When I first time reboot manjaro KDE after last update, the black screen appears when I logged in.
Wallpaper appears for a second and disappears.
My gpu Intel/ Radeon
I switch to tty 2 and ran ‘startx’
(==) Log file: …path/to/log/file…
(==) using config directory: “/etc/X11/xorg.conf.d”
(==) using system config directory “/usr/share/X11/forgot.conf.d”
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.ng kms color map for depth 24, 8 bpc.
Couldn’t exec startkde: no such file or d
In logs last information:
‘Failed to open protocol names file lib/xorg/protocol.txt’
Lock screen works as expected and shows after some period of inactvity.
I try to run in on kernel 5.8 and 5.4 but it fails in both cases.
Tried to run ‘kstart5 plasmashell’ and got:
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Could you help me solve this problem?
