Blackscreen after Update
its the amdgpu… you can try to enable early loading:
kate /etc/mkinitcpio.conf
and edit the modules section to look like this:
MODULES=(amdgpu nvidia nvidia_drm nvidia_uvm nvidia_modeset)
save it and update it:
sudo mkinitcpio -P
reboot and test… if it happens again, downgrade the linux-firmware + linux-firmware-whence packages to the previous version, reboot and test again…
No dice. New log:
Small comment. I had installed optimus-manager because I couldn’t get usbc-to-screen connection working otherwise, as it would try to use the integrated gpu and lag.
Jul 13 11:36:44 Ray-Laptop kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11 #12 #13 #14 #15
Jul 13 11:36:44 Ray-Laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20220331/dswload2-326)
Jul 13 11:36:44 Ray-Laptop kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Jul 13 11:36:44 Ray-Laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20220331/dswload2-162)
Jul 13 11:36:44 Ray-Laptop kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20220331/psobject-220)
Jul 13 11:36:44 Ray-Laptop kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Jul 13 11:36:44 Ray-Laptop kernel: pci 0000:00:08.1: can't derive routing for PCI INT A
Jul 13 11:36:44 Ray-Laptop kernel: pci 0000:00:08.1: PCI INT A: not connected
Jul 13 11:36:44 Ray-Laptop kernel: pci 0000:00:08.3: can't derive routing for PCI INT A
Jul 13 11:36:44 Ray-Laptop kernel: pci 0000:00:08.3: PCI INT A: not connected
Jul 13 11:36:44 Ray-Laptop kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Jul 13 11:36:44 Ray-Laptop kernel: pci 0000:00:00.2: PCI INT A: not connected
Jul 13 11:36:44 Ray-Laptop kernel: hpet_acpi_add: no address or irqs in _CRS
Jul 13 11:36:44 Ray-Laptop kernel: tpm tpm0: AMD fTPM version 0x3004e00020005 causes system stutter; hwrng disabled
Jul 13 11:36:44 Ray-Laptop kernel: ATPX version 1, functions 0x00000001
Jul 13 11:36:44 Ray-Laptop kernel: ATPX Hybrid Graphics
Jul 13 11:36:44 Ray-Laptop kernel: amdgpu 0000:05:00.0: amdgpu: PSP runtime database doesn't exist
Jul 13 11:36:44 Ray-Laptop kernel: amdgpu: SRAT table not found
Jul 13 11:36:44 Ray-Laptop kernel: nvidia: loading out-of-tree module taints kernel.
Jul 13 11:36:44 Ray-Laptop kernel: nvidia: module license 'NVIDIA' taints kernel.
Jul 13 11:36:44 Ray-Laptop kernel: Disabling lock debugging due to kernel taint
Jul 13 11:36:44 Ray-Laptop kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  535.54.03  Tue Jun  6 22:20:39 UTC 2023
Jul 13 11:36:44 Ray-Laptop kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Jul 13 11:36:44 Ray-Laptop kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Jul 13 11:36:44 Ray-Laptop kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Jul 13 11:36:44 Ray-Laptop kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Jul 13 11:36:44 Ray-Laptop kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jul 13 11:36:44 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:44 Ray-Laptop kernel: [drm] perform_link_training_with_retries: Link(0) training attempt 1 of 4 failed @ rate(30) x lane(4) : fail reason:(1)
Jul 13 11:36:44 Ray-Laptop kernel: [drm] perform_link_training_with_retries: Link(0) training attempt 2 of 4 failed @ rate(30) x lane(4) : fail reason:(1)
Jul 13 11:36:44 Ray-Laptop kernel: [drm] perform_link_training_with_retries: Link(0) training attempt 3 of 4 failed @ rate(30) x lane(4) : fail reason:(1)
Jul 13 11:36:44 Ray-Laptop kernel: [drm] enabling link 0 failed: 15
Jul 13 11:36:45 Ray-Laptop kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Jul 13 11:36:45 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:45 Ray-Laptop kernel: mt7921e: probe of 0000:04:00.0 failed with error -110
Jul 13 11:36:46 Ray-Laptop (uetoothd)[626]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Jul 13 11:36:46 Ray-Laptop bluetoothd[626]: src/plugin.c:plugin_init() System does not support csip plugin
Jul 13 11:36:46 Ray-Laptop bluetoothd[626]: src/plugin.c:plugin_init() System does not support vcp plugin
Jul 13 11:36:46 Ray-Laptop bluetoothd[626]: src/plugin.c:plugin_init() System does not support mcp plugin
Jul 13 11:36:46 Ray-Laptop bluetoothd[626]: src/plugin.c:plugin_init() System does not support bass plugin
Jul 13 11:36:46 Ray-Laptop bluetoothd[626]: src/plugin.c:plugin_init() System does not support bap plugin
Jul 13 11:36:46 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:47 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:48 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:48 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:48 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:49 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:49 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:49 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:50 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:50 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:50 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:51 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:51 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:51 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:52 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:52 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:52 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:53 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:53 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:53 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:54 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:54 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:54 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:55 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:55 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:55 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:56 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:56 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:56 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:57 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:57 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:57 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:58 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:58 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:58 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:59 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:36:59 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:36:59 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:00 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:00 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:00 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:01 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:01 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:01 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:02 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:02 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:02 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:03 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:03 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:03 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:04 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:04 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:04 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:05 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:05 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:05 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:05 Ray-Laptop sddm[687]: Could not setup default cursor
Jul 13 11:37:06 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:06 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:06 Ray-Laptop kernel: [drm:dc_send_update_cursor_info_to_dmu [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: QObject: Cannot create children for a parent that is in a different thread.
                                              (Parent is QGuiApplication(0x7ffed7627880), parent's thread is QThread(0x55e418cdeb90), current thread is QThread(0x55e418e3b5f0)
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.27'
Jul 13 11:37:07 Ray-Laptop sddm-greeter[928]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.28'
Jul 13 11:37:08 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:08 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:08 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:09 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:09 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:09 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:09 Ray-Laptop kernel: [drm:dc_send_update_cursor_info_to_dmu [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:10 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:10 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:10 Ray-Laptop kernel: [drm:dc_send_update_cursor_info_to_dmu [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:11 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:11 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:11 Ray-Laptop kernel: [drm:dc_send_update_cursor_info_to_dmu [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:11 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:12 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:12 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:13 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:13 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:14 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:14 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:15 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:15 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:16 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:16 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:17 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:17 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:18 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:18 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:19 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:19 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:20 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:20 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:21 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:21 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:22 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:22 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:23 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:23 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:24 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:24 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:24 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:25 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:25 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:25 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:25 Ray-Laptop kernel: [drm:dc_send_update_cursor_info_to_dmu [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:26 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:26 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:26 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:27 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:27 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:27 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:28 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:28 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:28 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:29 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:29 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:29 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:30 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:30 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:30 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:31 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:37:31 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:37:31 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:38:15 Ray-Laptop kernel: ucsi_acpi USBC000:00: GET_CONNECTOR_STATUS failed (-110)
Jul 13 11:39:26 Ray-Laptop sddm[687]: Error from greeter session: "Process crashed"
Jul 13 11:39:26 Ray-Laptop sddm[687]: Auth: sddm-helper (--socket /tmp/sddm-auth-13d89745-9cfd-4897-adb4-d53c5e440cd1 --id 2 --start /usr/bin/sddm-greeter --socket /tmp/sddm-:0-ltIGYK --theme /usr/share/sddm/themes/breath --user sddm --greeter) crashed (exit code 1)
Jul 13 11:39:26 Ray-Laptop sddm[687]: Auth: sddm-helper exited with 1
Jul 13 11:39:26 Ray-Laptop sddm[687]: Signal received: SIGTERM
Jul 13 11:39:26 Ray-Laptop /usr/bin/nvidia-powerd[739]: Could not set max CPU limit: current CPU limit (Khz): 3300000
Jul 13 11:39:26 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:26 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:39:26 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:27 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:27 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:39:27 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:28 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:28 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:28 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 13 11:39:29 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 13 11:39:30 Ray-Laptop systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
well if you search for these logs:
they all point out to some firmware issues…
so use the 5.15 in the meantime, and when there is a next update of firmware, test again…
you can install optimus again…
The problem is that 5.15 doesnt work with my wifi card, so I can only use it in the office, not at home, dont have lan at home.
But, its odd, cant I downgrade anything else to fix this?
I would just skip this whole update and wait till the next one… Since downgrading kernels and nvidia would be problematic, unless you still have in cache previous versions of nvidia packages…
Or you can timeshift back, if you use it, blacklist kernels+nvidia from updating, until the next update…
I used manjaro-downgrade to downgrade nvidia, to the previous version, but that surprisingly didnt help.
Okay, now downgrading nvidia to the previous + sudo mkinitcpio -P did actually enable me to run 6.1 again. Yay
Something I noticed; this line from your initial inxi
Kernel 6.1.30-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
indicates that your machine hadn’t been updated for a long time before your failed recent attempt. Since you now successfully updated to 5.15LTS maybe it would have been easier to remove all the other kernels, reboot and then reinstall them.
/var/log/optimus-manager/switch/switch-20230713T132831.log: line 1: [6]: command not found
/var/log/optimus-manager/switch/switch-20230713T132831.log: line 2: [6]: command not found
/var/log/optimus-manager/switch/switch-20230713T132831.log: line 3: [6]: command not found
/var/log/optimus-manager/switch/switch-20230713T132831.log: line 4: [26]: command not found
/var/log/optimus-manager/switch/switch-20230713T132831.log: line 5: syntax error near unexpected token `('
/var/log/optimus-manager/switch/switch-20230713T132831.log: line 5: `[27] INFO: Unloading modules ['nouveau'] (if loaded)'
Issues with optimus now. Which I need to switch to nvidia to display my usbc screen connection. Unless there is anothe roptionf or it
[2122] ERROR: Xorg pre-start setup error
File “/usr/lib/python3.11/site-packages/optimus_manager/kernel.py”, line 245, in _load_module
subprocess.check_call(
File “/usr/lib/python3.11/subprocess.py”, line 413, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command ‘modprobe nvidia NVreg_UsePageAttributeTable=1’ returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File “/usr/lib/python3.11/site-packages/optimus_manager/hooks/pre_xorg_start.py”, line 51, in main
setup_kernel_state(config, prev_state, requested_mode)
File “/usr/lib/python3.11/site-packages/optimus_manager/kernel.py”, line 22, in setup_kernel_state
_nvidia_up(config, hybrid=(requested_mode == “hybrid”))
File “/usr/lib/python3.11/site-packages/optimus_manager/kernel.py”, line 95, in _nvidia_up
_load_nvidia_modules(config, available_modules)
File “/usr/lib/python3.11/site-packages/optimus_manager/kernel.py”, line 164, in _load_nvidia_modules
_load_module(available_modules, “nvidia”, options=nvidia_options)
File “/usr/lib/python3.11/site-packages/optimus_manager/kernel.py”, line 249, in _load_module
raise KernelSetupError(f"Error running modprobe for {module}: {e.stderr}") from e
optimus_manager.kernel.KernelSetupError: Error running modprobe for nvidia: None
[2129] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
[2129] INFO: Writing state {‘type’: ‘pre_xorg_start_failed’, ‘switch_id’: ‘20230713T132831’, ‘requested_mode’: ‘nvidia’}
Ahhh, I think this is because of my downgrade:
  1. [ 684.243799] nvidia: version magic '6.1.31-2-MANJARO SMP preempt mod_unload ’ should be '6.1.38-1-MANJARO SMP preempt mod_unload ’
yes its because of the downgraded nvidia…
so just skip the whole update and wait till the next one…
Used GitHub - Frogging-Family/nvidia-all: Nvidia driver latest to 396 series AIO installer to manually install the 525 drivers and that allows me to use it at least for now.
