@cmarland00 no problem… at least you made no stupid space between the link text.
ok well what i see is this:
[ 8.074] (II) VESA: driver for VESA chipsets: vesa
[ 8.117] vesa: Refusing to run on UEFI
[ 8.117] (EE) No devices detected.
[ 8.117] (EE)
Fatal server error:
[ 8.117] (EE) no screens found(EE)
[ 8.117] (EE)
and this on the last working Xorg log:
962840.444] (II) LoadModule: "vesa"
[962840.445] (WW) Warning, couldn't open module vesa
[962840.445] (EE) Failed to load module "vesa" (module does not exist, 0)
[962840.445] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[962840.445] (II) intel: Driver for Intel(R) HD Graphics
[962840.445] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[962840.445] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[962840.445] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[962840.853] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200515
[962840.853] (II) intel(0): SNA compiled from 2.99.917-913-g9236c582
[962840.870] (WW) Falling back to old probe method for modesetting
[962840.871] (--) intel(0): gen9 engineering sample
[962840.871] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[962840.871] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[962840.872] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[962840.872] (==) intel(0): RGB weight 888
[962840.872] (==) intel(0): Default visual is TrueColor
[962840.874] (II) intel(0): Output eDP1 has no monitor section
[962840.874] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[962840.874] (II) intel(0): Enabled output eDP1
[962840.875] (II) intel(0): Output DP1 has no monitor section
[962840.875] (II) intel(0): Enabled output DP1
[962840.875] (II) intel(0): Output HDMI1 has no monitor section
[962840.876] (II) intel(0): Enabled output HDMI1
[962840.876] (II) intel(0): Output DP2 has no monitor section
[962840.876] (II) intel(0): Enabled output DP2
[962840.876] (II) intel(0): Output HDMI2 has no monitor section
[962840.877] (II) intel(0): Enabled output HDMI2
[962840.877] (II) intel(0): Output DP2-1 has no monitor section
[962840.878] (II) intel(0): Enabled output DP2-1
[962840.878] (II) intel(0): Output DP2-2 has no monitor section
[962840.878] (II) intel(0): Enabled output DP2-2
[962840.878] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[962840.879] (II) intel(0): Output VIRTUAL1 has no monitor section
[962840.879] (II) intel(0): Enabled output VIRTUAL1
[962840.879] (--) intel(0): Output eDP1 using initial mode 2736x1824 on pipe 0
[962840.879] (--) intel(0): Output DP2-1 using initial mode 1920x1080 on pipe 1
[962840.879] (--) intel(0): Output DP2-2 using initial mode 1920x1080 on pipe 2
[962840.880] (==) intel(0): TearFree enabled
[962840.880] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[962840.880] (==) intel(0): DPI set to (96, 96)
I guess you installed video-vesa
with video-linux
together by the mhwd tool. Therefore it loads the vesa driver (in general only basic video output for the terminal) and not the intel driver.
Keep sure you have ONLY installed video-linux
This shows the installed configs:
mhwd -li
