In any case I cannot help without the actual information.
The typed out snippet above
Is closer … but still must be missing portions.
I will also note that given the nature of your error, and the packages that seem to be involved … you are also dealing with a very out of date and unmaintained system.
If we cannot see the issue in full, and if you cannot fix it yourself, then we may have to simply suggest you back up important information and install using a current Manjaro ISO.
First, lets try again and go about this a different way…
We know adw-gtk3 does not exist in the repos or the AUR.
And we know that your system has a package that wants it for some reason.
Maybe we can find out what that is with the following:
First ignore all dependency checks and remove the adw-gtk3 (normally never use this flag!), and then the update should be able to continue. At least from this issue.
During the update, everything went smoothly - the packages were downloaded, but the process ended with this line. Errors occurred, no packages were upgraded.
Next, I did a reboot and tried to repeat the update. This is what happened https://0x0.st/Xxbe.txt
From a very quick scan of this thread, it looks like your system is a year out-of-date. Kernel 5.15.131 was released on 06-Sep-2023, and kernel 5.15.132 replaced it on 19-Sep-2023: Index of /pub/linux/kernel/v5.x/
The glibc issue looks like the one mentioned (and for which instructions to fix were provided) in the “Known issues and solutions” section of the Stable Update thread from 2023-10-13:
It looks like you have either recently installed a very outdated ISO of Manjaro or, if you have had Manjaro installed for a year or so, then you have not been maintaining your system correctly and keeping an eye on the Latest Announcements/Stable Updates topics - Manjaro Linux Forum
Please indicate which post helped the most to achieve this result. Mark it as the solution by using the checkmark (tick) button under whichever post that may be.
