Hi i have a gpd winmax 2 and i love manjaro but it also my only linux option with proper support for the handheld. but i am having a problem, while i use the machine, specially on krita or blender wich is how i work even while using the magma drawing site, i get a black screen crash.
the screen is still turned on, but nothing is happening using Ctrl+Alt+F1/F2/F3 dosnt do anything when the crash happens, neither does closing it and opening it. it seems to be a graphical issue since it works perfectly otherwise.
i tried unckechink the “allow apps tp block compositing” but it did not work, i updated the bios, the os is up to date as far as i am aware im still a somewhat new user to linux, and other than these crashes where i have to hold the power butter till it turnes off, i have no issues and i love manjaro. changing the manjaro power usage (performance, balanced, saving) also did not help
i made this same post on r/manjaro and thanks to some help i changed the kernel 2 times, and i added 38gb of swapon as per the table for the 32gb of ram with hibernation. Neither yielded any results, im hoping i can fix this because otherwise ill have to use windows ![]()
Sorry for the drive folder with the images but i cant seem to post this with the pics attatched since i just made the acc.
but thanks to another user on reddit i gave more info
ill leave the system info on the photos, i really dont know how to fix it ![]()
thank you for any help and for reading!!!
inxi -zv8c0
Kernel: 6.17.1-0-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.17-x86_64
root=UUID=71876f6a-1a6f-44af-8142-08129bb89954 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
Type: N/A System: GPD product: G1619-04 v: Ver.1.0
serial: <superuser required>
Mobo: GPD model: G1619-04 v: Ver.1.0 serial: <superuser required>
part-nu: 7896551968635 uuid: <superuser required> UEFI: American Megatrends
LLC. v: 1.05 date: 12/17/2022
ID-1: BAT0 charge: 63.2 Wh (100%) condition: 63.2/67.1 Wh (94.1%)
volts: 16.61 min: 15.4 model: Standard SR Real Battery type: Li-ion
serial: <filter> charging: status: full cycles: N/A
System RAM: total: 32 GiB available: 28.13 GiB used: 11.06 GiB (39.3%)
Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 6400 MT/s volts: curr: 0.5 min: 0.5
max: 0.5 width (bits): data: 32 total: 32 manufacturer: Hynix
part-no: H9JCNNNFA5MLYR-N6E serial: N/A
Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 6800U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404108
desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3943 min/max: 402/4770 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3943 2: 3943 3: 3943
4: 3943 5: 3943 6: 3943 7: 3943 8: 3943 9: 3943 10: 3943 11: 3943 12: 3943
13: 3943 14: 3943 15: 3943 16: 3943 bogomips: 86243
xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: IP3 Tech driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
HDMI-A-1, Writeback-1 bus-ID: 73:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 67.0 C
Device-2: Tripath USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.1:3 chip-ID: 058e:3864
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: eDP-1 mapped: eDP model: GPD1001H serial: <filter> built: 2022
res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 225 gamma: 1.2 chroma: red:
x: 0.627 y: 0.341 green: x: 0.278 y: 0.596 blue: x: 0.153 y: 0.071 white:
x: 0.282 y: 0.298 size: 217x135mm (8.54x5.31") diag: 1021mm (40.2")
ratio: 16:9 modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
rembrandt LLVM 20.1.8 DRM 3.64 6.17.1-0-MANJARO) device-ID: 1002:1681
memory: 2.93 GiB unified: no
API: Vulkan v: 1.4.321 layers: 6 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 25.2.3-arch1.2
device-ID: 1002:1681 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 73:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 73:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Conexant Systems driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 73:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.17.1-0-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
chip-ID: 8086:2725 class-ID: 0280
IF-ID-1: wwan0 state: down mac: N/A
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0032
class-ID: e001
Local Storage: total: 1.85 TiB used: 634.45 GiB (33.5%)
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731030WD temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: General UDisk size: 29.3 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 5.00 scheme: MBR
ID-1: / raw-size: 1.78 TiB size: 1.78 TiB (100.00%) used: 634.38 GiB (34.8%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 71876f6a-1a6f-44af-8142-08129bb89954
used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6D28-C751
ID-3: /home raw-size: 1.78 TiB size: 1.78 TiB (100.00%)
used: 634.38 GiB (34.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 71876f6a-1a6f-44af-8142-08129bb89954
ID-4: /run/media/erisg/IACB raw-size: 29.26 GiB size: 29.26 GiB (100.00%)
used: 65.4 MiB (0.2%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: IACB
uuid: 47F06A796C00587F
ID-5: /var/cache raw-size: 1.78 TiB size: 1.78 TiB (100.00%)
ID-6: /var/log raw-size: 1.78 TiB size: 1.78 TiB (100.00%)
ID-1: swap-1 type: partition size: 37.25 GiB used: 6.6 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 08d92e4e-05f9-441f-a585-f385d3a8648c
ID-1: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 3105-B091
Device-1: 1-3:2 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
Device-2: 1-4:3 info: Mouse for Windows type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 2f24:0135 class-ID: 0300
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Device-1: 3-1.1:6 info: Integrated Express Chipsbank CBM2199 Flash Drive
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 048d:1234 class-ID: 0806 serial: <filter>
Device-2: 3-1.4:4 info: Elecom TrackBall Mouse type: mouse
driver: elecom,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 98mA chip-ID: 056e:018d class-ID: 0301
Device-3: 3-3:3 info: Intel AX210 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0032 class-ID: e001
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0625
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 5-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 5-1.1:3 info: Tripath USB Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 058e:3864 class-ID: 0e02
Device-2: 5-1.2:4 info: Quectel Wireless Solutions EC25 LTE modem
type: <vendor specific> driver: option,option1,qmi_wwan interfaces: 5
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
chip-ID: 2c7c:0125 class-ID: ef00
Device-3: 5-1.3:5 info: Chipsailing CS9711Fingprint
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 2541:9711 class-ID: 0000
Hub-9: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-11: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-12: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-13: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 88.0 C mobo: N/A gpu: amdgpu temp: 68.0 C
Fan Speeds (rpm): N/A
Packages: 1640 pm: dpkg pkgs: 0 pm: pacman pkgs: 1612 libs: 416
tools: gnome-software, pamac, yaourt, yay pm: flatpak pkgs: 28
1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
2: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://mirror.23m.com/manjaro/stable/$repo/$arch
8: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 411
1: cpu: 449% command: java pid: 8542 mem: 6521.9 MiB (22.6%)
2: cpu: 22.6% command: java pid: 8344 mem: 835.9 MiB (2.9%)
3: cpu: 2.9% command: brave pid: 5163 mem: 371.6 MiB (1.2%)
4: cpu: 2.3% command: brave pid: 5116 mem: 570.2 MiB (1.9%)
5: cpu: 1.6% command: Telegram pid: 4405 mem: 723.4 MiB (2.5%)
Memory top: 5 of 411
1: mem: 6521.9 MiB (22.6%) command: java pid: 8542 cpu: 449%
2: mem: 835.9 MiB (2.9%) command: java pid: 8344 cpu: 22.6%
3: mem: 723.4 MiB (2.5%) command: Telegram pid: 4405 cpu: 1.6%
4: mem: 606.4 MiB (2.1%) command: plasmashell pid: 1380 cpu: 0.5%
5: mem: 570.2 MiB (1.9%) command: brave pid: 5116 cpu: 2.3%
Processes: 411 Power: uptime: 1h 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 11.23 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 14 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.39
kinfo
KDE Plasma Version: 6.3.6
KDE Frameworks Version: 6.18.0
Qt Version: 6.9.2
Kernel Version: 6.17.1-0-MANJARO (64-bit)
Graphics Platform: X11
Processors: 16 Ă— AMD Ryzen 7 6800U with Radeon Graphics
Memory: 28.1 GiB of RAM
Graphics Processor: AMD Radeon Graphics
systemctl list-unit-files --state enabled
UNIT FILE STATE PRESET
cups.path enabled disabled
bluetooth.service enabled disabled
cronie.service enabled disabled
cups.service enabled disabled
getty@.service enabled enabled
input-remapper.service enabled disabled
ModemManager.service enabled disabled
NetworkManager-dispatcher.service enabled disabled
NetworkManager-wait-online.service enabled disabled
NetworkManager.service enabled disabled
sddm.service enabled disabled
systemd-timesyncd.service enabled enabled
cups.socket enabled disabled
systemd-userdbd.socket enabled enabled
remote-fs.target enabled enabled
fstrim.timer enabled disabled
pamac-cleancache.timer enabled disabled
pamac-mirrorlist.timer enabled disabled
18 unit files listed.
systemd-analyze
Startup finished in 5.803s (firmware) + 6.785s (loader) + 4.892s (kernel) + 5.622s (userspace) = 23.103s
graphical.target reached after 5.622s in userspace.
systemd-analyze blame
2.200s plymouth-quit-wait.service
2.200s plymouth-quit.service
968ms systemd-binfmt.service
834ms NetworkManager.service
531ms input-remapper.service
377ms dev-nvme0n1p2.device
237ms systemd-udev-trigger.service
211ms systemd-journal-flush.service
189ms systemd-journald.service
171ms user@1000.service
170ms systemd-tmpfiles-setup.service
156ms upower.service
154ms systemd-remount-fs.service
126ms systemd-tmpfiles-setup-dev-early.service
121ms ModemManager.service
120ms polkit.service
114ms systemd-hostnamed.service
89ms udisks2.service
82ms systemd-userdbd.service
81ms systemd-logind.service
76ms systemd-modules-load.service
74ms lvm2-monitor.service
74ms bluetooth.service
69ms bolt.service
63ms systemd-udev-load-credentials.service
59ms systemd-tmpfiles-clean.service
55ms systemd-fsck@dev-disk-by\x2duuid-6D28\x2dC751.service
54ms dev-disk-by\x2duuid-08d92e4e\x2d05f9\x2d441f\x2da585\x2df385d3a8648c.swap
54ms plymouth-start.service
49ms dbus-broker.service
49ms accounts-daemon.service
47ms power-profiles-daemon.service
47ms systemd-rfkill.service
46ms rtkit-daemon.service
46ms boot-efi.mount
40ms systemd-udevd.service
38ms systemd-vconsole-setup.service
38ms alsa-restore.service
35ms systemd-random-seed.service
35ms systemd-update-utmp.service
27ms systemd-backlight@backlight:amdgpu_bl1.service
27ms systemd-timesyncd.service
26ms modprobe@dm_mod.service
26ms wpa_supplicant.service
24ms modprobe@loop.service
24ms home.mount
22ms proc-sys-fs-binfmt_misc.mount
22ms tmp.mount
22ms dev-hugepages.mount
22ms user-runtime-dir@1000.service
21ms NetworkManager-wait-online.service
21ms dev-mqueue.mount
21ms var-cache.mount
20ms sys-kernel-debug.mount
19ms pamac-daemon.service
19ms sys-kernel-tracing.mount
19ms systemd-tmpfiles-setup-dev.service
19ms cups.service
18ms kmod-static-nodes.service
17ms plymouth-read-write.service
16ms modprobe@configfs.service
16ms sys-fs-fuse-connections.mount
15ms modprobe@fuse.service
15ms modprobe@drm.service
15ms sys-kernel-config.mount
11ms var-log.mount
10ms systemd-sysctl.service
5ms systemd-user-sessions.service
Mod edit (scotty65): added command outputs from pastebin links
Update:
Quick update for anyone who might have the same problem, KDE is causing the crash i still dont know why but gnome plasma works fine on other distros, i had some trouble with bazzite with some other things but atleast i know the reason for the crash, ill miss manjaro though. :(.
