xd0
[   12.427207] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[   13.176421] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[   13.355467] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[   13.424631] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[   14.427198] sddm-greeter[721]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   19.774678] warning: `warp-svc' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
