Blackscreen after suspend (Manjaro Gnome, i7, UHD 750)
Hi all
I switched to Manjaro coming from Ubuntu a few months back and I am loving it.
Now after seeing my electricity bill I would like to be able to suspend my desktop (DELL XPS 8940) when not needed.
Problem: Whenever I try to suspend (automatic or manual), the suspend works. However, when waking (Keyboard or power button), it audibly does start, peripherals light up, and the screen is getting a signal, but both screens remain black. No mouse, no cursor. Blindly typing commands or getting into tty2 fail.
What have I tried: basically everything that could be found on the first 5 pages of google search that was even remotely connected to this issue. Among those were:
  • Trying new kernel (went from 5.15.32 to 5.17)
  • trying systemd-swap (though I have an actual swap partition)
  • removing all things nvidia (I use my GPU as passthrough for KVM)
  • blacklisting all things nvidia (see below)
Note The nvidia GPU is used with KVM as passthrough, so the host does not, should not interact with it at all. Thus I removed all things nvidia. Would that have an impact here?
if you have any idea how to further troubleshoot this, please let me know.
Here is some relevant output:
Grub
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor resume=UUID=7d52c7f7-63f9-4c4e-8079-42979cbaa4c7 udev.log_priority=3 intel_iommu=on transparent_hugepage=never rd.driver.pre=vfio-pci kvm.ignore.msrs=1 vfio-pci.ids=10de:1f08,10de:10f9,1b73:1100,1102:0012"
inxi -Fz
  Kernel: 5.17.1-3-MANJARO arch: x86_64 bits: 64 Desktop: GNOME v: 41.5
    Distro: Manjaro Linux
  Type: Desktop System: Dell product: XPS 8940 v: N/A
    serial: <superuser required>
  Mobo: Dell model: 0427JK v: A00 serial: <superuser required> UEFI: Dell
    v: 2.0.11 date: 01/22/2021
  Info: 8-core model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
    cache: L2: 4 MiB
  Speed (MHz): avg: 4759 min/max: 800/4800:4900 cores: 1: 4800 2: 4800
    3: 4725 4: 4594 5: 4752 6: 4800 7: 4800 8: 4800 9: 4807 10: 4375 11: 4791
    12: 4898 13: 4808 14: 4803 15: 4807 16: 4788
  Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] driver: i915 v: kernel
  Device-2: NVIDIA TU106 [GeForce RTX 2060 Rev. A] driver: vfio-pci v: N/A
  Device-3: Sunplus Innovation Aukey-PC-LM1E Camera type: USB
    driver: snd-usb-audio,uvcvideo
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia gpu: i915
    resolution: 1: 1920x1080~60Hz 2: 1080x1920~60Hz
  OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.3.8
  Device-1: Intel driver: snd_hda_intel
  Device-2: NVIDIA TU106 High Definition Audio driver: vfio-pci
  Device-3: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
    driver: vfio-pci
  Device-4: Sunplus Innovation Aukey-PC-LM1E Camera type: USB
  Device-5: C-Media Audio Adapter (Unitek Y-247A) type: USB
    driver: cmedia_hs100b,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.17.1-3-MANJARO running: yes
  Sound Server-2: PulseAudio v: 15.0 running: yes
  Sound Server-3: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek driver: r8169
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: virbr0 state: down mac: <filter>
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb
  Local Storage: total: 2.29 TiB used: 272.44 GiB (11.6%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC511 NVMe 512GB
  ID-2: /dev/sda vendor: Toshiba model: DT01ACA100 size: 931.51 GiB
  ID-3: /dev/sdb vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
  ID-1: / size: 91.11 GiB used: 20.35 GiB (22.3%) fs: ext4
    dev: /dev/nvme0n1p2
  ID-2: /boot/efi size: 476 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1
  ID-3: /home size: 347.28 GiB used: 252.09 GiB (72.6%) fs: ext4
    dev: /dev/nvme0n1p3
  ID-1: swap-1 type: partition size: 29.44 GiB used: 0 KiB (0.0%)
    dev: /dev/nvme0n1p4
  System Temperatures: cpu: 27.8 C pch: 54.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 872 fan-2: 990
  Processes: 374 Uptime: 12m Memory: 15.3 GiB used: 3.97 GiB (25.9%)
  Shell: Zsh inxi: 3.3.15
Journalctl (from suspend initialized via systemctl suspend to hard reboot)
Apr 23 15:10:55 calibanXIV systemd[1]: Reached target Sleep.
Apr 23 15:10:55 calibanXIV systemd[1]: Starting System Suspend...
Apr 23 15:10:55 calibanXIV systemd-sleep[4372]: Entering sleep state 'suspend'...
Apr 23 15:10:55 calibanXIV kernel: PM: suspend entry (deep)
Apr 23 15:11:12 calibanXIV kernel: Filesystems sync: 0.002 seconds
Apr 23 15:11:12 calibanXIV kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Apr 23 15:11:12 calibanXIV kernel: OOM killer disabled.
Apr 23 15:11:12 calibanXIV kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Apr 23 15:11:12 calibanXIV kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Apr 23 15:11:12 calibanXIV kernel: xhci_hcd 0000:02:00.2: xHC error in resume, USBSTS 0x401, Reinit
Apr 23 15:11:12 calibanXIV kernel: usb usb3: root hub lost power or was reset
Apr 23 15:11:12 calibanXIV kernel: usb usb4: root hub lost power or was reset
Apr 23 15:11:12 calibanXIV kernel: sd 1:0:0:0: [sdb] Synchronizing SCSI cache
Apr 23 15:11:12 calibanXIV kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Apr 23 15:11:12 calibanXIV kernel: sd 0:0:0:0: [sda] Stopping disk
Apr 23 15:11:12 calibanXIV kernel: sd 1:0:0:0: [sdb] Stopping disk
Apr 23 15:11:12 calibanXIV kernel: ACPI: PM: Preparing to enter system sleep state S3
Apr 23 15:11:12 calibanXIV kernel: ACPI: PM: Saving platform NVS memory
Apr 23 15:11:12 calibanXIV kernel: Disabling non-boot CPUs ...
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 1 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 2 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 3 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 4 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 5 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 6 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 7 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 8 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 9 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 10 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 11 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 12 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 13 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 14 is now offline
Apr 23 15:11:12 calibanXIV kernel: smpboot: CPU 15 is now offline
Apr 23 15:11:12 calibanXIV kernel: ACPI: PM: Low-level resume complete
Apr 23 15:11:12 calibanXIV kernel: ACPI: PM: Restoring platform NVS memory
Apr 23 15:11:12 calibanXIV kernel: Enabling non-boot CPUs ...
Apr 23 15:11:12 calibanXIV kernel: x86: Booting SMP configuration:
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Apr 23 15:11:12 calibanXIV kernel: CPU1 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Apr 23 15:11:12 calibanXIV kernel: CPU2 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Apr 23 15:11:12 calibanXIV kernel: CPU3 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
Apr 23 15:11:12 calibanXIV kernel: CPU4 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
Apr 23 15:11:12 calibanXIV kernel: CPU5 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
Apr 23 15:11:12 calibanXIV kernel: CPU6 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
Apr 23 15:11:12 calibanXIV kernel: CPU7 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
Apr 23 15:11:12 calibanXIV kernel: CPU8 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
Apr 23 15:11:12 calibanXIV kernel: CPU9 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
Apr 23 15:11:12 calibanXIV kernel: CPU10 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
Apr 23 15:11:12 calibanXIV kernel: CPU11 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
Apr 23 15:11:12 calibanXIV kernel: CPU12 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
Apr 23 15:11:12 calibanXIV kernel: CPU13 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
Apr 23 15:11:12 calibanXIV kernel: CPU14 is up
Apr 23 15:11:12 calibanXIV kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
Apr 23 15:11:12 calibanXIV kernel: CPU15 is up
Apr 23 15:11:12 calibanXIV kernel: ACPI: PM: Waking up from system sleep state S3
Apr 23 15:11:12 calibanXIV kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.ITBP], AE_NOT_FOUND (20211217/psargs-330)
Apr 23 15:11:12 calibanXIV kernel: ACPI Error: Aborting method \RWAK due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
Apr 23 15:11:12 calibanXIV kernel: ACPI Error: Aborting method \_WAK due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
Apr 23 15:11:12 calibanXIV kernel: sd 1:0:0:0: [sdb] Starting disk
Apr 23 15:11:12 calibanXIV kernel: sd 0:0:0:0: [sda] Starting disk
Apr 23 15:11:12 calibanXIV kernel: nvme nvme0: 16/0/0 default/read/poll queues
Apr 23 15:11:12 calibanXIV kernel: hid-generic 0003:1E7D:2FEE.0005: offset (77) exceeds report_count (64)
Apr 23 15:11:12 calibanXIV kernel: hid-generic 0003:1E7D:2FEE.0005: offset (76) exceeds report_count (64)
Apr 23 15:11:12 calibanXIV kernel: hid-generic 0003:1E7D:2FEE.0005: offset (78) exceeds report_count (64)
Apr 23 15:11:12 calibanXIV kernel: usb 1-11: reset high-speed USB device number 5 using xhci_hcd
Apr 23 15:11:12 calibanXIV kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Apr 23 15:11:12 calibanXIV kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Apr 23 15:11:12 calibanXIV kernel: ata3: SATA link down (SStatus 4 SControl 300)
Apr 23 15:11:12 calibanXIV kernel: ata2.00: supports DRM functions and may not be fully accessible
Apr 23 15:11:12 calibanXIV kernel: ata4.00: configured for UDMA/100
Apr 23 15:11:12 calibanXIV kernel: ata2.00: configured for UDMA/133
Apr 23 15:11:12 calibanXIV kernel: ata2.00: Enabling discard_zeroes_data
Apr 23 15:11:12 calibanXIV kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Apr 23 15:11:12 calibanXIV kernel: ata1.00: configured for UDMA/133
Apr 23 15:11:12 calibanXIV kernel: OOM killer enabled.
Apr 23 15:11:12 calibanXIV kernel: Restarting tasks ...
Apr 23 15:11:12 calibanXIV kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Apr 23 15:11:12 calibanXIV kernel: done.
Apr 23 15:11:12 calibanXIV kernel: thermal thermal_zone4: failed to read out thermal zone (-61)
Apr 23 15:11:12 calibanXIV kernel: video LNXVIDEO:00: Restoring backlight state
Apr 23 15:11:12 calibanXIV kernel: PM: suspend exit
Apr 23 15:11:12 calibanXIV systemd-sleep[4372]: System returned from sleep state.
Apr 23 15:11:12 calibanXIV systemd[1]: systemd-suspend.service: Deactivated successfully.
Apr 23 15:11:12 calibanXIV audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:12 calibanXIV audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:12 calibanXIV systemd[1]: Finished System Suspend.
Apr 23 15:11:12 calibanXIV systemd[1]: Stopped target Sleep.
Apr 23 15:11:12 calibanXIV systemd[1]: Reached target Suspend.
Apr 23 15:11:12 calibanXIV systemd[1]: Stopped target Suspend.
Apr 23 15:11:12 calibanXIV systemd-logind[553]: Operation 'sleep' finished.
Apr 23 15:11:12 calibanXIV kernel: audit: type=1130 audit(1650719472.026:174): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:12 calibanXIV kernel: audit: type=1131 audit(1650719472.026:175): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:12 calibanXIV dbus-daemon[551]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.70' (uid=1000 pid=1281 comm="/usr/bin/gnome-shell")
Apr 23 15:11:12 calibanXIV ModemManager[600]: <info>  [sleep-monitor] system is resuming
Apr 23 15:11:12 calibanXIV NetworkManager[584]: <info>  [1650719472.0329] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Apr 23 15:11:12 calibanXIV NetworkManager[584]: <info>  [1650719472.0330] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 23 15:11:12 calibanXIV audit: BPF prog-id=27 op=LOAD
Apr 23 15:11:12 calibanXIV kernel: audit: type=1334 audit(1650719472.029:176): prog-id=27 op=LOAD
Apr 23 15:11:12 calibanXIV systemd[1]: Starting Fingerprint Authentication Daemon...
Apr 23 15:11:12 calibanXIV kernel: Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
Apr 23 15:11:12 calibanXIV dbus-daemon[551]: [system] Successfully activated service 'net.reactivated.Fprint'
Apr 23 15:11:12 calibanXIV systemd[1]: Started Fingerprint Authentication Daemon.
Apr 23 15:11:12 calibanXIV audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:12 calibanXIV kernel: audit: type=1130 audit(1650719472.066:177): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:12 calibanXIV dbus-daemon[551]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.185' (uid=0 pid=4516 comm="gdm-session-worker [pam/gdm-password]")
Apr 23 15:11:12 calibanXIV dbus-daemon[551]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 23 15:11:12 calibanXIV gdm-password][4516]: pam_systemd_home(gdm-password:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Apr 23 15:11:12 calibanXIV NetworkManager[584]: <info>  [1650719472.2532] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Apr 23 15:11:12 calibanXIV NetworkManager[584]: <info>  [1650719472.2538] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 23 15:11:12 calibanXIV kernel: r8169 0000:04:00.0 enp4s0: Link is Down
Apr 23 15:11:14 calibanXIV ModemManager[600]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
Apr 23 15:11:14 calibanXIV ModemManager[600]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:04:00.0': not supported by any plugin
Apr 23 15:11:16 calibanXIV rtkit-daemon[939]: Supervising 11 threads of 6 processes of 1 users.
Apr 23 15:11:16 calibanXIV systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 23 15:11:16 calibanXIV audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:16 calibanXIV kernel: audit: type=1131 audit(1650719476.256:178): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4743] device (enp4s0): carrier: link connected
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4744] device (enp4s0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4750] policy: auto-activating connection 'Wired connection 1' (e0d73448-7982-3214-8308-c139b36dc33b)
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4753] device (enp4s0): Activation: starting connection 'Wired connection 1' (e0d73448-7982-3214-8308-c139b36dc33b)
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4754] device (enp4s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4755] manager: NetworkManager state is now CONNECTING
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4756] device (enp4s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 23 15:11:16 calibanXIV kernel: r8169 0000:04:00.0 enp4s0: Link is Up - 1Gbps/Full - flow control off
Apr 23 15:11:16 calibanXIV kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4759] device (enp4s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 23 15:11:16 calibanXIV NetworkManager[584]: <info>  [1650719476.4761] dhcp4 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 23 15:11:18 calibanXIV dbus-daemon[551]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=584 comm="/usr/bin/NetworkManager --no-daemon")
Apr 23 15:11:18 calibanXIV systemd[1]: Starting Network Manager Script Dispatcher Service...
Apr 23 15:11:18 calibanXIV dbus-daemon[551]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Apr 23 15:11:18 calibanXIV systemd[1]: Started Network Manager Script Dispatcher Service.
Apr 23 15:11:18 calibanXIV audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:18 calibanXIV kernel: audit: type=1130 audit(1650719478.476:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5466] dhcp4 (enp4s0): state changed new lease, address=192.168.1.49
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5478] device (enp4s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5483] device (enp4s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5483] device (enp4s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5485] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5486] manager: NetworkManager state is now CONNECTED_SITE
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5486] policy: set 'Wired connection 1' (enp4s0) as default for IPv4 routing and DNS
Apr 23 15:11:20 calibanXIV dnsmasq[774]: reading /etc/resolv.conf
Apr 23 15:11:20 calibanXIV dnsmasq[774]: using nameserver 192.168.1.1#53
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5507] device (enp4s0): Activation: successful, device activated.
Apr 23 15:11:20 calibanXIV NetworkManager[584]: <info>  [1650719480.5828] manager: NetworkManager state is now CONNECTED_GLOBAL
Apr 23 15:11:22 calibanXIV NetworkManager[584]: <info>  [1650719482.4144] dhcp6 (enp4s0): activation: beginning transaction (timeout in 45 seconds)
Apr 23 15:11:22 calibanXIV NetworkManager[584]: <info>  [1650719482.4147] policy: set 'Wired connection 1' (enp4s0) as default for IPv6 routing and DNS
Apr 23 15:11:22 calibanXIV dnsmasq[774]: reading /etc/resolv.conf
Apr 23 15:11:22 calibanXIV dnsmasq[774]: using nameserver 192.168.1.1#53
Apr 23 15:11:22 calibanXIV dnsmasq[774]: using nameserver fdaa:bbcc:ddee:0:eabe:81ff:feb5:f5e3#53
Apr 23 15:11:23 calibanXIV NetworkManager[584]: <info>  [1650719483.4669] dhcp6 (enp4s0): state changed new lease, address=2001:1711:fa57:7a00:5cf5:e075:9662:bb4d
Apr 23 15:11:23 calibanXIV dnsmasq[774]: reading /etc/resolv.conf
Apr 23 15:11:23 calibanXIV dnsmasq[774]: using nameserver 192.168.1.1#53
Apr 23 15:11:23 calibanXIV dnsmasq[774]: using nameserver fdaa:bbcc:ddee:0:eabe:81ff:feb5:f5e3#53
Apr 23 15:11:28 calibanXIV systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Apr 23 15:11:28 calibanXIV audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 23 15:11:28 calibanXIV kernel: audit: type=1131 audit(1650719488.486:180): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
