Hello, I don’t need help but have been having a bizarre intermittent issue with black screen boots. For whatever reason fully removing(safely) all voltage from the pc for about a minute solves the problem(shutdown then removing power plug). Couldn’t tell you why, but wanted to give another possible temp solution for anyone else experiencing this.
sys stuff:
Kernel: 6.11.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=0fbb8345-c2ca-466b-a7e0-e09278d25bbe rw quiet splash
resume=UUID=8cc72b31-cd97-4b44-8f6a-3732212a0278 udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: Gigabyte model: B450 AORUS M v: x.x
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: F51 date: 07/29/2020
System RAM: total: 16 GiB available: 15.56 GiB used: 2.27 GiB (14.6%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: no module installed
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 1866 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-8GVKB serial: N/A
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+ gen: 1+
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
smt: enabled cache: L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB
desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2682 min/max: 2200/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2682 2: 2682 3: 2682
4: 2682 5: 2682 6: 2682 7: 2682 8: 2682 9: 2682 10: 2682 11: 2682 12: 2682
13: 2682 14: 2682 15: 2682 16: 2682 bogomips: 118223
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
DP-3, DVI-D-1 bus-ID: 06:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 54.0 C
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) IPS QHD
serial: <filter> built: 2024 res: 2560x1440 hz: 75 dpi: 93 gamma: 1.2
chroma: red: x: 0.671 y: 0.325 green: x: 0.302 y: 0.635 blue: x: 0.149
y: 0.047 white: x: 0.314 y: 0.329 size: 698x393mm (27.48x15.47")
diag: 801mm (31.5") ratio: 16:9 modes: 2560x1440, 3840x2160, 1920x1200,
1920x1080, 1600x1200, 1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 93 2: parse_edid:
unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 95
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 18.1.8 DRM 3.59 6.11.11-1-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.303 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: N/A device-ID: 1002:67df
surfaces: xcb,xlib
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 06:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 08:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.4:4
chip-ID: 03f0:0294 class-ID: 0300
API: ALSA v: k6.11.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 6.14 TiB used: 2.39 TiB (39.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0002 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 3.63 TiB size: 3.57 TiB (98.40%) used: 671.47 GiB (18.4%)
fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
uuid: 0fbb8345-c2ca-466b-a7e0-e09278d25bbe
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: 14F2-3A12
ID-3: /game1 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.42 TiB (79.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: game1
uuid: 29e3b9c2-a2e5-4c72-a123-0d11f3cf6216
ID-4: /game2 raw-size: 698.63 GiB size: 686.6 GiB (98.28%)
used: 328.55 GiB (47.9%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: game2
uuid: 6468af10-2ea7-4973-988f-d799f27f76b8
dev: /dev/sdc3 maj-min: 8:35 label: swap
uuid: 8cc72b31-cd97-4b44-8f6a-3732212a0278
Device-1: 1-1:2 info: Holtek Gaming keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a1cd class-ID: 0300
Device-2: 1-2:3 info: Corsair SABRE RGB PRO Gaming Mouse
type: mouse,HID,keyboard driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 1b1c:1b79 class-ID: 0301 serial: <filter>
Hub-4: 3-3:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Device-1: 3-3.1:3 info: HP HyperX QuadCast S type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 03f0:028c class-ID: 0300
Device-2: 3-3.4:4 info: HP HyperX QuadCast S type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 40.5 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 780
Packages: pm: pacman pkgs: 1577 libs: 481 tools: pamac pm: flatpak pkgs: 0
1: http://mirror.fcix.net/manjaro/stable/$repo/$arch
2: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
4: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
5: https://mirror.koddos.net/manjaro/stable/$repo/$arch
6: https://mirror.zetup.net/manjaro/stable/$repo/$arch
7: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
8: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 365
1: cpu: 200% command: ps pid: 2070 mem: 3.46 MiB (0.0%)
2: cpu: 22.2% command: firefox pid: 1475 mem: 460.9 MiB (2.8%)
3: cpu: 9.1% command: zsh pid: 1980 mem: 9.58 MiB (0.0%)
4: cpu: 8.5% command: firefox pid: 1571 mem: 256.9 MiB (1.6%)
5: cpu: 5.3% command: konsole pid: 1947 mem: 155.3 MiB (0.9%)
Memory top: 5 of 365
1: mem: 460.9 MiB (2.8%) command: firefox pid: 1475 cpu: 22.2%
2: mem: 350.2 MiB (2.1%) command: plasmashell pid: 897 cpu: 1.7%
3: mem: 274.3 MiB (1.7%) command: firefox pid: 1677 cpu: 4.4%
4: mem: 256.9 MiB (1.6%) command: firefox pid: 1571 cpu: 8.5%
5: mem: 245.5 MiB (1.5%) command: manjaro-hello started-by: python3
pid: 1167 cpu: 0.8%
Processes: 365 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.36
