Hallo Gemeinde,
ab und zu fährt mein Dual-Boot-System (Windows 11) nicht richtig herunter.
inxi -Fz
Kernel: 6.8.0-1-MANJARO arch: x86_64 bits: 64
Desktop: Cinnamon v: 6.0.4 Distro: Manjaro Linux
Type: Desktop Mobo: N/A model: N/A serial: <superuser required>
UEFI: American Megatrends LLC. v: AM08Pro_P5C5V19 date: 09/20/2023
Info: 8-core model: AMD Ryzen 7 7735HS with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 741 min/max: 400/4829 cores: 1: 1391 2: 1362 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 1710 10: 400 11: 400 12: 400 13: 1608
14: 1396 15: 400 16: 400
Device-1: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel
Display: x11 server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 driver:
X: loaded: amdgpu unloaded: modesetting dri: radeonsi gpu: amdgpu
resolution: 3840x2160~60Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.6-manjaro1.1
renderer: AMD Radeon Graphics (radeonsi rembrandt LLVM 16.0.6 DRM 3.57
6.8.0-1-MANJARO)
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Device-4: Comtrue HIFIMAN-EF400 driver: snd-usb-audio type: USB
API: ALSA v: k6.8.0-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
Device-1: Realtek RTL8125 2.5GbE driver: r8169
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
driver: rtw89_8852be
Device-1: Realtek Bluetooth Radio driver: btusb type: USB
Local Storage: total: 476.94 GiB used: 4.7 TiB (1008.9%)
ID-1: /dev/nvme0n1 model: MasonSemi SSD size: 476.94 GiB
ID-1: / size: 287.81 GiB used: 181.76 GiB (63.2%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 26.6 MiB (27.7%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 46.2 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): N/A
Memory: total: 28 GiB available: 27.15 GiB used: 4.31 GiB (15.9%)
Processes: 434 Uptime: 14m Shell: Bash inxi: 3.3.33
hier ein Beispiel bei einem Reboot:
Feb 28 08:34:59 nipogi systemd-logind[641]: The system will reboot now!
Feb 28 08:34:59 nipogi systemd-logind[641]: System is rebooting.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Session 3 of User mm...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Session c1 of User lightdm...
Feb 28 08:34:59 nipogi systemd[1]: Removed slice Slice /system/getty.
Feb 28 08:34:59 nipogi systemd[1]: Removed slice Slice /system/modprobe.
Feb 28 08:34:59 nipogi systemd[1]: Removed slice Slice /system/systemd-coredump.
Feb 28 08:34:59 nipogi systemd[1]: system-systemd\x2dcoredump.slice: Consumed 2.242s CPU time, 689.1M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Bluetooth Support.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Graphical Interface.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Network is Online.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Sound Card.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Timer Units.
Feb 28 08:34:59 nipogi systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Feb 28 08:34:59 nipogi systemd[1]: fstrim.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Discard unused filesystem blocks once a week.
Feb 28 08:34:59 nipogi systemd[1]: logrotate.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Daily rotation of log files.
Feb 28 08:34:59 nipogi systemd[1]: man-db.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Daily man-db regeneration.
Feb 28 08:34:59 nipogi systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Monthly clean packages cache.
Feb 28 08:34:59 nipogi systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Generate mirrorlist weekly.
Feb 28 08:34:59 nipogi systemd[1]: shadow.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Daily verification of password and group files.
Feb 28 08:34:59 nipogi systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target System Time Set.
Feb 28 08:34:59 nipogi systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Closed LVM2 poll daemon socket.
Feb 28 08:34:59 nipogi systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Network Manager Wait Online.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Accounts Service...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Save/Restore Sound Card State...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Bluetooth service...
Feb 28 08:34:59 nipogi dirmngr[192924]: SIGTERM empfangen - wird heruntergefahren ...
Feb 28 08:34:59 nipogi bluetoothd[1357]: Terminating
Feb 28 08:34:59 nipogi systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Feb 28 08:34:59 nipogi systemd[1]: Stopping GnuPG network certificate management daemon for /etc/pacman.d/gnupg...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Light Display Manager...
Feb 28 08:34:59 nipogi systemd[1]: Starting Generate shutdown-ramfs...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Pamac Daemon...
Feb 28 08:34:59 nipogi systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Load/Save OS Random Seed...
Feb 28 08:34:59 nipogi systemd[1]: Stopping TLP system startup/shutdown...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Disk Manager...
Feb 28 08:34:59 nipogi systemd[1]: Stopping Daemon for power management...
Feb 28 08:34:59 nipogi lightdm[202450]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Feb 28 08:34:59 nipogi systemd[1]: run-media-mm-Windows.mount: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Unmounted /run/media/mm/Windows.
Feb 28 08:34:59 nipogi systemd[1]: accounts-daemon.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Accounts Service.
Feb 28 08:34:59 nipogi systemd[1]: session-3.scope: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Session 3 of User mm.
Feb 28 08:34:59 nipogi systemd[1]: session-3.scope: Consumed 20h 34min 28.594s CPU time, 24.9G memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd-logind[641]: Removed session 3.
Feb 28 08:34:59 nipogi systemd[1]: Stopping User Manager for UID 1000...
Feb 28 08:34:59 nipogi systemd[1269]: Activating special unit Exit the Session...
Feb 28 08:34:59 nipogi systemd[1]: session-c1.scope: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Session c1 of User lightdm.
Feb 28 08:34:59 nipogi systemd[1]: Stopping User Manager for UID 965...
Feb 28 08:34:59 nipogi systemd-logind[641]: Removed session c1.
Feb 28 08:34:59 nipogi systemd[202458]: Activating special unit Exit the Session...
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.2-org.cinnamon.CalendarServer.
Feb 28 08:34:59 nipogi systemd[1269]: app-dbus\x2d:1.2\x2dorg.cinnamon.CalendarServer.slice: Consumed 1.235s CPU time, 23.4M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.2-org.cinnamon.ScreenSaver.
Feb 28 08:34:59 nipogi systemd[1269]: app-dbus\x2d:1.2\x2dorg.cinnamon.ScreenSaver.slice: Consumed 47.060s CPU time, 169.2M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.2-org.x.reader.Daemon.
Feb 28 08:34:59 nipogi systemd[202458]: Stopped target Main User Target.
Feb 28 08:34:59 nipogi dbus-broker[202506]: Dispatched 20 messages @ 7(±9)μs / message.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.2-org.xfce.Xfconf.
Feb 28 08:34:59 nipogi dirmngr[192924]: dirmngr (GnuPG) 2.4.4 stopped
Feb 28 08:34:59 nipogi systemd[202458]: Stopping Accessibility services bus...
Feb 28 08:34:59 nipogi systemd[202458]: Stopping dbus-:1.6-org.a11y.atspi.Registry@0.service...
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.36-org.a11y.atspi.Registry.
Feb 28 08:34:59 nipogi systemd[1269]: app-dbus\x2d:1.36\x2dorg.a11y.atspi.Registry.slice: Consumed 8.788s CPU time, 2.3M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[202458]: Stopping User preferences database...
Feb 28 08:34:59 nipogi udisksd[1693]: udisks daemon version 2.10.1 exiting
Feb 28 08:34:59 nipogi systemd[1]: alsa-restore.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[202458]: Stopping Virtual filesystem service...
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/org.gnome.Terminal.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Save/Restore Sound Card State.
Feb 28 08:34:59 nipogi systemd[1269]: app-org.gnome.Terminal.slice: Consumed 13.714s CPU time, 1.1G memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped target Bluetooth.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped target Main User Target.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping dbus-:1.2-org.gnome.Identity@0.service...
Feb 28 08:34:59 nipogi systemd[202458]: Stopped Accessibility services bus.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping dbus-:1.2-org.gnome.OnlineAccounts@0.service...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping User preferences database...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Evolution address book service...
Feb 28 08:34:59 nipogi systemd[202458]: Stopped User preferences database.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Evolution calendar service...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Evolution source registry...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping GNOME Keyring daemon...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Feb 28 08:34:59 nipogi systemd[1]: run-user-965-gvfs.mount: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Unmounted /run/user/965/gvfs.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem service...
Feb 28 08:34:59 nipogi systemd[202458]: Stopped dbus-:1.6-org.a11y.atspi.Registry@0.service.
Feb 28 08:34:59 nipogi systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Unmounted /run/user/1000/gvfs.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem service - GNOME Online Accounts monitor...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem service - digital camera monitor...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem metadata service...
Feb 28 08:34:59 nipogi systemd[202458]: Removed slice Slice /app/dbus-:1.6-org.a11y.atspi.Registry.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Virtual filesystem service - disk device monitor...
Feb 28 08:34:59 nipogi wireplumber[2018]: stopped by signal: Beendet
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Multimedia Service Session Manager...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Portal service (XApp implementation)...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping Portal service...
Feb 28 08:34:59 nipogi wireplumber[2018]: disconnected from pipewire
Feb 28 08:34:59 nipogi systemd[1269]: Stopping flatpak document portal service...
Feb 28 08:34:59 nipogi systemd[1269]: Stopping sandboxed app permission store...
Feb 28 08:34:59 nipogi systemd[1]: dirmngr@etc-pacman.d-gnupg.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Feb 28 08:34:59 nipogi systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Unmounted /run/user/1000/doc.
Feb 28 08:34:59 nipogi systemd[1]: pamac-daemon.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Pamac Daemon.
Feb 28 08:34:59 nipogi systemd[1]: pamac-daemon.service: Consumed 50.491s CPU time, 1.2G memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped GNOME Keyring daemon.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped User preferences database.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem service - digital camera monitor.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem service - GNOME Online Accounts monitor.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped dbus-:1.2-org.gnome.Identity@0.service.
Feb 28 08:34:59 nipogi systemd[1269]: dbus-:1.2-org.gnome.Identity@0.service: Consumed 1.495s CPU time, 5.6M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Feb 28 08:34:59 nipogi systemd[1]: systemd-random-seed.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Load/Save OS Random Seed.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped sandboxed app permission store.
Feb 28 08:34:59 nipogi mkinitcpio[202548]: ==> Starting build: 'none'
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Portal service (XApp implementation).
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem metadata service.
Feb 28 08:34:59 nipogi systemd[1269]: gvfs-metadata.service: Consumed 3.192s CPU time, 4.0M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.2-org.gnome.Identity.
Feb 28 08:34:59 nipogi systemd[1269]: app-dbus\x2d:1.2\x2dorg.gnome.Identity.slice: Consumed 1.495s CPU time, 5.7M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi mkinitcpio[202548]: -> Running build hook: [sd-shutdown]
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem service - disk device monitor.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Feb 28 08:34:59 nipogi systemd[1269]: gvfs-afc-volume-monitor.service: Consumed 6.964s CPU time, 2.8M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped dbus-:1.2-org.gnome.OnlineAccounts@0.service.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Portal service.
Feb 28 08:34:59 nipogi systemd[1269]: xdg-desktop-portal.service: Consumed 1.430s CPU time, 7.3M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Evolution address book service.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice Slice /app/dbus-:1.2-org.gnome.OnlineAccounts.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Evolution calendar service.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Multimedia Service Session Manager.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping PipeWire Multimedia Service...
Feb 28 08:34:59 nipogi systemd[1269]: Stopped PipeWire Multimedia Service.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Evolution source registry.
Feb 28 08:34:59 nipogi systemd[1]: colord.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Feb 28 08:34:59 nipogi systemd[1]: tlp.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped TLP system startup/shutdown.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Multi-User System.
Feb 28 08:34:59 nipogi systemd[1]: Stopped target Login Prompts.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Modem Manager...
Feb 28 08:34:59 nipogi ModemManager[668]: <msg> caught signal, shutting down...
Feb 28 08:34:59 nipogi avahi-daemon[639]: Got SIGTERM, quitting.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Feb 28 08:34:59 nipogi avahi-daemon[639]: Leaving mDNS multicast group on interface wlp3s0.IPv6 with address 2a02:1748:dd4e:7800:e79e:4472:9d46:1d86.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Command Scheduler...
Feb 28 08:34:59 nipogi systemd[1]: Stopping CUPS Scheduler...
Feb 28 08:34:59 nipogi avahi-daemon[639]: Leaving mDNS multicast group on interface wlp3s0.IPv4 with address 192.168.178.57.
Feb 28 08:34:59 nipogi avahi-daemon[639]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
Feb 28 08:34:59 nipogi crond[758]: (CRON) INFO (Shutting down)
Feb 28 08:34:59 nipogi avahi-daemon[639]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Feb 28 08:34:59 nipogi avahi-daemon[639]: avahi-daemon 0.8 exiting.
Feb 28 08:34:59 nipogi bluetoothd[1357]: Battery Provider Manager destroyed
Feb 28 08:34:59 nipogi bluetoothd[1357]: Stopping SDP server
Feb 28 08:34:59 nipogi bluetoothd[1357]: Exit
Feb 28 08:34:59 nipogi ntfs-3g[83497]: Unmounting /dev/nvme0n1p3 (Windows)
Feb 28 08:34:59 nipogi systemd[1]: Stopping Record dmesg on every shutdown...
Feb 28 08:34:59 nipogi ModemManager[668]: <msg> ModemManager is shut down
Feb 28 08:34:59 nipogi NetworkManager[637]: <info> [1709105699.8869] modem-manager: ModemManager no longer available
Feb 28 08:34:59 nipogi systemd[1]: Stopping User Login Management...
Feb 28 08:34:59 nipogi systemd[202458]: Stopped Virtual filesystem service.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped Virtual filesystem service.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Touchégg Daemon...
Feb 28 08:34:59 nipogi systemd[1269]: gvfs-daemon.service: Consumed 2.131s CPU time, 21.3M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[202458]: Stopped target Basic System.
Feb 28 08:34:59 nipogi systemd[202458]: Stopped target Paths.
Feb 28 08:34:59 nipogi systemd[202458]: Stopped target Sockets.
Feb 28 08:34:59 nipogi systemd[202458]: Stopped target Timers.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GnuPG network certificate management daemon.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GCR ssh-agent wrapper.
Feb 28 08:34:59 nipogi systemd[1]: avahi-daemon.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped flatpak document portal service.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GNOME Keyring daemon.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Feb 28 08:34:59 nipogi systemd[1]: avahi-daemon.service: Consumed 41.852s CPU time, 2.0M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped target Basic System.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Feb 28 08:34:59 nipogi systemd[1269]: Stopped target Paths.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Feb 28 08:34:59 nipogi systemd[1269]: Stopped target Sockets.
Feb 28 08:34:59 nipogi systemd[1]: cups.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped target Timers.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GnuPG cryptographic agent and passphrase cache.
Feb 28 08:34:59 nipogi systemd[1]: Stopped CUPS Scheduler.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GnuPG network certificate management daemon.
Feb 28 08:34:59 nipogi systemd[202458]: Closed GnuPG public key management service.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GCR ssh-agent wrapper.
Feb 28 08:34:59 nipogi systemd[202458]: Closed p11-kit server.
Feb 28 08:34:59 nipogi systemd[1]: cronie.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[202458]: Closed PipeWire Multimedia System Sockets.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GNOME Keyring daemon.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Command Scheduler.
Feb 28 08:34:59 nipogi systemd[202458]: Closed Sound System.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Feb 28 08:34:59 nipogi systemd[1]: cronie.service: Consumed 1.554s CPU time, 4.0M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi dbus-broker[202479]: Dispatched 540 messages @ 3(±4)μs / message.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Feb 28 08:34:59 nipogi systemd[1]: rtkit-daemon.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Feb 28 08:34:59 nipogi systemd[1]: rtkit-daemon.service: Consumed 2.565s CPU time, 2.0M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[202458]: Stopping D-Bus User Message Bus...
Feb 28 08:34:59 nipogi systemd[1269]: Closed GnuPG cryptographic agent and passphrase cache.
Feb 28 08:34:59 nipogi systemd[1269]: Closed GnuPG public key management service.
Feb 28 08:34:59 nipogi systemd[1]: upower.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1269]: Closed p11-kit server.
Feb 28 08:34:59 nipogi systemd[1269]: Closed PipeWire Multimedia System Sockets.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Daemon for power management.
Feb 28 08:34:59 nipogi systemd[1269]: Closed Sound System.
Feb 28 08:34:59 nipogi dbus-broker[1356]: Dispatched 97575 messages @ 7(±8)μs / message.
Feb 28 08:34:59 nipogi systemd[1269]: Stopping D-Bus User Message Bus...
Feb 28 08:34:59 nipogi systemd[1]: udisks2.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Disk Manager.
Feb 28 08:34:59 nipogi systemd[1]: udisks2.service: Consumed 3.753s CPU time, 24.3M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi mkinitcpio[202548]: ==> Build complete.
Feb 28 08:34:59 nipogi systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Finished Generate shutdown-ramfs.
Feb 28 08:34:59 nipogi systemd[1269]: Stopped D-Bus User Message Bus.
Feb 28 08:34:59 nipogi systemd[1269]: dbus-broker.service: Consumed 5.496s CPU time, 4.6M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[202458]: Stopped D-Bus User Message Bus.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice User Core Session Slice.
Feb 28 08:34:59 nipogi systemd[1269]: session.slice: Consumed 1min 25.420s CPU time, 121.8M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[202458]: Removed slice User Core Session Slice.
Feb 28 08:34:59 nipogi systemd[1269]: Closed D-Bus User Message Bus Socket.
Feb 28 08:34:59 nipogi systemd[202458]: Closed D-Bus User Message Bus Socket.
Feb 28 08:34:59 nipogi systemd[1269]: Removed slice User Application Slice.
Feb 28 08:34:59 nipogi systemd[1269]: app.slice: Consumed 1min 32.457s CPU time, 1.2G memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi systemd[1269]: Reached target Shutdown.
Feb 28 08:34:59 nipogi systemd[202458]: Removed slice User Application Slice.
Feb 28 08:34:59 nipogi systemd[202458]: Reached target Shutdown.
Feb 28 08:34:59 nipogi systemd[1269]: Finished Exit the Session.
Feb 28 08:34:59 nipogi systemd[202458]: Finished Exit the Session.
Feb 28 08:34:59 nipogi systemd[202458]: Reached target Exit the Session.
Feb 28 08:34:59 nipogi systemd[1269]: Reached target Exit the Session.
Feb 28 08:34:59 nipogi systemd[1]: ModemManager.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Modem Manager.
Feb 28 08:34:59 nipogi systemd[1]: Stopping Authorization Manager...
Feb 28 08:34:59 nipogi systemd[1]: bluetooth.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Bluetooth service.
Feb 28 08:34:59 nipogi systemd[1]: polkit.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped Authorization Manager.
Feb 28 08:34:59 nipogi systemd[1]: polkit.service: Consumed 1.134s CPU time, 7.1M memory peak, 0B memory swap peak.
Feb 28 08:34:59 nipogi (sd-pam)[202460]: pam_unix(systemd-user:session): session closed for user lightdm
Feb 28 08:34:59 nipogi systemd[1]: user@965.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped User Manager for UID 965.
Feb 28 08:34:59 nipogi (sd-pam)[1271]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[mm] ruser=[<unknown>] rhost=[<unknown>]
Feb 28 08:34:59 nipogi systemd[1]: Stopping User Runtime Directory /run/user/965...
Feb 28 08:34:59 nipogi systemd[1]: user@1000.service: Deactivated successfully.
Feb 28 08:34:59 nipogi systemd[1]: Stopped User Manager for UID 1000.
Feb 28 08:34:59 nipogi systemd[1]: user@1000.service: Consumed 2min 58.789s CPU time, 1.3G memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: run-user-965.mount: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Unmounted /run/user/965.
Feb 28 08:35:00 nipogi systemd[1]: dmesg-shutdown.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Record dmesg on every shutdown.
Feb 28 08:35:00 nipogi systemd[1]: user-runtime-dir@965.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped User Runtime Directory /run/user/965.
Feb 28 08:35:00 nipogi systemd[1]: systemd-logind.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped User Login Management.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice User Slice of UID 965.
Feb 28 08:35:00 nipogi systemd[1]: Stopping User Runtime Directory /run/user/1000...
Feb 28 08:35:00 nipogi systemd[1]: lightdm.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Light Display Manager.
Feb 28 08:35:00 nipogi systemd[1]: lightdm.service: Consumed 2h 43min 24.215s CPU time, 284.2M memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: Stopping Permit User Sessions...
Feb 28 08:35:00 nipogi systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Permit User Sessions.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Network.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target User and Group Name Lookups.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Remote File Systems.
Feb 28 08:35:00 nipogi systemd[1]: Stopping Network Manager...
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.2792] caught SIGTERM, shutting down normally.
Feb 28 08:35:00 nipogi systemd[1]: Stopping WPA supplicant...
Feb 28 08:35:00 nipogi kernel: wlp3s0: deauthenticating from 74:42:7f:07:d4:92 by local choice (Reason: 3=DEAUTH_LEAVING)
Feb 28 08:35:00 nipogi systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped User Runtime Directory /run/user/1000.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice User Slice of UID 1000.
Feb 28 08:35:00 nipogi systemd[1]: user-1000.slice: Consumed 20h 37min 27.399s CPU time, 25.1G memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi wpa_supplicant[837]: wlp3s0: CTRL-EVENT-DISCONNECTED bssid=74:42:7f:07:d4:92 reason=3 locally_generated=1
Feb 28 08:35:00 nipogi wpa_supplicant[837]: wlp3s0: CTRL-EVENT-DSCP-POLICY clear_all
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3464] device (wlp3s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3468] manager: NetworkManager state is now DISCONNECTING
Feb 28 08:35:00 nipogi dbus-broker-launch[635]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Feb 28 08:35:00 nipogi NetworkManager[637]: <warn> [1709105700.3497] dispatcher: (11) failed (after 0.002 sec): Could not activate remote peer: activation request failed: unit is invalid.
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3498] device (wlp3s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3498] dhcp4 (wlp3s0): canceled DHCP transaction
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3498] dhcp4 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3498] dhcp4 (wlp3s0): state changed no lease
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3499] dhcp6 (wlp3s0): canceled DHCP transaction
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3499] dhcp6 (wlp3s0): activation: beginning transaction (timeout in 45 seconds)
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.3499] dhcp6 (wlp3s0): state changed no lease
Feb 28 08:35:00 nipogi wpa_supplicant[837]: nl80211: deinit ifname=wlp3s0 disabled_11b_rates=0
Feb 28 08:35:00 nipogi wpa_supplicant[837]: wlp3s0: CTRL-EVENT-TERMINATING
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.6076] manager: NetworkManager state is now DISCONNECTED
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.6084] device (p2p-dev-wlp3s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
Feb 28 08:35:00 nipogi systemd[1]: wpa_supplicant.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped WPA supplicant.
Feb 28 08:35:00 nipogi systemd[1]: wpa_supplicant.service: Consumed 4.539s CPU time, 6.9M memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi NetworkManager[637]: <info> [1709105700.6188] exiting (success)
Feb 28 08:35:00 nipogi systemd[1]: NetworkManager.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Network Manager.
Feb 28 08:35:00 nipogi systemd[1]: NetworkManager.service: Consumed 38.598s CPU time, 17.3M memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: run-user-1000.mount: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Unmounted /run/user/1000.
Feb 28 08:35:00 nipogi systemd[1]: touchegg.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Touchégg Daemon.
Feb 28 08:35:00 nipogi systemd[1]: touchegg.service: Consumed 21.313s CPU time, 43.4M memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Basic System.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Path Units.
Feb 28 08:35:00 nipogi systemd[1]: cups.path: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped CUPS Scheduler.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Slice Units.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice User and Session Slice.
Feb 28 08:35:00 nipogi systemd[1]: user.slice: Consumed 20h 37min 28.251s CPU time, 25.1G memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Socket Units.
Feb 28 08:35:00 nipogi systemd[1]: avahi-daemon.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Feb 28 08:35:00 nipogi systemd[1]: cups.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed CUPS Scheduler.
Feb 28 08:35:00 nipogi systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/dirmngr.
Feb 28 08:35:00 nipogi systemd[1]: gpg-agent-browser@etc-pacman.d-gnupg.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/gpg-agent-browser.
Feb 28 08:35:00 nipogi systemd[1]: gpg-agent-extra@etc-pacman.d-gnupg.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/gpg-agent-extra.
Feb 28 08:35:00 nipogi systemd[1]: gpg-agent-ssh@etc-pacman.d-gnupg.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/gpg-agent-ssh.
Feb 28 08:35:00 nipogi systemd[1]: gpg-agent@etc-pacman.d-gnupg.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/gpg-agent.
Feb 28 08:35:00 nipogi systemd[1]: keyboxd@etc-pacman.d-gnupg.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed GnuPG public key management service for /etc/pacman.d/gnupg.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/keyboxd.
Feb 28 08:35:00 nipogi dbus-broker[636]: Dispatched 129099 messages @ 9(±8)μs / message.
Feb 28 08:35:00 nipogi systemd[1]: Stopping D-Bus System Message Bus...
Feb 28 08:35:00 nipogi systemd[1]: dbus-broker.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped D-Bus System Message Bus.
Feb 28 08:35:00 nipogi systemd[1]: dbus-broker.service: Consumed 7.898s CPU time, 8.8M memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: dbus.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed D-Bus System Message Bus Socket.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target System Initialization.
Feb 28 08:35:00 nipogi systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Local Encrypted Volumes.
Feb 28 08:35:00 nipogi systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Feb 28 08:35:00 nipogi systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Local Integrity Protected Volumes.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Local Verity Protected Volumes.
Feb 28 08:35:00 nipogi systemd[1]: systemd-sysctl.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Apply Kernel Variables.
Feb 28 08:35:00 nipogi systemd[1]: systemd-coredump.socket: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Closed Process Core Dump Socket.
Feb 28 08:35:00 nipogi systemd[1]: systemd-modules-load.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Load Kernel Modules.
Feb 28 08:35:00 nipogi systemd[1]: Stopping Network Time Synchronization...
Feb 28 08:35:00 nipogi systemd[1]: systemd-update-done.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Update is Completed.
Feb 28 08:35:00 nipogi systemd[1]: ldconfig.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Rebuild Dynamic Linker Cache.
Feb 28 08:35:00 nipogi systemd[1]: systemd-journal-catalog-update.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Rebuild Journal Catalog.
Feb 28 08:35:00 nipogi systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Feb 28 08:35:00 nipogi systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Feb 28 08:35:00 nipogi systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Network Time Synchronization.
Feb 28 08:35:00 nipogi systemd[1]: systemd-timesyncd.service: Consumed 1.145s CPU time, 3.2M memory peak, 0B memory swap peak.
Feb 28 08:35:00 nipogi systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Create Volatile Files and Directories.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Local File Systems.
Feb 28 08:35:00 nipogi systemd[1]: Unmounting /boot/efi...
Feb 28 08:35:00 nipogi systemd[1]: Unmounting /tmp...
Feb 28 08:35:00 nipogi systemd[1]: boot-efi.mount: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Unmounted /boot/efi.
Feb 28 08:35:00 nipogi systemd[1]: tmp.mount: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Unmounted /tmp.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Swaps.
Feb 28 08:35:00 nipogi systemd[1]: Reached target Unmount All Filesystems.
Feb 28 08:35:00 nipogi systemd[1]: systemd-fsck@dev-disk-by\x2duuid-4C1C\x2dA765.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped File System Check on /dev/disk/by-uuid/4C1C-A765.
Feb 28 08:35:00 nipogi systemd[1]: Removed slice Slice /system/systemd-fsck.
Feb 28 08:35:00 nipogi systemd[1]: Stopped target Preparation for Local File Systems.
Feb 28 08:35:00 nipogi systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Feb 28 08:35:00 nipogi systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Create Static Device Nodes in /dev.
Feb 28 08:35:00 nipogi systemd[1]: systemd-sysusers.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Create System Users.
Feb 28 08:35:00 nipogi systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Remount Root and Kernel File Systems.
Feb 28 08:35:00 nipogi systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Feb 28 08:35:00 nipogi systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Feb 28 08:35:01 nipogi systemd[1]: lvm2-monitor.service: Deactivated successfully.
Feb 28 08:35:01 nipogi systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Feb 28 08:35:01 nipogi systemd[1]: Reached target System Shutdown.
Feb 28 08:35:01 nipogi systemd[1]: Reached target Late Shutdown Services.
Feb 28 08:35:01 nipogi systemd[1]: systemd-reboot.service: Deactivated successfully.
Feb 28 08:35:01 nipogi systemd[1]: Finished System Reboot.
Feb 28 08:35:01 nipogi systemd[1]: Reached target System Reboot.
Feb 28 08:35:01 nipogi systemd[1]: Shutting down.
Feb 28 08:35:01 nipogi systemd[1]: Using hardware watchdog 'SP5100 TCO timer', version 0, device /dev/watchdog0
Feb 28 08:35:01 nipogi systemd[1]: Watchdog running with a timeout of 10min.
Feb 28 08:35:01 nipogi kernel: watchdog: watchdog0: watchdog did not stop!
Feb 28 08:35:01 nipogi systemd-shutdown[1]: Using hardware watchdog 'SP5100 TCO timer', version 0, device /dev/watchdog0
Feb 28 08:35:01 nipogi systemd-shutdown[1]: Watchdog running with a timeout of 10min.
Feb 28 08:35:01 nipogi systemd-shutdown[1]: Syncing filesystems and block devices.
Feb 28 08:35:01 nipogi systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Feb 28 08:35:01 nipogi systemd-journald[393]: Received SIGTERM from PID 1 (systemd-shutdow).
Feb 28 08:35:01 nipogi systemd-journald[393]: Journal stopped
Dabei ist es unerheblich, ob ich neu starte oder ganz herunterfahre. Auch der hier laufende Kernel 6.8.0 spielt keine Rolle. Beim LTS 6.6.18 besteht das Problem genau so.
Danach ist nur noch der Powerbutton zu betätigen, was keine Lösung ist.
Wie kann ich das Problem lösen?
Vielen Dank schon einmal im Voraus
nabashi
