Hi all !
So here’s my issue. I use a KVM switch to switch my monitors from my macbook to my desktop.
When I switch back from my macbook I get a black screen and need to hard reset the desktop. I tried a lot of different OS recently and none had this issue. I also used manjaro before without this issue.
I have no clue where to look
inxi
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=b9d01d7a-cd5a-4e65-96aa-cd4cc49dbaa2 rw quiet splash apparmor=1
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1216
date: 11/24/2020
RAM: total: 15.6 GiB used: 2.25 GiB (14.4%)
RAM Report:
Info: model: AMD Ryzen 5 3600XT bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4003 high: 4022 min/max: 2200/4879 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4001 2: 4017
3: 4022 4: 3995 5: 4003 6: 3975 7: 3996 8: 3994 9: 4000 10: 4010 11: 4021
12: 4009 bogomips: 96045
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: XFX Pine driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 0c:00.0
chip-ID: 1002:731f class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.2.1:4 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: X: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: 0
Monitor-1: DP-1 model: ASUS VP28U serial: <filter> built: 2018
res: 3840x2160 dpi: 157 gamma: 1.2 size: 621x341mm (24.4x13.4")
diag: 708mm (27.9") ratio: 16:9 modes: max: 3840x2160 min: 640x350
Monitor-2: DP-2 model: Lenovo LEN P27h-10 serial: <filter> built: 2020
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.2")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.42.0
5.15.25-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab38
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7.4:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.14 TiB used: 573.1 GiB (49.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P5SSD8
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: X400 M.2 2280 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0012 scheme: GPT
ID-1: / raw-size: 107.42 GiB size: 105.18 GiB (97.91%)
used: 16.14 GiB (15.3%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: b9d01d7a-cd5a-4e65-96aa-cd4cc49dbaa2
used: 34.1 MiB (35.6%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 40B9-CF03
ID-3: /mnt/data raw-size: 931.5 GiB size: 931.5 GiB (100.00%)
used: 556.93 GiB (59.8%) fs: ntfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: Data uuid: AE58ABEE58ABB40D
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: D04AB7EC4AB7CD8A
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
ID-4: /dev/sda4 maj-min: 8:4 size: 129.91 GiB fs: ntfs label: Windows
uuid: 9668BFB368BF908B
ID-5: /dev/sda5 maj-min: 8:5 size: 523 MiB fs: ntfs label: N/A
uuid: FE0ACE610ACE1715
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-6:2 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-7.4:4 info: Intel AX200 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 3-1:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Hub-6: 3-1.2:3 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 3-1.2.1:4 info: Logitech C922 Pro Stream Webcam
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 046d:085c class-ID: 0102
serial: <filter>
Device-2: 3-1.2.2:5 info: Elan Micro Gaming KB type: Keyboard
power: 100mA chip-ID: 04f3:152e class-ID: 0301
Device-3: 3-1.2.3:6 info: Logitech G502 SE HERO Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C mem: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 384 Uptime: 4m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1158 pacman: 1153 lib: 311
flatpak: 5 Shell: Zsh v: 5.8.1 running-in: gnome-terminal inxi: 3.3.13
xrandr
Screen 0: minimum 16 x 16, current 5120 x 1440, maximum 32767 x 32767
XWAYLAND0 connected primary 2560x1440+2560+0 (normal left inverted right x axis y axis) 620mm x 340mm
2560x1440 59.91*+
1920x1440 59.90
1600x1200 59.87
1440x1080 59.87
1400x1050 59.86
1280x1024 59.89
1280x960 59.94
1152x864 59.78
1024x768 59.68
800x600 59.86
640x480 59.38
320x240 59.52
1920x1200 59.88
1680x1050 59.95
1440x900 59.89
1280x800 59.81
720x480 59.71
640x400 59.20
320x200 58.96
2048x1152 59.90
1920x1080 59.88
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
XWAYLAND1 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
2560x1440 59.91*+
1920x1440 59.90
1600x1200 59.87
1440x1080 59.87
1400x1050 59.86
1280x1024 59.76
1280x960 59.94
1152x864 59.78
1024x768 59.68
800x600 59.86
640x480 59.38
320x240 59.52
1920x1200 59.88
1680x1050 59.85
1440x900 59.89
1280x800 59.81
720x480 59.71
640x400 59.20
320x200 58.96
2048x1152 59.90
1920x1080 59.88
1600x900 59.82
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.45
720x400 59.55
640x350 59.77
