I got a blackscreen after the update. Couldnt even ctrl-alt-f3. Used recovery usb and chroot, downgraded sddm to 0.19 and still got the same issue.
inxi -v7azy
12System:
12Kernel 6.1.30-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.2.1
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2213 quiet systemd.show_status=1
splash driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
12Desktop KDE Plasma 12v ERR-101 12tk Qt 12v 5.15.10 12dm N/A 12Distro Manjaro Linux
12base Arch Linux
12Machine:
12Type Laptop 12System ASUSTeK 12product ROG Strix G713RS_G713RS 12v 1.0
12serial <filter>
12Mobo ASUSTeK 12model G713RS 12v 1.0 12serial <filter> 12UEFI American Megatrends
LLC. 12v G713RS.320 12date 07/29/2022
12Battery:
12ID-1 BAT0 12charge 85.9 Wh (100.0%) 12condition 85.9/90.0 Wh (95.5%) 12volts 17.0
12min 15.9 12model AS3GWAF3KC GA50358 12type Unknown 12serial <filter> 12status full
12Memory:
12System RAM 12total 32 GiB 12available 30.62 GiB 12used 5 GiB (16.3%)
12Array-1 12capacity 64 GiB 12slots 2 12modules 2 12EC None 12max-module-size 32 GiB
12note est.
12Device-1 DIMM 0 12type DDR5 12detail synchronous unbuffered (unregistered)
12size 16 GiB 12speed 4800 MT/s 12volts 12curr 1.1 12min 1.1 12max 1.1 12width (bits)
12data 64 12total 64 12manufacturer Samsung 12part-no M425R2GA3BB0-CQKOL
12serial <filter>
12Device-2 DIMM 0 12type DDR5 12detail synchronous unbuffered (unregistered)
12serial <filter>
12CPU:
12Info 12model AMD Ryzen 9 6900HX with Radeon Graphics 12socket FP7 12bits 64
12type MT MCP 12arch Zen 3+ 12gen 4 12level v3 12note check 12built 2022
12process TSMC n6 (7nm) 12family 0x19 (25) 12model-id 0x44 (68) 12stepping 1
12microcode 0xA404101
12Topology 12cpus 1x 12cores 8 12tpc 2 12threads 16 12smt enabled 12cache 12L1 512 KiB
12desc d-8x32 KiB; i-8x32 KiB 12L2 4 MiB 12desc 8x512 KiB 12L3 16 MiB 12desc 1x16 MiB
12Speed (MHz) 12avg 1812 12high 3300 12min/max 1600/4934 12boost enabled
12base/boost 3300/4925 12scaling 12driver acpi-cpufreq 12governor schedutil
12volts 1.2 V 12ext-clock 100 MHz 12cores 121 1600 122 1600 123 1600 124 1600 125 1600
126 1600 127 1600 128 1600 129 1600 1210 1600 1211 1600 1212 1600 1213 3300 1214 3300 1215 1600
1216 1600 12bogomips 105440
12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
12Vulnerabilities
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type retbleed 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
12vendor ASUSTeK 12driver nvidia 12v 530.41.03 12non-free 535.xx+
12status current (as of 2023-07) 12arch Ampere 12code GAxxx 12process TSMC n7 (7nm)
12built 2020-22 12pcie 12gen 4 12speed 16 GT/s 12lanes 8 12link-max 12lanes 16
12bus-ID 01:00.0 12chip-ID 10de:249c 12class-ID 0300
12Device-2 AMD Rembrandt [Radeon 680M] 12vendor ASUSTeK 12driver amdgpu 12v kernel
12arch RDNA-2 12code Navi-2x 12process TSMC n7 (7nm) 12built 2020-22 12pcie 12gen 4
12speed 16 GT/s 12lanes 16 12ports 12active eDP-1 12empty DP-1, DP-2, DP-3, DP-4,
DP-5 12bus-ID 05:00.0 12chip-ID 1002:1681 12class-ID 0300 12temp 60.0 C
12Display 12server X.org 12v 1.21.1.8 12driver 12X 12loaded modesetting 12dri radeonsi
12gpu amdgpu 12display-ID :0
12Monitor-1 eDP-1 12model BOE Display 0x0a69 12built 2021 12res 2560x1440 12dpi 171
12gamma 1.2 12size 381x214mm (15x8.43") 12diag 437mm (17.2") 12ratio 16:9 12modes
12max 2560x1440 12min 640x480
12API OpenGL 12Message GL data unavailable for root.
12Audio:
12Device-1 NVIDIA GA104 High Definition Audio 12vendor ASUSTeK
12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 8 12link-max
12lanes 16 12bus-ID 01:00.1 12chip-ID 10de:228b 12class-ID 0403
12Device-2 AMD ACP/ACP3X/ACP6x Audio Coprocessor 12vendor ASUSTeK
12driver snd_pci_acp6x 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16
12bus-ID 05:00.5 12chip-ID 1022:15e2 12class-ID 0480
12Device-3 AMD Family 17h/19h HD Audio 12vendor ASUSTeK 12driver snd_hda_intel
12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16 12bus-ID 05:00.6 12chip-ID 1022:15e3
12class-ID 0403
12Device-4 Generalplus USB Audio Device
12driver hid-generic,snd-usb-audio,usbhid 12type USB 12rev 1.1 12speed 12 Mb/s
12lanes 1 12mode 1.1 12bus-ID 3-2.3:5 12chip-ID 1b3f:2008 12class-ID 0300
12API ALSA 12v k6.1.30-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
12tools alsactl,alsamixer,amixer
12Server-1 sndiod 12v N/A 12status off 12tools aucat,midicat,sndioctl
12Server-2 JACK 12v 1.9.22 12status off 12tools N/A
12Server-3 PipeWire 12v 0.3.73 12status off 12with pipewire-media-session
12status off 12tools pw-cli
12Server-4 PulseAudio 12v 16.1 12status off 12with pulseaudio-alsa 12type plugin
12tools pacat,pactl
12Network:
12Device-1 Realtek RTL8125 2.5GbE 12vendor ASUSTeK 12driver r8169 12v kernel 12pcie
12gen 2 12speed 5 GT/s 12lanes 1 12port e000 12bus-ID 03:00.0 12chip-ID 10ec:8125
12class-ID 0200
12IF enp3s0 12state down 12mac <filter>
12Device-2 MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
12vendor Foxconn 12driver mt7921e 12v kernel 12pcie 12gen 2 12speed 5 GT/s 12lanes 1
12bus-ID 04:00.0 12chip-ID 14c3:0616 12class-ID 0280
12IF wlo1 12state up 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type dynamic noprefixroute 12scope global
12IP v6 <filter> 12type noprefixroute 12scope link
12WAN IP <filter>
12Bluetooth:
12Device-1 Foxconn / Hon Hai Wireless_Device 12driver btusb 12v 0.8 12type USB
12rev 2.1 12speed 480 Mb/s 12lanes 1 12mode 2.0 12bus-ID 1-4:3 12chip-ID 0489:e0e2
12class-ID e001 12serial <filter>
12Report rfkill 12ID hci0 12rfk-id 0 12state down 12bt-service N/A 12rfk-block
12hardware no 12software no 12address see --recommends
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 957.64 GiB 12used 710.43 GiB (74.2%)
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Micron 12model 2450 MTFDKBA1T0TFK
12size 953.87 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 63.2 Gb/s
12lanes 4 12tech SSD 12serial <filter> 12fw-rev V5MA010 12temp 42.9 C
12SMART yes 12health PASSED 12on 63d 23h 12cycles 365
12read-units 21,665,974 [11.0 TB] 12written-units 35,662,660 [18.2 TB]
12ID-2 /dev/sda 12maj-min 8:0 12model USB2.0 Flash Disk 12size 3.77 GiB 12block-size
12physical 512 B 12logical 512 B 12type USB 12rev 2.0 12spd 480 Mb/s 12lanes 1 12mode 2.0
12tech SSD 12serial <filter> 12fw-rev 1100
12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 944.77 GiB 12size 928.86 GiB (98.32%) 12used 710.43 GiB (76.5%)
12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2 12label N/A
12uuid 415d8219-ad78-4626-ab10-536750de4619
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 312 KiB (0.1%)
12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label NO_LABEL
12uuid F729-D657
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/nvme0n1p3 12maj-min 259:3 12size 8.8 GiB 12fs swap 12label swap
12uuid 5dd48583-a3fe-4bb0-af56-f4678bff9466
12ID-2 /dev/sda1 12maj-min 8:1 12size 3.59 GiB 12fs N/A 12label MANJARO_KDE_2213
12uuid 2023-05-29-08-47-39-00
12ID-3 /dev/sda2 12maj-min 8:2 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 1517-A94A
12USB:
12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
12Device-1 1-3:2 12info ASUSTek N-KEY Device 12type keyboard 12driver asus,usbhid
12interfaces 1 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA
12chip-ID 0b05:19b6 12class-ID 0301
12Device-2 1-4:3 12info Foxconn / Hon Hai Wireless_Device 12type bluetooth
12driver btusb 12interfaces 3 12rev 2.1 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
12mode 2.0 12power 100mA 12chip-ID 0489:e0e2 12class-ID e001 12serial <filter>
12Hub-2 2-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 3 12rev 2.0
12Device-1 3-1:2 12info Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
12type mass storage 12driver usb-storage 12interfaces 1 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 500mA 12chip-ID 090c:1000
12class-ID 0806 12serial <filter>
12Hub-4 3-2:3 12info Genesys Logic USB 2.0 Hub / D-Link DUB-H4 12ports 4 12rev 2.0
12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 100mA 12chip-ID 05e3:0606
12class-ID 0900
12Device-1 3-2.1:4 12info [Maxxter] USB GAMING MOUSE 12type mouse,keyboard
12driver hid-generic,usbhid 12interfaces 2 12rev 1.1 12speed 1.5 Mb/s (183 KiB/s)
12lanes 1 12mode 1.0 12power 100mA 12chip-ID 18f8:1286 12class-ID 0301
12Device-2 3-2.3:5 12info Generalplus USB Audio Device 12type audio,HID
12driver hid-generic,snd-usb-audio,usbhid 12interfaces 4 12rev 1.1
12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA 12chip-ID 1b3f:2008
12class-ID 0300
12Hub-5 4-0:1 12info super-speed hub 12ports 2 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Hub-6 5-0:1 12info hi-speed hub with single TT 12ports 1 12rev 2.0
12Hub-7 6-0:1 12info Linux Foundation 3.0 root hub 12ports N/A 12rev 3.0
12speed 5 Gb/s (596.0 MiB/s) 12lanes 1 12mode 3.2 gen-1x1 12chip-ID 1d6b:0003
12class-ID 0900
12Hub-8 7-0:1 12info hi-speed hub with single TT 12ports 1 12rev 2.0
12Hub-9 8-0:1 12info super-speed hub 12ports 1 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Hub-10 9-0:1 12info hi-speed hub with single TT 12ports 1 12rev 2.0
12Hub-11 10-0:1 12info super-speed hub 12ports 1 12rev 3.1
12speed 10 Gb/s (1.16 GiB/s) 12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003
12class-ID 0900
12Sensors:
12System Temperatures 12cpu 65.8 C 12mobo N/A 12gpu amdgpu 12temp 60.0 C
12Fan Speeds (RPM) 12cpu 0
12Info:
12Processes 0 12Uptime 17m 12wakeups 4 12Init systemd 12v 253 12default graphical
12tool systemctl 12Compilers 12gcc 13.1.1 12clang 15.0.7 12Packages 1637 12pm pacman
12pkgs 1630 12libs 429 12tools pamac,yay 12pm flatpak 12pkgs 7
12Client Unknown Client: systemd 12inxi 3.3.28
journal ctl output
Jul 12 10:23:54 Ray-Laptop kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.TZ01], AE_ALREADY_EXISTS (20220331/dswload2-326)
Jul 12 10:23:54 Ray-Laptop kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
Jul 12 10:23:54 Ray-Laptop kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP2.WWAN], AE_NOT_FOUND (20220331/dswload2-162)
Jul 12 10:23:54 Ray-Laptop kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20220331/psobject-220)
Jul 12 10:23:54 Ray-Laptop kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Jul 12 10:23:54 Ray-Laptop kernel: xhci_hcd 0000:06:00.4: can't setup: -110
Jul 12 10:23:54 Ray-Laptop kernel: xhci_hcd 0000:06:00.4: init 0000:06:00.4 fail, -110
Jul 12 10:23:56 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:30 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:31 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:31 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 12 10:24:31 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:32 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:32 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
Jul 12 10:24:32 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:33 Ray-Laptop kernel: [drm:dc_dmub_srv_wait_idle [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:33 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
Jul 12 10:24:33 Ray-Laptop kernel: [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error queuing DMUB command: status=2
